Question about Motorola Mobility Bluetooth Hands Free Headset Wireless Headset
Pairing H-70 to pair with BB Q5
Big Ble / iphone 5s pairing
clear any past stored passwords. reset unit and put into discovery mode. Usually holding the pair button for a few seconds puts the LED blue into fast flashing - discvery mode
Apr 09, 2014 | Brookstone Big Blue Live Wireless...
PAIRING PARROT TO BLACKBERRY 9320
To pair your BB to parrot go to connections
check whether the Bluetooth is ONthe search for devicesand when the name of the system comes..pair with the device.
Thank You.
Dec 26, 2012 | Parrot SA Parrot Ck3100 Lcd Handsfree...
How to pair my bb curve to uniden BT112 bkuetooth
You need to put the bluetooth into pairing mode.
Jun 26, 2012 | Blackberry Curve 8350i
tell the person with bt112 bluetooth to pair with you.. their will be a thing that pops up on your phone that says enter pair code just put 1234
I can not pair my headset HS820 with my BB 8520. My BB does not recognize it...what can i do?
First Ensure that your Blackberry 8520 is in discoverable mode (Settings>Options>Bluetooth) once in Bluetooth hit Menu (the button to the left of trackpad, Select options to turn Discoverable on, once you have done that ensure your bluetooth is in Pairing mode (solid blue light, except Plantronics brand which will alternate Red and blue lights) then have the device search and it should find it, select connect, then enter the headset (typically 0000 unless Bluetooth owners manual says otherwise) and it should pair just fine from there
Hope This Helps!
William
Sep 20, 2010 | Cell Phones
Blackberry storm will not syncronise with 2006 XJ6
If I remember rightly doesn't the Jaguar system give you a code you have to type into your BB? I run an earlier model than yours, but when I get a loaner, I seem to remember that you have to do this. So, go to pairing mode, get the code and tap that into the BB when it asks for the code. I have had no problem pairing my BB with any of the new Jags from X type, S type and XJ.
Jul 31, 2009 | 2006 Jaguar XJ8
Pairing blackberry with MEX-BT3700U
Place MEX BT in the search mode (Hold down BT button until BT logo begins to flash) Put BB in BT search mode, When BB will identify the BT device as "XPLOD" when prompted enter on BB "0000" and enjoy.
Mar 24, 2009 | Sony Car Audio & Video
Wont' pair with BB 8830
I had the same problem. Here is what you do:
When your headset is off push the multifunction (on/off) button and keep it pressed until the blue light turns solid blue (i.e. is not blinking). Now you can pair it and your BB will detect it. If you do not wait until the light remains lit it will not happen. Unfortunately this point is not well emphasized in the instructions of use for the device.
Enjoy
Dec 07, 2008 | Samsung WEP200 Headset
RIM 8310 Curve to desktop bluetooth "connection" problem
It seems is something related to this:
http://banagale.com/setting-up-bluetooth-sync-in-windows-xp-using-blackberry-desktop-manager-on-a-dell-d630.htm
I did not try yet, check it if you can an post the results of your tests.
- Ivano from Italy -
Jun 12, 2008 | RIM BlackBerry Curve 8310 Smartphone
Motorola Mobility Bluetooth Hands Free Headset Wireless Headset Logo
15 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
