Question about Directv D12-300/100 DTV Receiver
No title available on guide - Directv D12-300/100 DTV Receiver
Will Filing A Business Name With The Secretary Of State Protect That Title?
No. A business title provides notice that you're by using their trade title, but doesn't prevent other people from utilizing the same title. However, title protection is available under common law and federal trademark law.
Oct 12, 2015 | Retail Supplies
Tip
Porteus on a MultiBoot USB Flash (Grub4DOS)
Porteus is a linux distribution customized for USB flash
and disks (live mode)
It is available as 64bit and 32bit solution
to install on USB flash, CD, MP3 player, camera and hard drive.
Porteus 32bit
1.) Download the Porteus 32bit ISO image:
http://porteus.org/index.php#
2.) Create a folder porteus on a USB flash drive.
3.) Take from the downloaded ISO, files
vmlinuz
initrd.lz (from the folder boot)
and all content (from the folder porteus)
will be placed in a folder porteus.
(extract the files from the ISO can programs Ultra-ISO or WinRar)
4.) In the main menu.lst add a:
title Porteus ==>
configfile (hd0,0)/boot/menus/porteus.lst
5.) In the folder /Boot/menus/ (Create a folder on a USB flash drive)
to file porteus.lst (Create a file on a USB flash drive) add:
splashimage (hd0,0)/BOOT/Splash/slacktux.xpm.gz
foreground 000000
background ffffff
timeout 30
default 0
title Porteus Graphics mode (KDE)
find --set-root /grldr
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw autoexec=xconf;telinit~4 fromusb
initrd /porteus/initrd.lz
title Porteus Graphics mode (KDE),Copy To RAM
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw copy2ram autoexec=xconf;telinit~4 fromusb
title Porteus Graphics mode (LXDE)
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw autoexec=lxde;xconf;telinit~4 fromusb
title Porteus Graphics mode (LXDE),Copy To RAM
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw copy2ram autoexec=lxde;xconf;telinit~4 fromusb
title Porteus Graphics mode (KDE) + Save changes /porteus/
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw autoexec=xconf;telinit~4 changes=/porteus/ fromusb
title Porteus Graphics VESA mode
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw autoexec=telinit~4 fromusb
title Porteus Text mode
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw fromusb
title Return Back <==
configfile (hd0,0)/menu.lst
title Reboot
reboot
title ShutDown
halt
5.) Download file
http://dl.dropbox.com/u/4040651/slacktux.xpm.gz
Put the file in a folder /Boot/Splash/ (Create a folder on a USB flash drive)
6.) Porteus on our MultibootUSB flash-is ready for operation.
INFO: MultiBoot USB Flash - Survival Guide (Grub4DOS)
http://www.fixya.com/support/r8170992-multiboot_usb_flash_survival_guide
on Feb 07, 2011 | Computers & Internet
Tip
ISkysoft DVD to iPod Converter for Mac Guide
iSkysoft DVD to iPod Converter for Mac is a specially designed tool for Mac OS X users to easily convert DVD movies for playback on iPod. The steps below will guide you on how to use this software:mac dvd converter
Step1. Please download iSkysoft DVD to iPod Converter for Mac; you can know more about it by visiting here. Then install the software and run the software.
Step2. Add DVD Movie
Click the Load DVD button, browse your computer, find the DVD folder of the movie you want to add from your hard disc or DVD-ROM, open your DVD folder, select the VIDEO_TS folder and click OK.
Or, click the Load IFO button, browse your computer, find the DVD folder of the movie you want to add from your hard disc or DVD-ROM, open your DVD folder, open the VIDEO_TS folder, select all the IFO files and click OK.
After you add your movie, you can choose any titles or chapters that you want to convert by ticking the check boxes before them.
Step3. Output Settings
At the bottom of the main window, you can name the output file for the current title/chapter, and select a subtitle to put on your movie, select an audio track. Then finish all the settings including selecting an output format, clicking the Settings button to set the video and audio encoding settings, choose if to merge the selected titles or chapters into one file, and set an output directory to save the output files.
Step4. Start Conversion
After setting the output settings, you can just click the Convert button to start converting your Movie. You can choose to shut down your computer or open the output folder after conversion so you don't have to sit before your computer waiting for the conversion to finish.
Advanced Options If you want to edit your movie before converting it, iSkysoft DVD Ripper for Mac provides your with various powerful functions including:
1. Trim DVD Title or Chapter If you want to capture a clip from the current title/chapter, you can click the Trim button to open the Trim window and trim the current title or chapter by dragging the Start Time slider to set the start time, and dragging the End Time slider to set the finish time.
2. Crop DVD Video If you want to remove the black edges or just convert an area from your movie video, you can click the Crop button to crop the video of the current title or chapter. You can specify an area either by dragging the frame around the video or setting the crop values: Top, Button, Left and Right. Above the crop pane, you can select an output aspect ratio and the available options are: Keep Original, full screen, 16:9 and 4:3. You can preview the video in the select aspect ratio on the main interface and during the conversion process.
Above the crop pane, you can select an output aspect ratio and the available options are: Keep Original, full screen, 16:9 and 4:3. You can preview the video in the select aspect ratio on the main interface during the conversion process.
3. Video Effect If you want to adjust the video effect of your movie, you can click the Effect button and drag each effect adjustment slider to set the video brightness, contrast, saturation and video volume. You can also choose a special effect from the Effect drop-down list to apply to your movie.
on Apr 27, 2010 | Computers & Internet
Will Filing A Trade Name Using The Secretary of State Safeguard That Title?
No. A trade title or name provides notice that you're by using their trade title, but doesn't prevent other people from utilizing the same title. However, title protection is available under common law and federal trademark law.
Oct 02, 2015 | Retail Supplies
What is the name of astrologer whose accuracy is 100%?
One who is the top astrologer in India with 100 percent accuracy is Mr. Rajat Nayar. You can contact him to solve your problem. For more information visit:- http://www.rajatnayar.com/
Feb 10, 2014 | astrology-online.com Computers & Internet
Tip
Change Internet Explorer Title Bar Text
To change the text in the title bar of Internet Explorer, follow the below mentioned steps.
1) Goto - [Start] - [Run] - [Regedit]
2) Guide to the given Registry Key: HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main
3) Modify/Create the Value Name [Window Title] according to the Value Data listed below.
Data Type: REG_SZ [String Value] // Value Name: Window Title
Value Data: [Enter The Text Desired In Title Bar]
4) Exit Registry and Reboot
Regards,
Shrey
on Mar 03, 2010 | Computers & Internet
Manual free download
Hello
It is available as follows
Model Lang Title Date Huskystar 207,Huskystar 215 Svenska Instruktionsbok 04/28/2010 0MB Huskystar 207,Huskystar 215 Espa?ol Gu?a del usuario 02/01/2010 1MB Huskystar 207,Huskystar 215 English User's Guide 11/24/2009 1MB
from this link
http://manuals.husqvarnaviking.com/
Hopefully this will be of some help.
Sewingirl/
Jan 28, 2014 | Husqvarna Huskystar 215 Sewing Machine
Need to download canon powershot SD550 camera manual
Canon has several User Manuals for the SD550, as well as manuals for their software, on the product site. See http://usa.canon.com/cusa/support/consumer/digital_cameras/powershot_sd_series/powershot_sd550#BrochuresAndManuals . (If needed click on Brochures and Manuals link; then expand the Guides and Manuals section.) The full titles aren't given. It just gives the Canon product name and then User (before hiding the rest). The first one with User in the title is the Basic guide. The second one is the Advanced Guide.
I hope this helps.
Nov 06, 2011 | Canon PowerShot SD550 / IXUS 750 Digital...
The difference between a nintendo ds and playstation video game is pricing, is that correct?
The differences between these two game systems includes price, size, weight, screen configuration, different games, processing power, etc.
For a more in-depth comparison of the two game systems, check out:
May 18, 2011 | JNC Computers SSF-310 MP3 Player
Making a copy of my DVD magnavox ZV450MW8A
What dvd copying software did you use? Have you ever tried avs dvd copy? It can help you copy it in one by one title. And here is a guide about how to use it
http://www.freedvdripper.net/guides/copy-dvd-to-dvd-shrink-dvd9-to-dvd5.html
Hope it helps, email me if you need further help.
Aug 17, 2008 | Computers & Internet
Directv D12-300/100 DTV Receiver Logo
18 people viewed this question
Top Directv Televison & Video Experts
john milligan
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
