Question about Actiontec M1000 Qwest Century Link Dsl Modem Router & 2wire Wireless Adapter
How to enable usb port on qwest q1000 modem/router
Want to access usb from networked computers
2 Suggested Answers
SOURCE: two modems
easier to just get a wireless usb adaptor works fine. :)
Posted on Jun 19, 2008
Where can I download a manual for a Qwest Q1000 DSL router?
The technical page for this device can be found at:
Q1000 Actiontec Modems
It doesn't look like they provide a PDF of the entire user guide but links on this page (in 'Wi-Fi', 'Utilities', 'Advanced' and elsewhere) can guide you for more complex topics (such as port forwarding, etc.).
The Setup Guide can be found at:
CenturyLink Internet Manual English ZAM
May the Stars Shine Upon Your Path!
May 30, 2015 | Computers & Internet
How do I reset the password and User ID on an Q1000 Actiontec Modem?
Things You'll Need
• Q1000 Qwest Wireless N VDSL Modem Router
• Computer connected to the Modem
Step1 On any computer that is
connected to the Internet, type http://192.168.0.1 in the web
browser window and then press Enter.
Step2 Click Utilities.
Step3 elect "Restore Defaults" from the menu on the left.
Step4 Click the last restore button that follows
"Restore Modem to Factory Default State
The manufacturers web site with this advice is here.
http://www.actiontec.com/products/datasheets/Q1000QwFactoryDefaultsHowto.pdf
Sep 24, 2014 | Actiontec Qwest Model Q1000 4-port...
Wireless network no longer visible
The SSID field was turned off. Turn it back on.
Feb 22, 2014 | Actiontec Q1000 4-port Gigabit Wireless N...
Actiontec q1000 setup
Here is a general setup for this device, If further details are needed it is recommended to check the manual.
open a web browser on a computer connected to the device via a network cable (not wireless)
in the address bar type in 192.168.0.1
you will then need to login
the defaults are admin / admin for username and password.
You should then see the main configuration screen.
You may need to contact your ISP if special settings such as static ip, dns, or MAC address is needed.
Without knowing what exactly you need to setup, I would recommend going through each section and carefully reading what is on each page. Then modify ONLY those areas that you need.
Dec 28, 2013 | Actiontec Qwest Model Q1000 4-port...
I am trying to connect a D-Link DIR-628 router to a Qwest Actiontec GT-701-WG DSL modem. My computer OS is windows XP-service pack 3. The modem works fine when connected directly to the computer and...
Plug your internet into the router then, the router to the computer. Go to your network settings and run the network setup. This will change the settings in windows to except the router into the network. You may have to restart the computer. This should give you internet access to your computer through your router.
Jan 27, 2011 | D-Link Computers & Internet
My linksys w/2phone ports cannot hook up with the ethernet
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Kodak ESP 7 WIFI problems
The ACTIONTEC GT124, M1000 and PK5000 Routers are not compatible with wireless-enabled all-in-one printers. These routers cannot connect to your all-in-one printer because they do not support the multicast protocol. Contact your router supplier for additional assistance and to determine if your router will be able to support the muticast protocol in the future.
Feb 26, 2010 | Kodak ESP9 All-in-One w/USB Cable & 4x6...
Wireless Router Configuration
Double check that your modem has more than just a usb port on it. There should be a network port on it too. Simply connect a network cable for the modem to the WAN port on the router and then from the router to the computer.
I have never seen a modem with only usb on it. Let me know if this helps.
Oct 03, 2008 | NetGear DG834G Router
Networking
You actually have a couple of issues here. Fix these in this order. 1.) Login to router and turn off wireless (if you're not wanting to use wireless) 2.) Connect the ADSL modem CAT5 port to the WAN port of the Belkin router. 3.) Login to router and turn on NAT and make sure DHCP is enabled. 4.) On your Windows machine turn on DHCP under the network settings. This should allow your connection to be setup automatically and stop wireless access on the Belkin router. Let me know if you need more help. JC
Jun 24, 2006 | Belkin Wireless (F5D7130) 802.11g/b...
Actiontec M1000 Qwest Century Link Dsl Modem Router & 2wire Wireless Adapter Logo
51 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
