Question about LG RC897T DVD Recorder/VCR Combo
Recorder is LG LRY-517 (2005) Recent months records RW but not Sony+R X16. Does not even play the Sony disc recorded and finalized on another unit. When we put in the permanent Sony blank the screen indicates that it is a RW and asks if we want to intialize it. Some older discs I've used with other brands at 1 -8 X play but I don't think record. Would like a recommendation for DVD Disc brands. -R or +R?
2 Suggested Answers
RixsFixes
  • 2200 Answers
SOURCE: Lg dvd rw recording problems
Hi
You might like to know that this recorder works well with DVD+R, DVD-R and DVD-RW but is known to not work well with DVD+RW. This is likely to be the main cause of your problem if you experience these problems and find it happens mostly with DVD+RW.
If the problem occurs across all formats a DVD cleaning disk should help the problem.
Hope this helps. Please do rate my answer. Thanks.
Posted on Jul 26, 2009
My Magnavox Digital Disc Recorder & Video Cassette Recorder will not play DVD-RW discs. How can I solve this problem or get a replacement unit.
It claims to play -RWs finalized in DVD-VIDEO format, not VR. If a disc is recorded/finalized on a different recorder, not all players can play it. This is the price we pay for the convenience of the digital system.
Feb 11, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
DVD Recorder is ruining the DVDs
Here is the link to the manual for LG DR1F9H
read pages 33&34
you may be using wrong
disc or wrong mode
Dec 13, 2007 | Televison & Video
When I burn a DVD (R- or R+) on a Sony RDR-GX300 it burns the DVD which plays on that unit only. If I try to play the DVD burned on Sony RDR-GX300 on any other brand or any other Sony DVD player or even on...
On That Type Of DVD Recorder,( RW,R-R+). You Will Have To Finalize The Disk. Finalizing is Necessary When Playing On Any Equipment Other Than This Recorder.Even IF Your Other DVD Equipment IS ( VR ) Format Compatible You Still Need To Finalize The Disk. After Finalizing,You Cannot Edit or Record on The Disk,Make Sure It's In Video Mode.
Aug 11, 2011 | Sony RDR-GX300 DVD Recorder
After warranty time expires (2yearsd) my LG LRY-517 DVD combo recorder/player start to make randomly disc reading errors. During half year things has going worse. Now the situation is that it does not play...
Use lens cleaner disk to run many times. It cleans the lens and also runs cd on the disk which eventually will get rid of moisture on the circuits and restore your dvd recorder on the LG unit.
Mar 11, 2011 | Televison & Video
When i record why cant i play on another dvd player
if using a dvd-r/rw, you will need to finalize the disc to use on other players, but not on the recording unit.
not applicable when using dvd+r/rw
Mar 22, 2010 | LG DR275 Recorder
HOW DO YOU BURN A DVD ON A SONY DVD RECORDER RDR
Make sure your Sony input signal is on L1 or L3 (the inputs in back of recorder) or on L2 which is for inputs for cameras(located in front).Once you get a signal, you're where you need to be. Choose your recording mode for recording speed (pull down the flap on the remote control for this button and also the input button).
Choose from between1 hour and six hours. To archive really important stuff, stick with the first 3 speeds. TV recording can be on 3, 4 or 6 hour mode.
Push the record/pause button once. This will put the recorder into the record/pause mode and then it awaits you pushing it again to start recording immediately. Just pushing record will force the machine into a 3 to five second delay before actually recording anything so you might mess up and miss the first few seconds of your input. Suggest you use a dvr-rw or dvd+rw to practice on.
When your recording is done, just push the pause again. It stops recording but allows you to add more on to the first recording without starting a new chapter if you want. Just continue to release the pause button to continue.
If you are satisfied that you are finished, then push the pause button to stop recording. Wait for the info to be written(flashing message on screen). When it stops, you may play the dvd.
Notice- since the dvd has not been FINALIZED, you may only play it back on this unit without finalizing. It will not play on other dvd players unless you finalize it first.
To finalize, look on remote for the TOOL button. Press it once. Now push DISC INFO once. Use arrow keys and enter button on remote for the following. Scroll down to FINALIZE and press enter.
Use arrow keys to scroll to OK. push the ENTER button. Finalizing should take between 30 seconds and 2 minutes.
Warning- if titles or chapters are to typed in, it must be done BEFORE finalizing. Finalizing afterwards cannot be done.
Erasing can be done in part or all if using an RW+ or RW- disc
Dave
azsnoopy1@cox.net
Nov 19, 2009 | Sony RDR-GX300 DVD Recorder
Hi
Jul 26, 2009 | LG Televison & Video
Not reading pre-recorded dvd's and ocassionally not re-wrtten dvds
Over recent months my recorder has stopped reading pre-recorded disc's and more requently re-writer disc's. I had thought that the region had some how been altered, but not too sure now. Is there a way of checking? Or is there a problem with the laser block. I have stripped the machine down and thoroughly cleaned (but no dust found) and no loose parts. I have reset to manufacture default but this hasn't helped.
postsolution.gif Post Solution addwq.gif Work Queue -->sameproblem.gif Have the same problem? --> Have the same problem? Click Here
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK 1 Other User Has The Same Problem Comment by Guest, posted on Dec 19, 2007 DVDR70-051 recorder functions generally becoming more and more erratic. DVD-RW discs I have recorded sometimes say 'disc error' sometimes 'no disc' sometimes start ok but cycles round and round for 5 - 10 mins before stopping, sometimes goes straight into play at last position, won't stop back in menu just goes straight to stndby. Factory reset dosn't help. Wont play pre-recorded discs without going into menu and messing around. It seems to damage or not record RW discs properly a lot of the time. Not even sure if it's resetting to factory settings properly.
Oct 28, 2007 | Philips DVDR70 DVD Recorder
Samsung R155 Recording from VHS Issues
The reason why you are having this problem is because you haven't finalized the disc. In able for you to play that Burned DVD that you have you need to Finalized the disc. Finalizing a recordable optical disc means writing the disc's lead-in (the Table of Contents or TOC) and lead-out information (blank data that fills up the unused space at the end of the disc) so that a DVD player will know where the various tracks begin and end. Without the TOC, a conventional DVD player will not be able to read the contents of the disc. Once the disc is finalized, no more information can be written to it. Finalizing takes about two or three minutes. To finalize a DVD-RW/DVD-R: 1. Press the Menu button with the disc stopped. 2. Select Disc Manager and press Enter or the right arrow. 3. Select Disc Finalize and press Enter or the right arrow. You will be asked twice if you are sure that you want to finalize the disc. Select Yes and press Enter. Once the disc is finalized, you cannot delete entries from the record list. After being finalized, the DVD-R/DVD-RW (video mode) operates in the same manner as a DVD-Video. Recorded discs must be finalized in order to play back in non-Samsung DVD players. A DVD-RW disc that has been recorded by DAO (disk-at-once mode) in a PC cannot be unfinalized. A DVD-RW disc that has been recorded in Video Mode on a non-Samsung recorder cannot be unfinalized by a Samsung recorder. A DVD-R disc cannot be unfinalized. Note: Finalization does not apply to DVD-RAM. If you cannot finalize a DVD-R or DVD-RW disc, make sure that Disc Protection is turned off. If you are still having difficulty, you may try calling technical support of SAMSUNG. Note: Do not turn the recorder off while it is finalizing the disc. Data on the disc will be damaged if the finalization process is interrupted.
Sep 17, 2007 | Samsung DVD-R155
LG RC897T DVD Recorder/VCR Combo Logo
14 people viewed this question
Computer Repairing
Computer Repairing
