Question about Singer Futura Xl-400 All-In-One Sewing And Embroidery Machine
Thread breakage and bobbin tangles
When I sew and embroidery my thread breaks and bobbin tangles
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Singer Expert
  • 631 Answers
These might be caused by one issue, or by separate issues, so you need to test to identify it, but that doesn't take long.
You need to take out your user's manual and make sure that you are threading it correctly. You might also want to take your spool out of the spindle on the machine. Put the spindle that came with it for twin needle sewing on the top, and put the thread at the back of the machine in a coffee cup, then bend it around the base of the spindle, and then thread normally--exerting tension at the top and bottom when you do so, and making sure that your presser foot is UP--ALWAYS up on ANY sewing machine. That is the only time that the tension disks are spread to admit the thread, and a possible cause of your problems.
Next, review how you insert the bobbin, and make sure that the bobbin case was properly inserted, and the thread is properly threaded, with the bobbin going in the correct direction.
Also, you might want to switch to either a slightly larger needle, or a metallic needle, which is a regular needle in a range of sizes, but has a larger eye. Also, try another spool of thread to make sure the problem is NOT the thread, which might be old--even if you just bought it, it may have been sitting on a shelf.
Posted on Jan 02, 2015
dupina
  • 110 Answers
SOURCE: bunching thread underneath
When your thread is bunching at the bottom, your top tension is not tight enough, or you did not thread the machine correctly. Make sure the thread goes through the tension blades. Check your manual how to do it properly. you can check if there is any tension by pulling on the thread before threading through the eye of the the needle, and with the presser foot down. By pulling with the left hand and adjusting the tension with the right hand you should be able to feel a difference. Normal setting is between 3 and 5
Posted on Nov 13, 2007
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Posted on Sep 22, 2008
dupina
  • 110 Answers
SOURCE: singer solid state-bobbin part
Check your tension disks, with your presser foot up, and the tension dial on zero. Sometimes a piece of cotton breaks off between the tension disks and then prevents the disks to work properly. Also make sure when you thread the machine, the thread does go through the disks and over the take up lever. After you threaded the machine, before putting the thread through the eye of the needle, lower the presser foot and while pulling on the thread with your left hand, increase the tension with your right hand. Do it slowly and you should feel in difference in tension. If this is the case, your machine should work fine. Also use a ball-point needle on t shirt material. Good luck!
Posted on Nov 03, 2008
WonderTech
  • 268 Answers
SOURCE: my sewing machine keeps getting jammed when
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope this helps.
Posted on Sep 15, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
Singer futura quartet embroidery machine's bobbin area is tangling up the top thread. the top thread never breaks it just clogs up in the bobbin compartment can you help?
Be sure that when you thread the top thread, ALWAYS RAISE the presser foot. This allows the thread to seat firmly in the tension disk. Sounds like what you are experiencing is called bird nesting or thread nesting.
Jul 11, 2017 | Singer Sewing Machines
I have a futura SEQS 6000. It sews perfectly fine but when I try to embroider the thread is either unthreaded or becomes tangled with the bobbin thread and doesn't finish the design.
indicates that the needle thread is not tight enough some embroidery threads are finer than normal threads so require an increase in thread tension
Jul 09, 2016 | Sewing Machines
Singer CE250 error 88 winding bobbin
I couldn't find an explanation for error 88, but it SOUNDS to me like it's complaining because the needle isn't all the way up. Those models (had one) are VERY sensitive to that issue. As to breaking threads, that sounds like you have something in the tension disks at the top of the machine. The clear cover can be removed with one screw; remove it and gently "floss" with UNWAXED dental floss or hand embroidery floss between the disks. The presser foot MUST be UP at the time; that's the only time the disks are spread, and the reason you must ALWAYS thread your machine with the presser foot up. Most experienced users put the thread in a jar at the back of the machine away from the hoop area and thread from there, rather than the posts on the machine. Also, if you're using regular thread, make sure the notch to hold the loose end of the thread when not in use is not facing towards the thread path; it can catch in the spool and cause shredding and breakage as well as needle breakage.
You can also purchase a separate bobbin winder for under $25 at WalMart online, and frankly, I think it does a better job anyway.
Just a heads up; the cover over the tension disks snaps in place when you put it back on, but you may have to fool with it--don't panic! It WILL snap back into place, when you get it into position just right!
Sep 02, 2014 | Singer CE250 Computerized Sewing Machine
Thread bernina embroidery bobbin
The thread sensor eye is probably dirty.
Dec 26, 2017 | Bernina Sewing Machines
My thread keeps breaking when I sew
Tension is maladjusted. There is a tensioner on the front of your machine. If it is too tight (turned clockwise) the thread will break. Also could be the bobbin has tangled. Remove it and check for tangles.
Aug 18, 2012 | White Sewing Fashionaire Sewing 2380...
My Husqvarna diamond top thread keeps breaking while doing loop embroidery. It sews a couple of stitches and then you can hear when the thread breaks. Ive tried changing the needle and bobbin, and cleaning...
Hello
Primary causes of upper thread breakage:
-- misthreading: pull all the thread off and thread again, using the manual, step by step. Read each step aloud before you do it. (sounds dumb, but helps.) (And make sure you thread the takeup lever!)
-- thread has wrapped itself around a thread guide or spool pin from one of the breaks. Take the spool off the machine before rethreading.
-- bad or damaged needle. Replace with the right size for the fabric, turned correctly (backwards needles skip stitches)
-- dirty machine, especially in the bobbin case area: review cleaning instructions and do it, using brush and vacuum only
-- bad/cheap thread: should not be slubby or break easy. Try another spool.
-- top thread tension too tight. 4 is normal for most fabrics, most stitches.
Tips;
1) do a light cleaning (brush and vacuum) every day you sit down to sew.
2) replace the needle if you hear it hit metal, if you've got a really bad thread jam, if you see it deflect as you sew (for instance, sewing over the side seam on jeans when hemming). Replace every 3-8 hours of actual stitching time anyhow.
3) buy good quality thread
4) when your machine isn't sewing right, stop; take all the thread off of/out of the machine (bobbin out of bobbin case, spool off spool pin) and give it a quick cleaning. Rethread from scratch, carefully. If that doesn't fix it, do it again, then replace needle and rethread one more time, manual in hand (yah, even if you've threaded it 8 million times before). #4 is curative about 98% of the time. The other 2% often requires professional attention.
Jul 11, 2011 | Husqvarna Designer I
Brother embroidery machine broken
make sure the bobbin thread is wound and installed correctly
remove tangled thread and clean lint out from under feed plate
clean and remove shuttle to clean out area with lint brush
inspect bobbin for burs and scratches...make sure when reinstalling shuttle and bobbin that it rotates freely
hope this helps
Feb 04, 2010 | Brother SE-270D Computerized Sewing...
I am trying to do letter embroidery on my Futura 350 and I keep getting constant error messages about thread breaking even when there is no visible sign of that. Also, the bobbin thread side is bunching...
Check out your threading with "Machine setup" Tutorial under Help submenu and whether the thread tension control on the front panel is set to "E".
P.S. The error message about thread breakage appears not only when the thread is really broken but if the sewing speed is not changing smoothly (for example if design is not optimised).
Oct 06, 2008 | Singer CE-200 Quantum Futura Computerized...
Can't get Bobbin to wind properly
Verify that your thread path is correct when winding the bobbin. It has a distinctive path including a tensioner that helps your thread wind smoothly. Do not use a bobbin that is not wound smoothly because (as you already know) it could possibly break needles and damage the machine.
Brother CS 80 Sewing Machine Bobbin Rewind
Nov 09, 2017 | Kenmore 15208 Mechanical Sewing Machine
Singer Futura Xl-400 All-In-One Sewing And Embroidery Machine Logo
65 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
