Question about 1991 91 Chevrolet S10 Instrument Cluster Bulb-1991 Chevrolet Instrume
Gear shift indicator on 1991 chevy s10 pickup not working
S10 Chevrolet pickup truck 1995 will not shift gears how can I fix it
This is most likely going to be a transmission problem. You will have to have this diagnosed first by a shop. Should be about 80 bucks for this. Then you can go from there to fix it yourself or not.
Jan 26, 2016 | 94 95 96 97 Chevy S-10 S10 Pickup Billet...
1991 chevy pickup not shifting
b85f3b28-0a87-431e-bab0-3cb80e429a6c.jpgT.C.M. MODULE & WIRING HARNESS. GMC. $ 147.49 Chevrolet C1500 2WD PICKUP, 1991, 1992, 1993. Chevrolet ,you can see clearly what you need!
Watch out because not necessarily is the TCM,If you put more details may be we are able to help you out!
May 29, 2013 | 1991 Chevrolet C1500
Chevy s10 2.2 liter transmission problem
a number of issues. Tcc regulator bore worn out, the infamous check ball seat it hammered badly, or/and calibration issues. I have seen all three issues on the same trans - often!
Jul 15, 2010 | 1996 Chevrolet S-10 Pickup
92 chevy s10 4x4 4.3L manual transmission no 3rd gear
Hi:
Your transmission has 3 shift rails...
1st - 2nd
3rd -4th
5th- Reverse
If your 3rd gear doesn't work , you have an internal transmission problem, such as a syncronizer, or similar fail... There is not much you can fix, without removeing the transmission.
Nov 30, 2009 | 1992 Chevrolet S-10
My 2000 chevy s10 pickup doesn't want to shift
Check your master and slave, If your slave is not fully depressing the pressure plate it would be very hard to shift.
Low fluid would not cause this. However there is a bolt on the side of the trans that you remove and put your finger in to check the level. If you put your pinky in and no fluid comes out it is low.
The slave often goes on the chevy's. It is internal, you have to pull the trans to replace it.
Also a pressure plate that is collapsing can cause the same problem. You are pushing all the way down, but it is not releasing.
Hope this helps.
Nov 03, 2009 | 2000 Chevrolet S-10
1994 Chevy s10 pickup 2wd 4.3l autonmatic tran prob
if all other gears work fine then it's just a matter of changing out the solenoid that controls that gear you will save quite a bit of cash you don't have to change the whole transmission
Apr 27, 2009 | 1994 Chevrolet S-10
1991 chevy s10 pickup won't shift into park
Has anyone tried lubricating & or adjusting linkages/cable?
Nov 30, 2008 | 1993 Chevrolet S-10 Blazer
1998 Chevy S10 pickup backup lights don't work
Yes it screws in on right side of tramission and you will need a 7/8 inch deep socket to remove it. You may be able to clean the old one once it is removed. There is a little ball thatgets dirty and may you can get by with cleaning it. Good Luck. Ed
Sep 06, 2008 | 1991 Chevrolet S-10 Blazer
1991 chevy s10 pickup 4.3 engine
Check for vac. leaks and timing.
Jul 11, 2008 | 1991 Chevrolet Suburban
1991 91 Chevrolet S10 Instrument Cluster Bulb-1991 Chevrolet Instrume Logo
27 people viewed this question
Top GE Vehicle Parts & Accessories Experts
shadowpro
David Wiebe
Level 1 Expert
Are you a GE Vehicle Part and Accessory Expert? Answer questions, earn points and help others
