Question about LG Flatron 995FT 19" CRT Monitor
LG 995FT slightly out of focus
My Screen ahas steadily lost focus over time and is now slightly out of focus...Can this be adjusted to correct the focus and where would one do this?
Thanks,
Jaco
Hi
do u have its driver?
send me it to ab_eng@hormail.com
Posted on Jun 04, 2008
My screen seems to be slightly out of focus - is there an adjustment I can make?
usually there is auto adjustment on the bottom part of your monitor. if there is none manually adjust it using vertical and horizontal adjustment tool in the same set of controls at the bottom of your monitor
Dec 05, 2013 | Dell Inspiron Computers & Internet
"Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Nov 08, 2007 | Televison & Video
Slightly out of focus. Is there an (internal) adjustment, and if so, where?
over time the shadow mask picks up a magnetic charge that interferes with the focus of the electron beams which makes the image look fuzzy or out of focus...to fix this.. most monitors have a deguassing coil/button..look for a DEGAUSS button or in the menu selection on the monitor..Degaussing usually makes a "thunk" sound and the screen will go crazy for a moment ..
May 06, 2009 | Computers & Internet
Adjust focus
Focus adjust is located on the neck board or on the Flyback transformer, another fault is dirty spark gap inside the CRT socket
Jan 04, 2009 | Sharp 25R-S100 25" TV
Convergence problem
This is a common television flyback transformer , it has two potentiometers ( POTS ) variable resistors , how ever you wanna say it , the one above has 3 , one of them is the focus
you can use a plastic screwdriver or plastic wand , or small metal screw driver if nothing else
Here's a closeup of one that has only two potentiometers
One of them is the focus adjustment
to adjust the focus/sharpness of the image you see on the screen
1. find which one is the focus , you will know because adjusting it out of calibration will cause
the screen to go out of focus untill you adjust it correctly.
to adjust it correctly , rock it back and forth untill you see the sharpest image , then your done.
if you accidently get the wrong one by mistake your screen will increase in brightness
set the brightness lower rather than higher , because you don't want it to be over saturated.
Az.
Sep 16, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
LG Flatron L1722P
The computer might not be working properly not the screen... CPU turns - on, but with no response... have the computer check by a computer technician
Jun 26, 2008 | LG Flatron 995FT 19" CRT Monitor
Thin red horizontal lines across screen
replace the focus block or try to adjust the screen control on the focus block for red only. this will affect the white balance of the set so adjust it carefully. the focus block is located on the front inside the set. remove the speaker cover then the 4 screws on the front plate. the focus block is 3" x 2" black box with 6 adjustment posts three for focus and three for screen. adjust only the affected screen (R).
Mar 13, 2008 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Toshiba tv-model tz55v61
If the red,green and blue mixture adjustment is what you want...
remove front lower speaker grill & access panel..locate RGB
adjust on Screen / focus block.......slightly adjust screen controls for best mixture....do not adjust focus controls.....T.
Jan 10, 2008 | Toshiba TZ55V61 55" Rear Projection...
Tasco propoint PDP2 scope
Are you looking set the eye relief or the focus ring?
For eye relief you need to loosen the scope in the rings, mount the rifle to your shoulder with your standard hold and cheek weld. At this point, slide the scope back and forth in the rings until you obtain a full field of view. Tighten one of the rings slightly, dismount and remount the rifle several times to ensure correct adjustment. Level scope and tighten rings a final time.
For focus adjustment (remember that you are using the eyepiece to focus on the cross hair, not your target!) loosen the lock ring and turn the eyepiece until the cross hair is focused. It is best if you check it several times by closing and opening your eye several times. The crosshair should be instantly in focus. If your eye must adjust, then you need to refocus until the focus is instant.
The two dials on the scope are for adjusting the bullet point of impact. They will typically move POI 1/4 inch at 100 yards.
Nov 08, 2007 | Optics
SLIGHT GREEN TINT TO PICTURE
most atimes if i adjust the screen adjuster on the voltage multiplier i always observe that the screengoes green(lg 21" television),and if i readjust the screen,the greengoes off.Rubberhead,try adjusting the sceenknob on your voltage multiplier(line transformer).
Feb 26, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
LG Flatron 995FT 19" CRT Monitor Logo
130 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
