Question about Abu Garcia Abumatic 170i Spincast Reel
Line doesn't come out freely
When you cast, the line won't come out freely.
How can I get my reel to cast smoothly?
Hey Ken, Neil here from Dark Side Reelz. it boils down to over oiled bearings, or bearings that require cleaning, your spool shaft only rides on 2 or max of 3 points, (depending on reel make) each of those points contains a bearing the spool shaft seats in those bearings any build up will greatly reduce casting distance. I specialize in reel cleanings, rebuilds and restorations as well as custom work like upgrades and super tuning. If you would like to read some really good info on what you can do read this article I wrote http://ezangler.com/tackle-box/gear-tips/the-reel-truth/ here is the link to my webiste as well www.darksidereelz.com
Jul 05, 2014 | Generic Ardent C400 Fishouflage Bass...
2003 gmc envoy 4x4 problems. 4200 vortec engine. my front diff doesnt seem to be working
Look under there and see, but I think they (the hub locks) are engaged by vacuum motors.
May 18, 2017 | 2003 GMC Envoy
Hoover spirit 900 canister wont turn on?
see this causes and fix it. God bless you
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
Sep 27, 2012 | Hoover Vacuums
My line won't rewind on my Shakespeare Encore reel. After casting, the bail snaps in place, but when I reel in, the line won't reel in. The spool turns with the bail, but doesn't retriev
Your line is on the wrong side of the bail. Rethread the line so its over the bail so that after the cast you flip it up it catches the line and retracts it.
May 05, 2012 | Sport & Outdoor - Others
The left side of the toaster does not stay engaged...if I hold it down it heats up but it doesn't stay down ..it doesn't catch.
There are two printed circuit boards inside front of toaster - One PC board for each side. The circuit board on the side that won't latch down in the "toasting" position , is defective. Now, does anyone have access to a schematic for this toaster?
Jul 02, 2011 | Cuisinart CMT-400 Cast Metal 4-Slice...
Where can I get a manual for a vermont casting 1982 intrepid 1 non catalytic woodstove?
Since Vermont Castings has gone through 3 different ownerships in the past 10 years, the chances of finding the manual, for your discontinued model are slim and none. Having been a VC dealer up until 5 or 6 years ago, my data base is pretty complete. However, the Model 1982 Intrepid I Non-catalytic Wood Burning Stove doesn't even show up there. If the dealer you purchased you stove from is still in business & is still a VC Dealer, that would be the best place to start. As, his records would go back further than mine. But, I must caution you, many dealer like myself, dropped the Vermont Castings line, during the last part of it's Ownership, by Majestic Fireplace Corp. VC is now owned my Monessen Hearth Hearth Systems.
Hope this helped you some.
Jun 21, 2011 | Heating & Cooling
Model 345 won't start. New fresh gas/oil mix. Cleaned carb with liberal applications of gumout. Removed diaphragm and inspected carb, cleaned what passages I could identify. Cleaned fuel line. The fuel...
There is a vent in the tank, it is situated on the right hand side of the tank, close to where the fuel hose exits the tank, the early vent looks like a round white pellet, the later vent is a white plug with a nipple on the top, the later vent will just pull out with long nose pliers, the early vent has to be extracted useing a self tapping screw, this of course will destroy the vent.
Jun 07, 2011 | Husqvarna Garden
Cant cast the pinnacle platinum plus lp 100 fishing reel more than 15 feet because the line tangles. Any suggestions?
Sounds like your drag is too loose. Best way to get used to setting a baitcaster, in my opinion, is to put a 1/2 ounce weight on the end of the line and engage the spool. The line should drop to the ground freely, but not full speed - if too fast, the spool will continue to spin and you'll get that dreaded birdsnest. If it doesn't reach the ground, you need to loosen it more. Once you have it set, keep that weight on and go practice, using the thumbing process Parorae noted in the previous answer.
They take some getting used to for sure!
Aug 04, 2010 | Pinnacle Solene SLP10 Baitcast Reel
Abu Garcia Abumatic 170i Spincast Reel Logo
Top Abu Garcia Fishing Experts
Ngoro
Ngoro
ray gallant
Steve P
Steve P
Are you an Abu Garcia Fishing Expert? Answer questions, earn points and help others
