Question about Frigidaire Refrigerators
Control board #5303918498 dont work
We replace main control board snd ice dispenser board and still doesnt work
maklean
  • 1665 Answers
SOURCE: Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jul 04, 2008
SOURCE: JENN-AIRE MODEL JCD2389GEW = WATER/ICE
defros heater
Posted on Oct 18, 2008
abhishek33
  • 1239 Answers
SOURCE: Ice/Water dispenser not working correctly
hi,,
it is a thermostat problem,,because of it heating is not done properly ..u should replace or fix it,,it is not a big amount....
thank u,,,
Posted on Jul 01, 2009
TheMobilian
  • 8220 Answers
SOURCE: GE refrigerators GSS23WSTASS: The control panel on
GSS service manual
Posted on May 13, 2010
  • 26 Answers
SOURCE: Ice maker on an LG American Fridge Freezer doesnt work- why?
it can't freeze
Posted on Jun 12, 2010
Fisher snd paykel e522b ice snd water frudge not dispensing chilled water. Also only half display is working.
U may need to get it re-gassed? or it may be a wire running to the water chiller
Oct 31, 2013 | Refrigerators
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
My LG ref. stop dispensing water and ice. make ice but it doesnt dispense it.
I have found that my ice maker makes ice, but i can not dispense, water or ice, control board good, micro switch good only thing left is reversing solenoid. i have just ordered one once i replace it ill get back to you
Dec 18, 2012 | LG LSC26905TT Side by Side Refrigerator
Replaced motherboard I still doesnt work freezer wroks but ref doesn't have to defrost w/hairdyers once a week
open up the freezers rear panel and check the defrost element for a bad heating element, that defrosts the freezers evaporator coil,then its either an adaptive defrost board which i suspect is controlled off the main-board that you already replaced
Sep 16, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice/Water despenser Problem- not working(no lights on the button)
Replace the main control board . Pt # WR55X10942 is the part number . The dispenser board has lost communication with the main board . The main control board is behind the refrig , behind the small 8X10 inch panel . There are 6-8 group plugs which will only fit in perspective plugins , so this board is easily replaceable . Cost of board is about $150.00 .
Jul 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE fridge fan clicks, ice dispenser not working
Main control board problem . Pt # WR55X10656 . The freezer fan motor , works off DC voltage . The board is not giving it enough voltage . The main board , also controls the dispensor board .
Sep 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice and water working intermittently, makes ice, Artica PSS 26NG
Go into the test mode and use 0 4 as the test code between the dispensor board and the main board .(communication test) Sounds like the main control board though .
Jul 18, 2009 | GE Profile¿ Arctica® Energy...
We have a french door botom freezer maytag w/ and electronic water/ice dispenser. Model #mfi2568ae In the middle of the night the ice dispenser started opening and closing by itself and the led display is...
Don't be duped into thinking the display/dispenser board is the culprit. It may come a surprise, but this failure is often misdiagnosed. Because the dispenser is causing such a ruckus or because the display itself is blank or flickering, folks are led to believe that the display control board itself is the part that has failed. Looking at the history of our board evaluations, this little tiny control board rarely fails. And as crazy as it may seem, it is the main control board, aka the high voltage control of the fridge that is causing your refrigerator not to cool and the dispenser to be erratic.... This is the main control board of the refrigerator, located on the back of the unit. I've attached photos of what this main control board looks like. This main control board will need to be repaired to replaced.
http://blog.fixyourboard.com/2016/06/08/ice-dispenser-flapping-display-flashing-on-refrigerator/
Ice Dispenser Flapping and Display Flashing on Refrigerator
Aug 04, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Ice/water dispenser control panel
could be the dispenser board or the main board. hard to sort out without a meter. most likely the dispenser board but i have seen a dispenser board go bad and smoke the main board if that is the case you can damage the new component so check out the cost on the parts
May 07, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
GE Profile Side-by-Side Refrigerator Ice Maker Issue
The Computer on the Door communicates to the Main Control Board on the rear of unit via several small low voltage DC wires .Ive had this problem and is was a bad connection under the freezer door behind the toe plate (it goes through the middle of the hinge). You can try wiggling that connector, but if it still doesnt work you may have to bypass that connector with proper techniques. Unplug before cutting or splicing, If is still doesnt work than There is no other way to tell what the issue is besides replacing display board and Main board. I would try Main board first if connection is good. Hope this helps
Jan 19, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
