Question about Sharp AQUOS LC-32D43U 32 in. LCD Television
Whin i open the tv there's a red light upper but when i press the power button it cant be open the tv where shuold i check is there have a secondarry power hope u can halp me in my problem thank you
No power
  • 4 Answers
Jhshgxks,
Posted on Feb 15, 2014
I have a Samsung model PN60F5300BF that just died on me. Its barely 2 years old and one day it just went dead as if there is no power to the TV, even the red indicator light does not come on anymore
This may seem silly but you shuold check to be sire the power cable is plugged into the back of the TV, the other end is in a power receptacle, and if it's in a power strip, that that strip it turned on (some have a switch). A breaker might have tripped too. If none of these are correct, see if there's a reset button on the rear of your TV.
Dec 06, 2016 | Samsung PN60F5300BFXZA 60" 1080p 600Hz...
After power surge panasonic hdtv projection tv model # PT-53WX42F wont come on red light flashes
Bobbie, It dose not sound like surge protector was real effective, the TV will have to come apart to diagnose what has all blown, capacitors, boards etc. Google search can help show how it is done.
Enter all your TV's info, will not power on repair.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 08, 2016 | Panasonic Televison & Video
I pressed the power button, but the tv wont turn on
Please check if the power cord is connected properly in the wall outlet and in the TV. Check the wall outlet. Has it got power? Check if there is red light when the power is switched on at the wall outlet. If there is red light then press the power button. Does the TV turn on? If not then your power button is defective and requires replacement as it is not making contact. Also please try to start your TV WITH THE REMOTE CONTROL. At times it helps.
Feb 12, 2011 | Sanyo Televison & Video
My panosonic big screen tv has a red light flashing when i press the power button. wu do i do??
If evven after you try powering with the remote the sett is nott triggering then the possible secondarry power supply failure is for sure. You will have to open the rearr cover and check for the power (+B) look for absence or cut off, if absent check the fuse , fusible resistors inthe Sm tranformer output, if not the output drive could be faulty. But you will need to probe carefully, seek help so as not to tamper if not familiar.Good day
Aug 15, 2010 | Panasonic Televison & Video
Cant get a 1080i picture . tv supports this and i'm using a component cable . ( no socket for HDMI cable on tv )
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
after plugging in the hd cables
Oct 21, 2009 | Sony Playstation 3 (PS3) Console
Bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
Oct 20, 2009 | Samsung Televison & Video
My dish network remote isnt working with my LG tv
Not all TVs are supported by our remotes. You can do a power scan to see if you can find one that works or you can get the newest remote type that supports a large array of TVs. The new rmote is a model 21 which will work in IR and UHF mode. To perform a power scan do the following: Press and hold the upper left TV button on the remote until all lights on top light up and release.Now press the small red TV button and release - the upper tv button should be lit solid. Now press the arrow up key slowly until set turns off. Once it does presss the arrow down key once and then the arrow up key and the TV should power on. Now press the pound sign and the rrecord button. Now press the upper SAT button and release . You should be able to control the set now. Thanks for using Fix Ya.
Apr 07, 2009 | DISH Network IR Remote Control
TV will not turn on.
This is usually caused by 1 of 2 things.
1: You have a lot of dust in the vents so the bulb gets too hot. You might see a flashing red temperature light on the front status button. Clean the vents to the light housing and see if that solves the problem. You might also want to physically disconnect the power from the TV for about 30 seconds to allow it to reset if it is just a random problem.
2: Your light is about to go out. If you have had the tv for a few years, it is possibly time to replace the light bulb. You can usually tell this because the light will be dimmer than normal and possibly all 3 indicator lights will be blinking on the status button on the front.
HTH
Mar 07, 2007 | Samsung DLP HL-P5663W 56" TV
Sharp AQUOS LC-32D43U 32 in. LCD Television Logo
24 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
