Question about Application Techniques BEST SERVICE chris hein horns vol. 1
Chris hein horns authorization - Application Techniques BEST SERVICE chris hein horns vol. 1
Hydraulic jack manuals
Look for a rubber or plastic grommet on the cylinder in the jack. That is the fill hole.
Aug 03, 2014 | Hein-Werner Hein Werner HW93642 2 ton...
I have no horn or cruise control . This used to work but one day quit. Any ideas
Horn and cruise share the same fuse, check that. Also, clockspring inside the steering wheel could be messed up, that's a little tedious repair, find a junkyard wheel, pull it and hand it to your mechanic if the fues is good...Good luck... Chris
Nov 04, 2012 | 1994 Mercury Capri
I just inherited an older 3 ton floor jack. Guardian make, Model 4-102, 3000 lb. capacity. What type of fluyid does it take. who would I contact for repair parts? thanks
It was made by Hein-Werner, Similar to the WS model also 3,000lbs (not 3 tons). Been out of production at least 20 years or more. Guardian was Hein-Werner's cheaper off brand. Kind of a "dumbed-down" version. Also made an H-101 which was similar to H-W OS (O-Boy) model of 2500lbs.
Try a hydraulics dealer who sells Hein Werner parts. although obsolete, about 1/2 the parts are still available.
Lastly: Hydraulic jack oil. Never use brake fluid. Engine oil in a pinch, by I would never do it.
Jun 22, 2011 | Garden
How to activate adobe photoshop cs3 extended authorized code
If you need an activation / authorization code for this product, you will have to contact adobe. If the software is pirated you will have to go else where to find a solution.
Adobe activation hotline is :866-772-3623
Regards, Chris
May 20, 2011 | Computers & Internet
Please give a photoshopcs2 authorization code
You will have to contact Adobe for an authorization code.
866-772-3623
Regards, Chris
May 20, 2011 | Adobe Photoshop CS for PC
My horn keeps going off in the middle of the night and wont stop until you hit the horn several times and then will wait a little while and go off again
Just voluntarily fire the alarm off yourself each nite before you go to bed. Just hit the horn alarm button and let it blow once and hit it again to stop it. If you do this each nite it won't go off in the middle of the nite.
Mar 03, 2009 | 2003 Mitsubishi Montero Sport
Application Techniques BEST SERVICE chris hein horns vol. 1  Logo
Top Application Techniques Computers & Internet Experts
L Pfaff
L Pfaff
micky koren
Level 1 Expert
Are you an Application Techniques Computer and Internet Expert? Answer questions, earn points and help others
