Question about Acer Aspire 3050-1733 Notebook
The screw on the bathroom door has been strippped how do I get the door off
    Problem Solver:
  • 6 Answers
If you have a hardware store or a place where you buy tools go and buy a set of easy outs these will after screw is drilled out and then the tool is tapped onto the the hole drilled will bite and allow you to remove the screw
Posted on Jul 25, 2014
Bathroom door kwik Set is locked on the inside by child. How do you unlock the door from the out side. There is only a hole NO Key to unlock door.
usually on a quik set there is a little hole right in the center of the door knob. take something small around as a coat hanger and insert it in the hole. push it and it should unlock. Other door knobs have a hole just to the left or right of the know. these you can unlock with a real small screw driver
Apr 08, 2011 | Home
A Bryant 3 way independent rocker switch with red, black and white wires for 3 lights in bathroom one switch not working can i replace it with a Broan Nutone P66V three function control
397bfdd.jpgLeviton triple switch
fe442eb.jpgNutone P66V
Nutone looks like an ordinary three-switch combo being marketed as a bathroom 'fan switch.'
The screws on the device would tell the story.
Look at the Leviton screws:
The switch has dark-colored screw on one side >> the hot from breaker always connects to dark screws.
Other side of switch has 3 silver-colored screws, but these can be brass colored screws > the wires to fan light and heater connect to each of these screws.
Most likely the Nutone switch is identical to the Leviton
I say this because the descriptor on Amazon describes it as a 'fan' switch.
It's being marketed as a bathroom fan-light combo switch >>> so it looks like an ordinary three-combo switch
Oct 28, 2010 | Broan-NuTone P66V Fan Control Switch
It is impossible to align the blade of a screwdriver with the slot on the head of the adjusting screw on the bobbin. Is there a special tool?
Yes, use small jewler screwdrivers. but be careful. The screws are soft metal and will easily stripp
Jun 26, 2010 | Consew 226R-1
SCREWS NEEDED FOR THE BRAKES OF 2001 FORD TAURUS SE. i HAD A MECHANIC STRIPP ONE OF THE 2 SCREWS IN MY CALIPERS. NOW THE SCREW THT WAS STRIPPED DOES NOT LOOK LIKE THE ONES I CAN PICK UP FROM AUTO ZONE THE...
Easiest fix is to replace the caliper. There only about 35 $ at autozone and as important as brakes are its best not to try and sub the wrong parts on something that stops your car. Doesn't sound like I would use that mechanic if he did stuff like that anyway.
Feb 22, 2010 | 2001 Ford Taurus
I have to fit this washer through a door smaller than the machine. How do I take the front panel and door off so it fits through this bathroom's door?
I would suggest it would be much more simple to remove the bathroom door, as it is not a straight forward job to remove the washer front panel
Carefully check the measurements of the opening with the bathroom door removed.
Hope this assists you.
Dec 14, 2009 | Kenmore 44042 Front Load Washer
Glides attached to glass doors are no good.
Well, if the screw is rusted too much to remove, you have to drill it out...
Nov 30, 2009 | Maax Home
Bathroom doorknob stuck in locked position.
I will tell you how to fix 'em. Open the Door Knob with a screw driver, gently pull aart the two knobs once open, then look for a long sliding rod, pull one knob away, twist the Knob untlil it is in unlock position, put them back together to test if it slips properly. If it does not, there is something preventing the rod from rotating freely. Try to ensure it rotates freely. Then screw back together :)
Nov 18, 2009 | Hardware & Accessories
I have a bathroom cabinet door that came off and now I can't get the screws to stay in as the inside of the cabinet is so damaged and wood filler does not work , even glue will not hold this door back on...
Buy a dowel pin the size of the hole in the cabnet then use carpenters glue to glue the dowel pin in place where the old hole was make sure it is a good tight fit. Next saw off the dowel pin and let set over night then drill a strating hole in the dowel pin and reinstall the door works like a chanp. Hope this helps.
Sep 28, 2009 | Duravit 6130 Starck 1.2.3 Vanity Unit w/ 2...
Acer Aspire 3050-1733 Notebook Logo
19 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
