Kenmore 70 series model 24732300
Doesn't fill water
JOE LLAMA
  • 26 Answers
SOURCE: kenmore 70 series
First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
Posted on Apr 04, 2008
jsrock516
  • 5911 Answers
Okay...I'm a little confused on your symptoms. You initially said it fills, but doesn't agitate or spin, but drains.
Then, you finished with the washer filling, no agitate or spin, but now doesn't drain.
Which one is it?
The symptoms you describe are usually associated with the following:
1. Fills, may or may not agitate, won't spin or drain - lid switch.
2. Fills, may or may not agitate, won't spin, but still drains - motor coupling.
3. Fills, may or may not agitate, won't spin or spins slow - gear case.
4. Fills, agitates, spins, but does not drain – water pump.
NOTE: These are the more common failure items with these symptoms.
Double check the lid switch by opening and closing the lid. You should hear a clicking noise to indicate the switch is working. The switch is located under the top panel along the wash tub rim on the right-hand side. If not, check to make sure the lid strike (small plastic piece on the lid itself) is in place. This activates the lid switch when the lid is closed. Also, check the mounting screws along the rim (there are two of them) to see if they are tight.
If the motor coupling were bad, the washer would still drain, but there would be a rattling sound as the washer tries to spin or agitate.
If you need replacement parts, go to searspartsdirect.com and type in your model number in the "Search by Model Number" window. The lid switch can be found under the "Top and Cabinet" heading as item number 11 (part #3949238). Instructions on how to replace are located at the following link:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
If you wish to replace the motor coupling, the part can be found under the “Brake/Clutch/Gearcase/Motor/Pump” heading as item number 13 (part #285753A). If you need instructions on how to replace, just follow this link:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Now, there’s a couple of ways to drain the washer. If it’s a simple lid switch problem, you don’t need to drain the washer to replace the switch. With a broken switch repaired, the washer will run and drain by itself. However, if you wish to drain the tub you can use a shop vac to pull a vacuum on the drain hose. This may take a few times depending on the size of the shop vac. These wash tubs typically have about a 35 gallon capacity. If you do not own a shop vac, you can by-pass the lid switch by jumpering the two BLACK wires at the lid switch connector that is connected to the console. CAUTION: Make sure you UNPLUG the washer before jumpering, then plug back in.
I hope this information is helpful to you. If I’m wrong about the symptoms, please post back and update me on what the washer is or is not doing, so I can assist you further.
Posted on May 15, 2008
  • 91 Answers
SOURCE: slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Posted on Jan 04, 2009
jsrock516
  • 5911 Answers
SOURCE: Broken Machine-Kenmore 70 series Washing Machine
This is commonly caused by a lid switch malfunction. If your model number is correct, the lid switch for your washer is located under the right hand side of the washer casing along the wash tub rim. The switch is activated by a small plastic piece on the washer lid (called a "lid strike") through a small hole. The switch contacts close when you shut the lid. In many cases, the lid switch either comes loose, or the lid strike breaks off. In both cases, the washer will exhibit the symptoms you describe. Open and close the washer lid and listen for a distinctive "clicking" sound as the switch contacts close. If you cannot hear the switch, make sure the lid strike is intact and the mounting screws for the lid switch (located around the wash tub opening on the casing) are tight. Sometimes, all it takes is to tighten the lid switch screws to realign it with the lid strike. If the switch is defective, or the strike is missing, parts can be ordered on line at searspartsdirect.com. Just type in your COMPLETE model number, which can be found on a nameplate under the washer lid. The lid switch and lid strike will be listed under the "Top and Cabinet" heading. Other sites that offer competitive pricing are repairclinic.com and appliancepartspros.com. If you require instructions on how to replace the switch, you may use the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you have questions, or if the diagnosis is incorrect, please let me know. I hope you find this information helpful.
Posted on Jan 14, 2009
  • 234 Answers
SOURCE: Kenmore washer won't stop filling w/ water
The problem is most likely the water level switch. This would be the case if the water is able to be turned off with the dial on the washer and not running all the time.
If it is running all the time and you have to turn it off at the water line valve, then the problem is a stuck water fill valve.
If you need more help, post a comment.
You can find information on the parts at partselect.com.
You can buy parts from them or find them locally if you want.
Thanks,
Tim
Posted on Jun 16, 2009
Kenmore 70 series wont stop filling with water to start the wash cycle
Lid off, right side circular pressure switch with black hose attached. Remove end of hose, blow down to make sure not blocked and blow into switch where hose attaches. Should click twice. If doesn't click, faulty pressure switch (replace)
May 19, 2012 | Washing Machines
I have the kenmore heavey Duty 70 series 92273100 Model 110 that we just moved. Was working fine before. Now it won't stop filling, overflows, and doesn't go into wash cycle. It will only s
either the pressure switch is bad or the pressure switch hose from the wash tub to the pressure switch is kinked or plugged so air pressure cant reach switch and operate switch,remove hose at tub and blow into it and see if machine now operates,if not the switch is bad
Feb 19, 2012 | Washing Machines
The wash machine will fill but wont stop filling
If it stops filling when you turn it off, the water level switch is malfunctioning. If the water runs in regardless, the water inlet valve needs replaced.
Dec 28, 2009 | Kenmore Washing Machines
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Kenmore Series 70 washing machine whines and low flow on cold H2O
Yeah you need to replace the water valve. To get to it you need to remove the cabinet on the newer direct drive models, If yours has a rear access panel then you simply pop the top to get to the valve after removing the hoses. Fairly simple job. Here is a good website for direct drive coupling replacement . It shows you how to open the cabinet. http://repair2000.com/coupling.html
GVI 151 is the generic part that fix all belt drive models. Direct drive will need its own little water valve buy hay it ain't but 20 bucks.
For a better explanation post you model number in the comment box and I will research it further for you amigo.
Jan 20, 2009 | Kenmore 22422 Top Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore series 70 washer doesn't fill
check your incoming water supply, the buzzing sound is coming fromthe waterinlet valve , soundslikke its trying to fill. possible that the valve is no good as well,
Nov 23, 2008 | Kenmore 22422 Top Load Washer
Series 70 Washer Won't stop filling
yes and also make sure fill tube is not clogged or debreed
Jul 05, 2008 | Kenmore 22422 Top Load Washer
70 series wont fill w/water
CHECK SCREENS IN WATER VALVES FIRST. CHANGE TEMPERATURE SELECTOR TO COLD ONLY, SEE IF IT WILL FILL. IF IT DOES FILL AND SCREENS ARE CLEAN YOU MOST LIKELY NEED A WATER SELONOID.
FXIT
Jan 26, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
