Question about AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90
Replace impellor shaft
Broken impellor shaft
2 Suggested Answers
  • 106 Answers
SOURCE: removing pool pump impellor
Separate pump and motor. Remove diffuser. Remove back cover from motor. Motor shaft has either a slot for a screwdriver or a flat area for a wrench. Hold shaft and unscrew impeller.
Posted on Feb 24, 2010
What now ?? my yamaha suv1200 Can the transmission be shot ?
there are no gears just a direct drive from the crank to a jet pump ! if theres no propultion of water it could be several things !
1. plastic bag etc in the intake to impellor pump assy !
2. impellor gap to housing too much ie worn impellor !
3. impellor not turning because splines on either the shaft or impellor worn !
4. drive coupler damaged and spinning on shaft !
Try running on a hose pipe and look at rear of engine ( remove plastic cover so you can see the 2part coupler and drive shaft ) .
Check the impellor assy !
Sep 08, 2014 | WSM 1999-2001 Yamaha Suv 1200 Cc Jet Ski...
Yz 250 water pump leak
Hi mate this will be the oil & water seals the leak from weep hole is basically a warning light to tell you it needs replacing asap, you need to remove impellor, carefull not to lose the spacer washer behind it...then remove the water seal clean the surface it came from and replace with new seal. Now to do this 100% I would always replace the impeller shaft as the shaft wearing is usually what caused the seal to fail and I would also replace the oil seal which is the other side of case that you just changed the water seal (oil seal sits behind the small bearing) I would also consider replacing this bearing but maybe not critical? all up the impellor shaft the 2 seals and bearing last time I bought cost about $160... no special tools required just quite a bit of time required as you should really remove the outer engine case to access the impellor to undo it and to get to the oil seal and bearing, how ever I know guys do just open the water pump cover then rattle gun off the impellor only replace the water seal then install the impellor and cover back on then ride away! this will work and will fix the leak but is definitely the incorrect way to repair this and will be temporary fix but thought you may like to know this alternative as is very handy way to do it if your on a race meeting and just need to get through the last race or two.
hope this help cheers... Moto X Parts online.com
Feb 28, 2013 | 2003 Yamaha YZ 250
Pool pump does not turn on it just hums
If it hums and the impellor shaft is not turning, it's jammed and will trip the breaker after it over heats.
If the impellor shaft is turning, may have a broken impellor. After closing the inlet and oulet valves, I would take the pump cover off and check... Good luck...
Aug 07, 2011 | Waterway Pool & Spa
How to replace water seal
remove clutch cover,hold water pump shaft on flats on shaft and undo impellor by nut cast on impellor. remove old bearings and seals.check shaft for grooving where seal runs and replace if any.assemble in reverse order with new seals and bearings etc
Jun 22, 2010 | 2004 Yamaha YZ 450 F
Washer will not drain
There may be more debris in there or the impellor is now broken from its shaft,the pump will need replacing.
May 29, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
How do i remove impellor from maxiflo a7134075 spa booster pump? pump assy is leaking & i need to replace seals!
cut power to pump.... pull of rear cover... ther e should be a shaft in the middle of the back of the motor... you will need a wrench or channel locks or something like that to hold shaft in place... then unscrew the impeller while holding this shaft
May 20, 2010 | Pool & Spa
Leaking #1 pump on Arctic Spas Cub hot tub.
I found out that the pump impeller can be unscrewed from the motor shaft by turning the impeller while keeping the shaft from rotating. There is a brass shaft coupling embedded in the back side of the impeller. This allowed me to remove the leaking seal assembly inside the pump by tapping it out gently. However, instead of just replacing the seal, I decided to replace the entire pump with a newer version. Cost was only about $25 more than replacing the seal and gaskets. The pump-motor assembly has been reinstalled in the spa and there are no more leaks.
Dec 03, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
1995 rm 250 blown water pump seal
Iv'e changed heaps of these.Follow these steps taking carefull note of where & how everything goes to make it easy to put back together. make sketches if necessary.
  • Drain the coolant & engine oil
  • Remove the hoses that go to the water pump
  • remove the waterpump cover
  • remove the impellor
  • remove the kickstarter
  • remove the clutch cover & locating dowel pins if they are still in the clutch cover(if they didn't stay in the crank case)
  • the water pump seal is a (ceramic) two piece unit
  • remove the ceramic disc & rubber holder from the back of the impellor
  • remove the impellor drive shaft from the clutch cover
  • behind the impellor drive shaft there is a small bearing. To remove this I heat around the alloy of the bearing with a heat gun (or butaine gas torch,if using an oxy torch use a small tip & take care to heat evenly & not melt anything/or heat in an oven to 80 to 100 degrees max)Use welding gloves to handle the hot clutch cover)
  • turn the cover over & whack it down on a flat piece of wood(9 times out of 10 this is enough to shock out the bearing
  • remove the back-up seal from behind the bearing you just removed noteing the direction it was facing(for reassembly)
  • now using a suitable drift,knock out the other half of the mechanical seal
  • scrape all the gaskets & clean the parts
  • check the impellor drive shaft to make sure the shaft is smooth & dosn't have any groves worn in it.If it does you'll have to replace it
  • I always fit a new impellor bearing & back-up seal & new gaskets when doing this job
  • reassembly is reverse of removal noting the following
  • to install the bearing & seals use a socket that matches the OUTSIDE diamiter of them so you don't damage them.To install the rubber cup & ceramic washer into the impellor DON'T use a drift just push them in by hand
  • apply some grease to the impellor shaft before installing it
  • Apply some soap to the ceramic disc before re-fitting it
  • to install the clutch cover, if it won't go on at the front near the impellor, turn the impellor shaft to engage the gear
  • refit kickstarter,waterpump cover,hoses
  • re-fill radiator with fresh coolant
  • re-fill gearbox with fresh gearbox oil
That just about covers it all
Hope this helps you
Regards Andrew Porrelli
Dec 03, 2009 | Suzuki RM 250 Motorcycles
Dishwasher makes a high pitch whine when it runs
instead of motor check out the motor impeller that can make the high pitched noise if rusted or cracked. ------------- Motor and pump assembly screw and impellor help....
One of the most common question that I get on a dishwasher repair is "how does that motor and pump impellor screw come out?"
Inside many dishwasher pump assemblies is a screw that goes through the upper impellor and screws directly into the motor shaft. Since the motor shaft and screw are made of metal...you guessed it...they can / will rust. The screw can rust and become very tight and difficult to remove!! These screws are normally a right ( regular ) hand thread, socket or nut driver can be used to remove the screw. One hard thing to do is to hold the impellor still so the screw can be removed, they often just turn together. The impellor may be jammed with a screwdriver to hold it still so the screw can be removed...sometimes the impellor can be help still by placing a rag on it and hold tight with your hand, the rag will help prevent a sharp edge on the impellor from cutting your fingers. The odd time that screw is too rusted into place, soaking a little rust buster or 3in1 oil on it over night may help loosen it. Sometimes trying to tighten the screw a little at first will help break it free. There are some tool ( see below ) that can be purchased to help hold the impellor still so the screw can be removed, these are only for a few models and pump assembly styles.
WLP seal tool helps center and install the pump seal
Frigidaire seal - impellor remover and install tool
Once the screw is removed, the next obstacle is the impellor can also get stuck onto the motor shaft. Many times I have to break off the old impellor. A sharp blow straight down with a hammer and flat screwdriver will often crack the plastic impellor...careful not to damage the pump body! If the motor shaft has indeed rusted, clean it up really good with sand cloth.
Apr 03, 2009 | KitchenAid Dishwashers
AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90 Logo
16 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Larry Maranto
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
