Question about Coffee Makers & Espresso Machines
Jura ena 3
I have a Jura Ena3. The screen is saying Open Tap and then when I open it, the screen says System Filling, then it says Close Tap. After I close tap, the screen then says Open Tap. How do I fix this problem?
2 Suggested Answers
  • 60 Answers
SOURCE: open tap - filling system - close tap
Try using warm water in the watertank, important that the water is not too hot, it can cause leakage in the o-rings in the fluidsytem.
Repeat the procedure a few times, if nothing helps, turn off the machine and wait 1 hour and try again.
If you can`t get around this message, then the flowmeter needs to be changed.
Posted on Jul 12, 2009
System is not filling in my Ena 3. Pump stalled despite several attempts to prime it. Any suggestion?
I do not know what efforts you made to prime the pump.
1- Make sure that the water faucet is open.
Use a hand pump to push water into the pump. You can use a syringe or a hand pump. See instructions attached. Services Unlimited Inc Parts Guru Since 1988
Dec 16, 2016 | Jura ENA 3 Automatic Coffee Center - Black
Jura ena 3 rotary dial issue
Have you tried completely powering it down, as far as unplugging it from the wall? Sorry if that's stating the obvious, but I'm a computer guy and 9 times out of 10, a 'reboot' fixes the problem.
Aug 04, 2014 | Jura Capresso Jura Ena 3 Espresso Machine ...
Close cover message
the same here, but with jura impressa j5. any solutions?
Feb 08, 2014 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
My Jura Capresso E 8 is stuck in open tap filling system. I open tap it says filling system, it says close tap, when I close the tap it goes back into open tap. Float valve looks fine, water is moving
Open the tap with frother spout off. This happened to mine and I took the frother tip off and opened tap with tip off. Water filled and I closed tap...Machine returned "Ready". I heated water in microwave for three minutes- placed frother tip in hot water and all kinds of gunk came out. Lesson learned- Do a thorough cleaning of frother by immersing it in very hot water at least once monthly- even if you don't use it
Jan 06, 2013 | Jura Capresso Impressa E8 Espresso/Coffee...
Disassemble ena 4
As far as I know the Jura machines have a special oval shape screw head on their panels...and Jura charge something outrageous like 150euro if you want to buy the tool for opening these! Mite be worth trying to open it some other way like by gluing a tool or something into the head and let it dry, then open it.... then maybe replace the oval head screw with a different screw type when reassembling. Not an easy method of getting past the problem but id sooner do it than pay for the tool!!
Hope this helps
Dec 04, 2012 | Jura Capresso ENA 4 (13421)
Filter change
this was absolutely the problem with my Jura Capressa E-8 machine. I followed instructions after changing the filter. I opened tap-machine stated that it was filling system- I closed tap when instruction. The open tap remained on because no water was filling system. I took the frother tip off and opened tap. Water filled system (container under frother). I closed tap without the frother tip. Machine Ready.... (I heated water in microwave for three minutes) I placed the frother tip in there and used a wooden skewer to ensure frother was clear of debris... Worked like a charm!
Nov 26, 2012 | Jura Capresso Impressa E8 Espresso/Coffee...
I can't get past the 'open tap'/'close tap prompts on my Impressa
I had this problem with my Ena 3. The difference was that water was actually passing through the nozzle, but when I turned the dial back to the coffee symbol it would just tell me to open the tap again.
The solution was simple thanks to bergend's post, although I'd never have thought of it independently. I emptied the water tank and filled it back up with luke warm water instead of the cold water I had been using. After the first "system filling" round, the machine continued with the setup program fine.
So, to others with this problem: don't use too cold water in the tank for the first setup, even though the manual tells you to. Luke warm works great.
Apr 25, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Coffee Makers & Espresso Machines Logo
13 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
