Question about Dishwashers
My whirlpool quiet partner III has green light under lock icon. It is not starting.
huuum
  • 750 Answers
SOURCE: whirlpool quiet partner III
Hello bckp,
Welcome to Fixya
If your dishwasher does not run or stops during a cycle
Is the Start/Resume indicator flashing? Opening the door or
interrupting the power stopped the cycle. Close the door and
press START/RESUME.
Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
Is the door closed tightly and latched?
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
latched.)
Is the right cycle selected? Refer to the “Cycle Selection
Charts.”
Is there power to the dishwasher? Has a household fuse
blown, or has a circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shutoff valve (if installed) turned on?
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
If the dishwasher will not fill
Check the overfill protection float that is able to move up and down
freely? Press down to release.
Let me know if any of these procedures helped you?
Huuum
Please remember to leave a rating.
Posted on Oct 05, 2008
tzweeb
  • 318 Answers
SOURCE: lock light will not go off
what you have to do is push and hold, i believe, the air/heat dry button for 5 seconds and that should change the control from lock to unlocked.
look for a "lock" symbol under the button and thats the one that you have to hold in on.
it may not be the air dry button but there will be one that does have the symbol.
Posted on Jan 04, 2009
SOURCE: i have a whirlpool quiet
I held down the heated dry button for a few seconds & it unlocked.
Posted on Jan 05, 2009
  • 530 Answers
SOURCE: whirlpool quiet partner III clean light blinking green
you have to hit heated dry and normal and toggle these till all the lights light up. then hit cancel . you are going to have to turn the power of and slide the dishwasher out and look directly behind the dishwasher you will see that a wire off of the heater is more than likly burned of repair the wire you should be fine. replug dishwasher in after wire is repaired. if you do not have a burned wire you have a bad heating element replace the element.
Posted on Apr 14, 2009
SOURCE: whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Posted on Dec 29, 2009
Lock light stays on my whirlpool quiet partner II
If pushing and holding the lock button till the light goes out doesn't work, you likely have a problem on the circuit board.
May 24, 2014 | Dishwashers
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
Whirlpool quiet partner III. Clean light keeps flashing clean.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Mar 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Lock light will not go off
Jan 04, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Padlock icon light is on
you have engaged teh lock out feature, simply push in the control lock button for 3 secs to unlock not a problem! look close at the buttons,ones marked "contol lock" in small print under it, usually the heat dry button
Nov 17, 2008 | Dishwashers
Its not working at all!
Sounds like the main wash/circulating pump is faulty
Jul 08, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
16 people viewed this question
Top Dishwashers Experts
Owen Barnes
