Question about Yamaha RX-V595A Receiver
Yamaha RX-V595A tuns off automatically
When I press the STANDBY/ON button, the unit turns on for a split secnd and the automatically turns off.  I have checked all the speaker connections and they look good.  I have also unplugged the received for 30 seconds and made sure the impedence selector is set accordingly but this doesn't work either.
Any suggestions would be appreciated.
  • Samfarr Jan 21, 2008
    I have the same problem. My amp was in storage for several years and I fired it up the other night for the first time. It immediately shut down. I checked the impedence selector on the back and tried it in the up and down postion with the speakers wired to the amp. No change. Any ideas would be appreciated.
  • Anonymous Oct 24, 2008
    Same here. When it gets loud it shuts off at the exact same point in a movie. I will go back and right when the volume gets really loud it just shuts down.
This was happening to mine also, all of a sudden. This solution came from the owners manual. Sure enough, the impedance selector was stuck in the middle , between 4 and 8 ohms....I also, made sure the speaker wires were not touching each other at the splice. Problem fixed.
B
The unit fails to turn on when
STANDBY/ON is pressed, or set in
the standby mode suddenly soon
after the power has been turned on.
The power cord is not plugged in or the
plug is not completely inserted.
The IMPEDANCE SELECTOR switch
on the rear panel is not fully set to the
upper or lower end.
Firmly plug in the power cord.
Set the switch fully to the upper or
lower end when the unit is in the
standby mode.
Posted on Nov 15, 2007
My Yamaha Rx a710 is stuck in stand by mode can't get any thing to work how do I do a hard re set on this receiver
  1. Set the unit to Standby Mode using the Power button. ...
  2. While holding down Straight button, hit the Power button. ...
  3. Use the Program Selector buttons to navigate to INIT-CANCEL and press the Straight button to select INIT-ALL.
  4. Turn off the unit using the Power button
Oct 20, 2016 | Yamaha Audio Players & Recorders
Yamaha receiver shuts off automatically after two seconds. Changing Inpedence switch has no impact.
Does disconnecting all the speakers make a difference? If so, troubleshoot the short out to a speaker.
If not, it's due for a trip to the ER.
Dec 31, 2010 | Yamaha RX-V595A Receiver
Yamaha RX-V595a receiver shuts off 2 seconds after its powered on
The first thing called out is the impedance switch on the back is not fully in one or the other position. Cycle the switch back and forth to make sure it will 'read' each setting, then turn it on.
Also make sure you if you have anything connected to its convenience outlets that they are not drawing more current than is allowed.
Did you buy it used or new?
Mar 09, 2010 | Yamaha RX-V595A Receiver
How do I turn On/Off my RX 596 reciever with my Yamaha remote ?
Press the Standby/On button on the remote or on the receiver (right below the Yamaha logo) to stop the audio output and display. The RX-596 goes into a low power standby mode when not in use; this allows it to respond to the remote when you press the buttons. If you want the receiver's power use to go to zero, you need to unplug it from the outlet. (You could also use a switched surge protector and push the switch to off.)
See page 9 (page 11 in the PDF) in the manual for the details on the On/Standby switch. The manual is available here: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000057561.pdf . The page is also available here: https://www.manualslib.com/manual/197512/Yamaha-Rx-596.html?page=11#manual .
I hope this helps.
Jun 28, 2017 | Yamaha Audio Players & Recorders
Reciever won't switch back on
you need to take it to the nearest yamaha service centre. Unit could have had a surge or blown a fuse.
Mar 25, 2008 | Yamaha RX-V595A Receiver
Yamaha rx-v595a problem with dts signal
the unit must be switched to digital in order for the auto function to work, then it will automatically select dts or dolby digital. youn need to check your digital feed from the dvd player.
Dec 28, 2007 | Yamaha RX-V595A Receiver
Yamaha RX-V595A Receiver Logo
684 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
