Question about Onkyo DV-SP404 DVD Player
ONKYO DV-SP404 REMOTE CONTROL CODE
REMOTE CONTROL CODE NEEDED
4 Suggested Answers
  • 8 Answers
SOURCE: Onkyo DVD player - remote doesn't function at all
One of the two things might have happened:
- The IR sensor got covered - by some reason
- the IR sensor talks to a small controller back - which is not working at all.
Posted on Dec 17, 2008
SOURCE: Remote control via RI terminal on Onkyo Receiver
Not sure I can solve, but maybe help. I am having a similiar problem. However, make sure you Analog Audio (RCA type) cable are connected even if using Digital connection between the two. They use those cable to send the Commands (Mentioned in the documentation).
If you did get yours to work, please give me a hint... I upgraded mine from a 603 to a 701 and haven't been able to get it to work since.
Posted on Feb 14, 2009
  • 1335 Answers
SOURCE: Have lost the remote control
You can get a substitute remote (the original remote is no longer available) at
http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13118717212490&smodel=DVCP702&brand_pn=ONKYO_DVCP702
Let me know if you have any other problems or questions.Please rate this solution. Thanks.
Posted on Jul 28, 2011
DVD fails to load. Unit then shuts down
Disc loading mechanism fault. Either the loading belt broken or any broken gear wheel can cause this problem. You have to take out the loading mechanism out from it to get it repaired. Contact any service technician. In some cased, the the loading mechanism might have to be replaced with a new one. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 11, 2015 | Onkyo DV-SP404 DVD Player
Tip
Onkyo Remote Control Codes
Onkyo 5-digit Remote Control Codes
Have you lost the remote codes list for your Onkyo Remote Control?
Would you a like a digital, searchable version of the 5-digit Onkyo remote code list?
A pdf version of the Onkyo remote control code list is available here.
I hope that helps.
on Apr 11, 2010 | Televison & Video
Have lost the remote control to onkyo dv cp702. Would like to access the random option.
Jul 28, 2011 | Onkyo DV-CP702 DVD Player
Onkyo DV-SP405 DVD player says no disc
This woud be due to two things
1. laser
2. servo motor not spinning to the correct speeds i,e Bad motor
Thanks
Jun 11, 2009 | Onkyo DV-SP404 DVD Player
Onkyo DV Sp500 DVD player set for US region but i Have DVDs from Australia - is there a code to unlock the player or do i need to purchse a new one?
icon_minipost.gifRegion code hack posted by Victor Lazlo, July 14 2003:
Steps to change Region code:
1. open setup menu (with setup key)
2. select menu point 'General' (dt. 'Allgemein')
3. select sup-menu point 'Setup-Menu Mode' (dt.Setup-Menü-Modus)
4. at 'Setup-Menu Mode' select 'basic' (dt. Einsteiger)
5. confirm 'Basic' sellection with 'Enter' key
6. now push 'Display' key at your remote control, the present regent code will be displaid
7. to change the region code push 'Condition Memory' key (COND.M) at your remote control, afterwards a number key representing the region code you want to select
8. after a successful change, the disply of ther regional code will disappear
9. if pressing the 'Disply' key again the changed regional code will be shown.
Remark: Macrovision copyguard in gerneral will be switched off after that modification
refer to:http://www.videohelp.com/dvdhacks
Jan 25, 2009 | Onkyo DV-SP500 DVD Player
Need codes that will operate my ONKYO BLUE RAY DV-BD606 player
there is no sulution as far as codes are considered for blu rays. You have to do a manual learning mode for every button.you need to buy a learning remote this is where you point both remotes at each other and press each button to learn it. unfurtunately your sony remote does not have this funtion. i hope this clarifies your problem.
Jan 10, 2009 | Sony RM-V302 Remote Control
How can I program my DVD player to accept discs from other region
I think it's possible to unlock the player to region free. I'll need more info on the DVD player. give me a few days to search for the tech details of the player
Rifaa
Nov 17, 2008 | Onkyo DV-CP704 DVD Player
Play all region dvds
Multi-Region Hack:
Press the Open button on your Onkyo DVD-player to Open the drive tray.
Using the remote press 9, 9, 9 and 9 on your remote control.
Press the 1 button on your remote control for region 1, 2 for region 2, and so on, or 9 for multi-region.
Press OK and the tray will close.
Reset the unit by powering Off and then back On again.
Jan 14, 2008 | Onkyo DV-CP704 DVD Player
Unlock procedure for Regions
1. Press Open/Close on remote control. DVD tray opens. 2. Press the following buttons in sequence: 2, 8, 1, 2. 3. TV displays "Region 2" 4. Press the Enter button on the remote until code changes to 9 5. Press the Open/Close on the remote. DVD tray closes. 6. Press Power on the remote control. Now code free...
Jan 04, 2008 | Onkyo DV-CP704 DVD Player
Onkyo DV-SP404 DVD Player Logo
Top Onkyo Televison & Video Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
