Question about Sabre Televison & Video
Sabre tv power outage power came back on now yellow light flashing tv won't come on
ikebert
  • 47 Answers
SOURCE: After a momentary power outage Panasonic LCD TV has a flashing red light and will not turn on.
Try using a different outlet, the outlet or the tv may have been damaged in the surge. In the case of the tv contact the manufacturer and see if it's still under warranty. There may also be a way to 'reset' the tv by holding the power button down, try looking in the manual or calling customer support. In the future use a surge protector, many of today's electronics are still sensitive to power surges, older tv's were more resilliant than today's in this regard.
Posted on May 30, 2009
micromatikal
  • 2777 Answers
SOURCE: Sabre modet # LCT260BKA will
Unfortunately there is no master reset button or relay switch. Does it turn on at all, any lights or anything? Have you attempted to unplug it from the power source, let it sit 2 minutes, and replug it in? Are you certain the outlet is not the culprit? Do you have other things plugged into the same outlet that function fine?
Thanks, let me know and I can help further
Tim
Posted on Sep 21, 2010
SOURCE: Just had a power outage
I hate to tell you that this happened to me last week and mine is 18 months old. after calling toshiba and going through all troubleshooting, nothing worked. they referred me to a service center near me and the repair is $466!!!!! I have lots of power outages so they can seriously damage a tv (the motherboard to be specific). Mine is the 42 inch 535U. get a surge protector for your cable and ask your electric company to install a power shield on the meter or a surge arrester.. good luck.
Posted on Nov 15, 2010
  • 8457 Answers
SOURCE: power went off and now red light is flashing on tv
Tries tv unplug,replug it back like an hour later.That way to reset the tv back to the factory setting.The tv should work now,if not than the tv power supply board is problems and the causes.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Nov 28, 2010
  • 62 Answers
SOURCE: green light is flashing tv will not turn on held
Your TV has a bad inverter more than likely. There is nothing you can do to fix your TV except replace the part that is damaged. I recommend contacting Sharp and seeing if the TV is still under warranty. Most of the time they can dispatch a technician to replace the part for you. If you have to replace the part yourself then I recommend simply buying a new 32" TV since the cost of repair and parts will easily be in the three hundred dollar range.
Posted on Feb 28, 2011
Green light flashing won't turn on
Likely has bad 1000UF capacitors on DM module. this will prevent rebooting.
Apr 08, 2014 | Mitsubishi WS-65611 65" Rear Projection...
The yellow LED on my Toshiba 32CV510U flash all the time and TV won't turn on
check some leak or bulged capacitors at the power supply board then replace it.
Oct 02, 2012 | Toshiba 32CV510U LCD TV
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Sabre 37in multisystem TV has blinking yellow light and won't turn on. Now in Europe, 220V. Should work fine.
TV's operate on 110 volts, not 220 volts. You need more than just an adaptor to plug in your TV. You need to use a voltage converter to bring the voltage down to 110 volts. But since you already connected your TV up to 220 volts, damage has already occurred to the sensitive electronic components and you need to get it repaired.
Sep 15, 2011 | Sabre LCT371BKA LCD TV
My Sabre LCD TV is blinking red and green on power button and will not come on
My TV just did this 2 days before Thanksgiving. I just messed with it and fixed it today. Unplug it from the power source for atleast one hour. Plug it back it. Hold the power button til constantly flashes red and green. Wait at least one minute while it continues to flash. Turn it off. Flip the big power source button on the back to off && then on. Then hit the power button on the side, and it should turn on. Worked for mine. Hope it helps.
Aug 31, 2010 | Sabre LCT371BKA LCD TV
Tv keeps turning itself off
You most likely either have a faulty power supply or high voltage transformer that is failing. You can test them both with a voltmeter or multi-tester. The capacitors on the newer sets seem to overheat and burn out quickly
Oct 10, 2009 | Televison & Video
Red light flashes,10 sec after turning on. after power outage
Hi, thank you for visit fixya.
Do you need replace both stk 392-110, and check any resistor (2.2 ohms) for blown or open. You can replace this IC's for stk 392-150d9f769b.jpg
May 12, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Having the yellow flashing light
Sounds like maybe a power surge killed the TV. If it is newer, try contacting the Manufacturer for warranty repairs.
Apr 16, 2009 | Toshiba TDP-ET20U DLP Projector
50 inch dlp wont restart after power outage
did you replace the light bulb from the back of the tv set ?
check if its blown ?
if so just replace and your good to go ....
Aug 07, 2008 | Toshiba 50HM66 52" Television
Sabre 37" LCD TV problem
I bought a 37'' Sabre when I got back to the states in 07. Now, the power button is flashing red/yellow/green and won't turn on. Anyone with these tv's having this problem?
Dec 26, 2007 | Televison & Video
Televison & Video Logo
Top Sabre Televison & Video Experts
Electro Med Services...
Are you a Sabre Televison and Video Expert? Answer questions, earn points and help others
