Question about Samsung Refrigerators
Need to know where cover-w_harness conv door goes on Samsung refigerator
Found it laying on floor dont know where it came off of
3 Suggested Answers
SilentSno
  • 9 Answers
SOURCE: unable to install harness after washing
You might be able to contact Cosco for a manual or diagrams of where everything goes, there info is: Consumer Relations Department at 1-800-544-1108 Hours of operation Monday ? Thursday 7:00 AM to 6:00 PM EST and 7:00 AM to 4:30 PM EST on Friday.
Posted on Jul 19, 2007
SOURCE: The door interlock on my samsung washing machine
I am having the same problem. Did you find an answer to this?
Posted on Oct 16, 2011
2000 Chrysler Sebring Conv. Side mirrors and a/c not working. What would cause this
Side mirrors may be a wiring issue possibly near the driver door area where it would come from the door into the A pillar to under the dash,sometimes from age and door operation the wires break inside that harness.AC issue would need to be checked by a certified AC tech to check for leaks and operation,could also be a electrical issue or low on freon from a leak.
May 04, 2014 | 2000 Chrysler-03 Sebring 2 Door 00-01...
Power windows mercury mountaineer
wiring harness should be under the left side. covers on the floor area , next to the seats....... in the post area, that your front door locks into , and the hinge area on the rear door..... wiring is wrapped in main harness....
Apr 12, 2014 | 2000 Mercury Mountaineer
I am getting no power to my back passenger side door. The speakers and power windows dont work
there is a wiring harness that goes from the frame to the door its by the hinges. there is a rubber boot that covers them. pull it back and check for cracked and broken wires. this is the most possible place to break. let me know we can go from there
Jun 21, 2010 | Cars & Trucks
I need to know how to replace the side mirror on my 2003 Chevy Tahoe. It is a heated mirror and I need to replace the whole unit. I especially need to know how to take off the door panel to unhook the old...
Well, technically you dont have to remove the door panel to remove the outside door mirror. At the top of the door panel, at the front of the door, there is a triangle shaped plastic cover. It's held in place with push clips, so pull that cover off and remove the foam insulation and you'll be able to access the 3 nuts that hold the mirror to the door. The only potential problem could be in unplugging the wiring harness. I use a hooked pick to pull up the harness to unplug it.
Dec 30, 2009 | 2003 Chevrolet Tahoe
Stalling and misfiring once it gets hot
You didn't say the year? But check the coil. Frankster016
Oct 19, 2008 | 1998 Dodge Grand Caravan
Sabbath Setting
I just bought the SamsungRF267AB bottom freezer refrigerator.  Amoung the features that must be disabled for shabbos are the lights, motor cuttoff and inside panel indicators.  On most refrigerators there is a swich that you can tape in the depressed mode that will trick the unit into thinking the door is still closed.  With this unit it's magnetic.  you need to place a magnet on the top of the door frame to make the refigerator think the door is still closed.  I hope this helps.
Sep 15, 2008 | KitchenAid Architect KBRA20ERSS Bottom...
Blend door
ok first put you front seat down and back raise steering wheel . now lay on you back with you head in the drivers floor board. look up see 2 screws remove them and the panel they hold on . look to left main wire harness needs to be moved to the right , up and behind it is th blend actuator 7/32 socket to remove it then manually turn the white peg , total labor 30 min
Aug 28, 2008 | 2005 Chevrolet Impala
Power windows on a 1994 ford taurus
what you could do is remove the door card and bypass the switch and put the windows up the windows work from the drivers door ie all the power goes through the window switch first then to all other switches like a set of jump leads also check were the wires go to the door you might have a broken wire check the colour of the power and trace it back from the fuse board to the drivers switch
Mar 15, 2008 | Baby Gear
Refrigerators Logo
23 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
