Question about Bosch BUC11700UC Cyclone Jet Bagless Upright Vacuum
My vacuum cleaner overheats
Overheats and stops
Lg vacuum cleaner overheats and shuts off.what is a problem?
How to Fix Vacuum Cleaner
With the link that i have attached i sure do hope that you will solve your overheating problems and others just in case. There are diagrammatic instructions also. Hope the information is useful and helpful.
Sep 17, 2016 | LG Vacuums
Stopped working while vacuuming??
Filters might be clogged which will overheat motor. Clean and replace them frequently
Jan 12, 2014 | Hoover UH70120 WindTunnel TSeries Rewind...
Vacuum cleaner stops
The motor has a thermal reset built in. If the filters need replaced the motor can overheat. Filters should be replaced frequently to insure proper cleaning suction and motor life
Jan 04, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson dc11 has just stopped after sucking space saver bags
Hi Philip,
Your DC11 is equipped with a safety device which shuts the cleaner down if it starts to overheat. It's likely that this is what occurred, as there may not have been enough airflow through the cleaner to keep the motor cool. If you unplug the cleaner and leave it to cool down for at least an hour, you should find it will work again.
If the cleaner still won't run after this time, get in touch with us directly so we can provide further assistance - you can call us free on 0800 298 0298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Oct 31, 2011 | Dyson DC11 All Floors Bagless Canister...
Dyson cylinder i was sucking a vacuum space saver bag and my vacuum just stopped
Hi Philip,
Kind regards,
Jack
Vacuum cleaner automatically turned on by itself. fine black dust blown out through the filter.
This sounds like an overheat condition, Inspect for plugged air flow issue. the motor will burn up, if no heat based interrupt stopped the unit. My bet is that something is plugging the machine's air flow.
Jun 04, 2011 | Kenmore 25512/ 25513 Progressive Canister...
The vacuum stopped working while i was using it...did all the troubleshooting tips.. still not working.
Sometimes the vacuum will overheat, if this happens the vacuum will shut down to protect it from damage.
Unplug the vacuum, and let it sit unused 30 minutes.
Please let me know if this has solved your problem.
Mar 11, 2011 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Motor and Lights stopped suddenly after vacuuming the stairs.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19809&thid=745467
Motor and Lights stopped suddenly after vacuuming...
Posted by Brigham81 on Jul 05, 2008
I was vacuuming the stairs, and all of a sudden the light went out and the motor stopped. Is it possible to overheat it, or blow a fuse? Thanks, Brigham
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL2200 Bagged Upright Vacuum. It sounds to me that when the lights go out and it stops working that the motor is bad that you would have to replace the motor. It is still cheaper to replace the motor than to purchase a new vacuum. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 05, 2008 | Oreck XL2200 Bagged Upright Vacuum
Bosch BUC11700UC Cyclone Jet Bagless Upright Vacuum Logo
22 people viewed this question
Top Bosch Vacuums Experts
Cleverer2
Billy Detlefsen
ray gallant
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
