Question about 1990-1993 Accord 2 and 4 Door Body Kit Part 5460
Car wont start
"Room light bulb is out of order or wiring is short with body' what does this mean
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 102 Answers
Has to be electrical or fuel related. spark and gas the basic places to start! good luck! Remove the gas line at the filter and use a can to catch the gas turn it over and see the volume of gas before and after the filter. Remove a spark plug and ground it to the closest metal or buy a spark plug tester [preferably] then turn it over check for spark. Don't be holding plug wire HEI has a bit of a bite! I could be wrong but a good place to start.
Posted on Feb 16, 2014
Backup lights are back feeding into turn signal. Why??
This is usually due to a bad ground wire (open circuit) creating a feed back voltage, or a short between the power and ground wire.
Try to isolate the problem by removing the backup light bulbs and the tail light bulbs, check the bulb sockets for overheating or short circuits between ground and hot wires, check each ground connection to body ground, must be zero ohm or less. If it's an automatic transmission the problem can be the neutral start switch as well.
Jun 25, 2015 | Cars & Trucks
Fuse keeps blowing on brake lights
It sounds like a short in the brake light circuit. When you are hitting the brakes, it is sending power along the positive wire of the circuit and shorting on the ground somewhere in the circuit. They make tools for finding shorts, which consists of an amp meter and circuit breaker. However, you can start by checking all wires that go to the brake lights. Start with the ones that are usually accessible through the trunk. Don't forget to check the third brake light if your vehicle has one. You will also want to check the bulb sockets themselves.
Jun 11, 2014 | 1995 Rover 200 Vi
Tail light wont come on
Look for short in wiring within the wiring harness. Had same problem and found 2 wires shorted together
Mar 02, 2013 | 1999 Dodge Ram
My passenger side brake light socket keeps melting the bulb where it connects, after replacing the bulb several times it wont work at all. also everytime i try to use my cigarette lighter it wont work and...
it sounds like that your car has an open short in the wiring somewhere, i would 1st check the wiring of the brake light that you are having trouble with, and if that checks out ok, then , i would check the fuse box area. and the wiring to the cigarette lighter, the wire connection to it , could be shorting out, by means of the wire being worn and shorting out against the metal.
Apr 23, 2011 | 1995 Chevrolet Cavalier
When i turn my high beam lights on the passenger side high beam does not come on. the fuse also blows.
there are short circuit somewhere ,check that no wire touch car body in the switch.
Mar 28, 2011 | 1991 Audi 80
Tail lights and dash lights went out
The parking and tail lights are usually on the same fuse as the dash lights, so check the fuse located in the fuse panel under the dash to see if it is blown. If replacement fuse blows again then it could mean a bad tail light bulb or a wire in the wiring loom that is shorting to the body. Check globes first and then check wiring loom near light assemblies for any chafed or bare wires.
Dec 19, 2010 | 1989 Chevrolet S-10 Blazer
Reverse lights turn off when brake is applied
This would normally mean a loose earth wire to the light , but check the bulbs as well as a bulb with one filament gone can short or earth back through another circuit You can jump a small wire from the chassis to the light assembly body to check
May 16, 2010 | 1994 Toyota Camry
My prking light says lamp out.my tail lights wont work either. i replaced all the bulbs and still says the same thing.all blinkers work brake lights.the fuses are fine.i tried everything ca=hanged the the...
well maybe the problem is further back then the replacement pigtails...perhaps a wire rubbed through somewhere and is rubbing on the body somewhere and not enough current is being exchanged to short a fuse. then perhaps you may have a controller problem too...a module that is...like a body control module.
Nov 19, 2009 | 2004 Buick Rendezvous
Why wont my taillights work on my grand marquis and everytime i put in a fuse it blows out
I had the same problem - the headlight switch was bad. It was drawing too much current and melting the plastic. Solution was to get another headlight switch from the junkyard. Then I used a dremel tool to remove the plastic from the area that kept melting. No problems since.
Aug 10, 2009 | 1992 Mercury Grand Marquis
1990-1993 Accord 2 and 4 Door Body Kit Part 5460 Logo
70 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Spud Howell
Mike Carew
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
