Question about Brother 1034D Mechanical Sewing Machine
Fabric is binded up in the needles and feedogs and won't budge
  • Susan Turnau
    Susan Turnau Dec 28, 2014
    Unscrew the plate and carefully remove the threads and bits of fabric that are stuck. Clean with your brush (not with canned air or blowing with your breath) and put it all back. When you start again use a tear away stabilizer or tissue paper under the fabric to keep this from happening again and then tear away the tissue or stabilizer. You can also add a piece of fabric before your starting point and then the loose end of your cut fabric won't get so easily caught in the feed dogs. Afterwards cut off your starter piece, which could be just cotton. Hope this works for you.
What size needle required for sewing Velvet curtains??
What kind of velvet? Poly-based fabrics often require ball-point needles to avoid pulls. For apparel weight velvet (something I'd make a skirt with), I'd probably use at least an 90, possibly heavier. For really heavy, upholstery-weight, I'd use my walking-foot machine and a 100-110 (often used for jeans). But I'm sure I'd want to bind all of the seams on my serger, I often bind after sewing the regular seams, but for very heavy fabrics I'd bind first (just run up all of the edges of each piece before sewing seams).
Hope this helps.
Apr 06, 2015 | Janome Memory Craft 4900QC Mechanical...
Why would hand wheel be binding or stopping sew machine in one area
Needle may be having a hard item getting through a thick wad of fabric -- use a heavier-size needle. Or, threads have bunched up and need to be cut to release the machine. Check the underside of fabric for bunching threads in that case -- and adjust your top tension.
Dec 10, 2013 | Kenmore Sewing Machines
Feed dogs won't move
No info on the sewing machine make or model. It sounds like something is binding up, is bent, or is tangled in the machine. Look around the front and back of the sewing area for a switch to lower the feed dogs.
Good luck
Oct 05, 2012 | Sewing Machines
Serger won't chain off a stitch. Stitches won't chain and hold to fabric. Added new needle, rethreaded whole machine. Stitches won't connect to fabric or make a chain.
is it possible that the needles are in backwards?
it's very possible that the machine is out of time & would have to be taken to a sewing machine repair shop to be retimed
Apr 02, 2012 | Sewing Machines
Skipped stitches. Also, won't transition
have you checked the needle to make sure it's in correctly--flat side of needle goes to the back of the machine
correct needle insertion is mandatory for the proper use in your sewing machine. Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
place the new needle in the needle clamp with the flat side of the needle facing the back (or if using a round needle the groove in the needle should be facing away from the shaft.
push the needle all the way up to the stop, or as far as it will go, then tighten the needle clamp screw.
how to decide which needle is correct to sew with, it depends on the fabric & thread being used for the project.
like for example, I've been sewing for over 30 years, I'm sewing a stretchy fabric & regular needles won't work because they skip stitches & will pull the fabric thus damaging the fabric, the needle I have to use is a singer universal ball point needles, & I have no problem with the stitches they come out fine.
Sep 10, 2011 | Brother XL-2600
When sewing, the thread keeps pulling the fabric threads and the result looks messy. I've tried playing with the thread tension but it won't help.
have you tried using a new needle- if the needle is the slightest bet bent or or damaged it can cause problem with the fabric threads
if the needle is not the correct one for the fabric, it can move or damage the fabric threads
also clean under the needle plate for loose threads or lint also in the bobbin area
Aug 29, 2011 | Brother CS6000i Computerized Sewing...
I am having a problem with my Janome Decor Excel 5018. It was working fine, until the bobbin thread won't gather with the top thread. And the top thread is binding up underneath the fabric. Kim
try a new needle
rethread the machine top & bobbin, that way you make sure the thread is not caught anywhere
make sure the bobbin is correctly inserted in the machine
clean under the needle plate & in the bobbin area for loose thread & lint
always keep a long thread tail of 3 to 5 inches long, & keep the tails pulled back behind the needle
before sewing
if none of these things help the problem,, then it may need to be serviced
Aug 10, 2011 | Janome D'cor Excel 5018
My problem is that i starts to sew ,then it binds up in the machine and i have to pull it all out ,and i have to stop,so other words we start to sew then it binds up inside,where the needle is any idea,...
check the needle to see if it's bent-roll on flat surface to see if it rolls correctly
blunt needle- makes popping sound going thru fabric
damaged needle-end broke off
try rethreading machine-some sewing machine bind up when the thread come off the thread take up lever
make sure there is no lint or loose thread in the bobbin area
Sep 25, 2010 | Kenmore Drop-In Bobbin 16231 Mechanical...
Haven't used my bernina activa 140 for couple of years now. it wont pull the fabric through, any ideas why? All sounds healthy enough
Probably you have the feedogs lowered like you would for free motion or darning. Raise the feedogs by pushing in the button on lower right side I beleive.
Rick Engel
Jul 24, 2009 | Bernina Sewing Machines
Open Questions:
See all Brother 1034D Mechanical Sewing Machine Questions
Brother 1034D Mechanical Sewing Machine Logo
73 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
