Question about Nordic Track Incline Trainer X9i Interactive
I CALIBRATED ELEVATION AND IT DID NOT WORK
THE INCLINE NEVER CALIBRATED BACK TO ORIGINAL POSITION
Incline not moving
Try to do the following hope it will solve the problem.
if its doesn't solve the problem then the the incline motor or the control panel is faulty.
HOW TO USE THE SETTINGS MODE T
he console features a settings mode that allows you to connect your incline trainer to your own wireless network and to log in to your iFit Live account. The settings mode also allows you to turn on and turn off the display demo mode. You may also be able to select the unit of measurement.
Select the settings mode.
Insert the key into the console . Next, select the start menu. Then, press the i button in the lower right corner of the screen to select the settings mode.
Select the maintenance mode.
Press the Maintenance button in the lower right corner of the screen to enter the maintenance mode.
Calibrate the incline system of the incline trainer.
Press the Calibrate Incline button. The incline trainer will automatically rise to the maximum incline level, lower to the minimum incline level and then return to the starting position. This will recalibrate the incline system. Press the Begin button to calibrate the incline system or the Cancel button to return to the maintenance mode. When the incline system is calibrated, press the Back button. IMPORTANT: Keep pets, feet, and other objects away from the incline trainer while the incline is calibrating. In an emergency, pull the key from the console to stop the incline calibration.
Restore factory defaults.
If necessary, press the Restore Defaults button to reset the firmware to the original factory firmware. This will erase all firmware updates that you have downloaded. Press the Begin button to restore the default firmware or the Cancel button to return to the maintenance mode. When the restoration is complete, the words PLEASE CYCLE POWER will appear in the grey box. Press the power switch into the off position. Wait for several seconds, and then press the power switch into the reset position. It may take a minute for the console to be ready for use.
Exit the maintenance mode.
To exit the maintenance mode, press the Back button repeatedly.
www.electro-medical.blogspot.com
Aug 31, 2015 | Nordic Track NordicTrack X7i Incline...
Sole F63 Treadmill Incline Error
http://electro-medical.blogspot.com/. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience
Jun 26, 2014 | Sole Fitness F63 Treadmill
E07 keeps coming up on my display for my carl lewis tredmill does anybody know what the problem is
follow the 2 options and fix it. However RUN the software calibration for easy troubleshooting and fix it. God bless youVersion:1.0 StartHTML:0000000168 EndHTML:0000006037 StartFragment:0000000468 EndFragment:0000006020
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Version:1.0 StartHTML:0000000168 EndHTML:0000003648 StartFragment:0000000468 EndFragment:0000003631
The Steps for Newer Style Console Calibration
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Mar 27, 2013 | Exercise & Fitness
E7 error message
see this steps and fix it. God bless you
ERROR CODE # 7
2)Alternative:
Nov 27, 2012 | Exercise & Fitness
My treadmill is locked in the max incline position and controls won't respond
Run the software calibration for diagnose, troubleshooting, and fix it.
2) clean the gear and shaft from elevation motor.
3) adjust the POT for better improvement.
see the diagram
God bless you
Jul 27, 2012 | Exercise & Fitness
Healthstream Elation HS 2200T - E3 code - incline not working
1) Lube the shaft and gear from elevation motor
2) Tight the connection motor very well.
3) Adjust the potentiomenter from elevation motor
4) Measure the voltage input.
5) Try to RUN the software calibration for diagnose, and troubleshooting see the block diagram.
God bless you
Jun 13, 2012 | Exercise & Fitness
Endurance treadmill TF3i stuck in full incline position ...removed cover and incline motor very very hot...any ideas? Thank you
Dear SSIR:
The motor can be faulty. 2) See my personal tips for HELP 3) adjust the potentiomenter of elevation motor 3) Lube the gear and bar very well. 4) Mother main board can be faulty.
sincerely. God bless you
May 01, 2012 | Exercise & Fitness
Proselect pace master treadmill incline does not work
Dear Sir:
1) You must test the Main motor board, RUN the software calibration for easy diagnose and troubleshooting.
2) The elevation motor has a Potentiomente adjust. 3) The gear from elevation motor can be LUBE. However RUN the s. calibration.
3) Another machine has relais for down and up, you must clean the relais contact, if the board has relais.
Apr 23, 2012 | Exercise & Fitness
Efx 546 in diagnostics mode, flashes 255 and then real position of incline. getting error 42 when first turning machine on.
ok
elevation needs calibration or stuck
open--put elevation manually lowest and turn the unit on and bring the elevation lowest by pressing el down key
put it together clear it and start elevation will come in the starting position clear it and use it 225 is out of range of elevation
also check elevation fuse if it is good and secure
Nov 20, 2010 | Precor EFX 546i Elliptical Version 4
Nordic Track Incline Trainer X9i Interactive Logo
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
