Question about Severin 3986 bread maker for 220 volts-4237
Set the program but cycle does not start - Severin 3986 bread maker for 220 volts-4237
I have a LG (Trubo drum) top loader. At the moment I can select the washing functions and it is taking water into the machine. My question is why is the machine not washing, rinsing or spinning. I have...
the program is set by you and is set in the system when you press start
the program opens the tap solenoids and water flowd in until the setting or wash load is reached
at that point the level control turns off the taps and starts the wash cycle
failure to start the wash cycle indicates a program board failure as it is not progressing to the next instruction
Nov 25, 2017 | Washing Machines
I just moved into my home it has a 10yr. old timer my neighbor set the zone times.when they started perfect, but it keeps repeating the cycle over and over again till I turn it off manualy.Its irratating...
When you set an irrigation timer, you set times for every zone, however, YOU MUST SET ONLY ONE PROGRAM START TIME. If you want the system to start at 2:00 am, you put only one start time of 2:00 am. Make sure there are no other start times in any other programs, Programs B, C, or D.
That will solve your problem.
Gary
Jul 23, 2011 | Garden
Toro lawn Master ll timer (53805) keeps repeating station cycles even though I only use Program A with weekly , time starts, zone times, " 0's" on Program B & C and"...
The "start times" are often mistaken for zone start times with this model. These times are actually if you want your sprinkler to run/start more than once a day. If you only want your sprinkler to run once a day, then you should set start times number 2 and 3 to "OFF". The "OFF" setting is between 11:45pm and 12:00am as you cycle through time settings.
This is not in the manual. You're welcome!
Jul 18, 2011 | Toro Electric Trimmer
Second wash/rinse cycle for heavy loads must be engaged manually. is there a way to set it to start automatically?
Possible fault in the program controller unit. If the menu can be set up manually then select the wash/rinse or drying seperately and press start.
In most machines this is possible to override the program just in case the auto mode does not work orr the said program has errors.
Apr 19, 2011 | Washing Machines
Radio Shack 63-891 Electronic Timer: Seems I'm able to program the time at which timer turns the power on. How do you program the time at which the power goes OFF? Thanks for any help you can...
The timer has 8 programs that will run. This will give 4 ON/OFF cycles if all are used. Set program 1 as the ON time, program 2 as the OFF time. Use each odd program # as the ON time and each even program # as the off time. Do this in PROGRAM mode then switch to RUN with the upper switch set to TIMER to actually start the program running. ON will turn it ON during the OFF cycle and OFF will turn it OFF during the ON cycle.
Sep 04, 2010 | Hardware & Accessories
How do you set the clock and program to brew at a specific time?
To program the Auto On
1. Set the desired Brew-Start time.
a. Turn the FUNCTION KNOB to “Prog”.
b. Set the time you want coffee to begin
brewing by using the minute and hour
push-buttons. Follow the same instructions
you used to set the time of day, in
the To set the time section above.
2. Turn the FUNCTION knob to the “Auto On”
position. LCD will display the current time.
3. Lift and release the FLIP SWITCH. The
green indicator light will come on to remind
you that the programming function is in use.
At the programmed time, the red light will
come on as well, indicating that the brew
cycle is starting. Both lights will go off when
keep warm cycle ends.
NOTE: To reactivate the auto-on feature to
start brew cycle at the same time another day,
simply lift and release the FLIP SWITCH. The
green “auto-on” light will illuminate.
Aug 16, 2010 | Cuisinart DCC-1200 Coffee Maker
Lost directions to set timer Melnor 604 F
Melnor 604F Instructions (from Label on unit)All indicator light flashing - replace 9V battery inside unit
1. To Start - turn dial to Off and press Enter.
2. Set Time - set current time and press Enter (Yellow ring).
3. Set Start Time - Set time to start first irrigation cycle (Yellow ring) and press Enter.
4. Frequency - Set frequency of irrigation cycle; e.g., twice a day set 12 h. (red sector ring) and press Enter
5. Duration - Set duration of cycle (Green band) minutes and press Enter.
To change duration - turn dial to new duration and press enter.
To turn water on manually - Turn dial to ON position, water will turn off in 30 min.
Do not press enter in the OFF position as the unit will clear program. You will have to reprogram unit
via steps 2-5 above.
Jan 31, 2010 | GARDENA Melnor/Gardena 101 Flowmeter Water...
Coffee too weak what are normal knob settings
Function Knob For setting time of day, and auto on and auto off times. a. Auto On The Auto On feature is used to program the start time of the brew cycle. The auto on time can be set for any time, day or night. The “PM” indicator is displayed on the LCD for nighttime program times. b. Auto Off The Auto Off feature is used to shut off the coffeemaker at a preset time, anywhere from 0 to 4 hours. c. Program Set The Program Set function is used to set the time for the Auto On function. d. Brew The brew function is used to start the brew cycle directly. e. Clock Set Used to program the time of day. f. Audible Tone (not shown) The Brew Central™ Coffeemaker is equipped with an audible tone which will sound 5 times when the coffee has completed brewing (coffee will continue to stream from the filter for a few seconds after tone).
If yours is a Vienna Digital Coffee Maker please click the link below. it is manual of Coffee Maker, it would be helpful to in the future.. http://www.cerinicoffee.com/Saeco_User_manuals_free.asp
Jan 20, 2010 | Saeco Vienna Digital Coffee Maker,...
Need assistance on how to program the timer for my cuisanart 12 cup coffee maker
The manual can be found here:
http://www.cuisinart.com/share/man/25_man.pdf
Mar 24, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Severin 3986 bread maker for 220 volts-4237 Logo
26 people viewed this question
Top Severin Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Severin Kitchen Appliances - Other Expert? Answer questions, earn points and help others
