Question about Canon PowerShot A40 Digital Camera
My memory card for my power shot a40 isn't popping up
I took the memory card out of camera and put it in computer and it shows nothing.
  • 8 Answers
SOURCE: canon power shot sx 100 reads card locked
SD Memory cards have a tiny switch on the edge that marks the memory card as read only and prevents any writes. If you get the message "Card locked!" when you turn the camera on then turn the camera off, eject the SD card. With the card facing you (metal contacts facing away) the switch is on the left hand edge, slide towards the top of the card to make the card read/write again.
Posted on Dec 19, 2008
randy320sgi
  • 121 Answers
SOURCE: New San Disk memory card not working
vebhat,
Make sure the little slide on the SD card is in the right position, and if it's a high capacity SD it might not be compatible with your camera...
randy320sgi
Posted on Jan 09, 2009
hsanfor
  • 71 Answers
SOURCE: memory card capacity for my older canon digital camera
Does you camera use CF cards?
If so the may work but some of the newer high tech CF cards are made for newer cameras.
It may be worth a shot to try the 2GB card and if it does not work, sell to someone who uses those.
Posted on Jun 17, 2009
old marine
  • 2147 Answers
SOURCE: I have a cannon power shot SD600. I bought a
Did you get an SDHC card? The SDHC protocol was developed after the SD600 came out, and the SD600 is not compatible with it. Use SD cards with a maximum of 2GB storage capacity.
Posted on May 24, 2010
dj_relly999
  • 4070 Answers
SOURCE: i lost the cd from my camera canon power shot a40
Hi! Please visit www.canon.com, they have lists of downloadable programs that you can use for your webcam. Hope this helps and have a good one!
Posted on Jun 11, 2010
Took out memory card to transfer photos. returned card to camera and it indicated memory card error shut down leaving lens out.
Never remove or insert a memory card while the camera is turned on. Try removing the battery, waiting about 30 minutes, and then putting in a freshly charged battery.
Never remove or insert a memory card while the camera is turned on!!!!!!
Jun 22, 2014 | Pentax Optio Cameras
How to get photos off a nikon coolpix internal memory
Two alternatives: Remove the memory card before connecting the camera to your computer, or use the Copy command to copy the pictures from the internal memory to the memory card and then download from the memory card.
Dec 21, 2012 | Nikon COOLPIX S640 Digital Camera
I took my memory card out of my camera,erased what was on it, add new pictures from my computer,to it,then put the memory card back in to the camera,and hooked the camera up to my television so I could...
Your mistake was in assuming your camera would recognize any information your computer put on the card. It won't because of the difference in the operating systems. To get your card to work properly in your camera again, you will have to format it in the camera.
Oct 31, 2010 | Canon PowerShot SD1000 Digital Camera
Didnt put in memory card, but want the pics in the camera
the picture will either be on the internal camera memory if it has it or a card when installed. Both will come off the same way. Plug into the usb and the camera will be recognized by the pc. You can either use my computer or the management software that came with the camera to move or copy it off. It will show up as an extra drive or two.
Mar 23, 2010 | SVP CDC-8680 Digital Camera
Panasonic Lumix DMC-FS5 cant upload photos!!
Did your friend use the "safely remove hardware" function when removing your card from her computer? That could corrupt your card if she didn't. Try this...take your card to a store like Walmart that has a Kodak picture kiosk. They can usually read everything on a card. There, you can print the pics or even make a cd of them. Afterwards, format your card in your camera.
Dec 14, 2009 | Panasonic Lumix DMC-FS5 Digital Camera
When i put card in camera it keeps saying reinsert card
You didn't say what camera you are using, check the specs for the camera and see if it can use a 2GB card. If the camera is not able to use that size card it will not "see" it.
Have you tried putting the card in a reader and formatting it on your computer?
If it the computer can't see it, the card may be bad.
Oct 09, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
I am having trouble with computer not being able to read my memory card. Got a new memory card and I took pictures with it and they showed up on the camera put memory card in computer and said there were...
Have a look at the pins at the back of the memory card reader. You may need a torch to see to the back. My kids stuck something in my computer card slot and bent the pins so my cards would not read.
Jul 26, 2009 | Canon Digital Rebel XTi Digital Camera
Exilim camera, PNY optima SDHC memory card error
Hi
  1. 1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  2. 2 Open up 'My Computer'. You should see it under the list of available drives.
  3. 3 Check its contents first to make sure that you have the right drive.
  4. 4 In 'My Computer', right-click on the drive and choose 'Format'.
  5. 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  6. 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Nov 10, 2008 | Casio Exilim EX-S2 Digital Camera
Pictures
You have to make sure that the sd memory card you were using, hasn't been in another camera. If it was, your camera read the memory card differently, and it didn't show you had taken any. If this was the case, put the sd card back into the camera you took it from, and hopfully it will show on that.
If I wasn't even close, put you sd memory card in your computer, and hopefully, they will show up on there.
I'm sorry if I didn't get what you were saying, and didn't even answer you problem. I hope this helps.
Oct 01, 2008 | Nikon Coolpix L11 Digital Camera
ImageMate USB
Copy and past. If it is corrupt, scan computer and card for virus.Espesialy worm virus.
Aug 11, 2007 | Canon PowerShot A75 Digital Camera
Canon PowerShot A40 Digital Camera Logo
15 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
