Vacuum shutdown due to motor overheating and it wont start again. Is there a reset button
  • 97 Answers
SOURCE: my Miele s558 Silver moon
This is caused by a circuit board problem in the hose. Unfortunately, the only way to fix this problem is to purchase a new SES 125-3 hose. The good news is that the new production hoses have rectified this problem and you will not experience it again.
-R
Posted on Sep 10, 2008
Nicesuit
  • 61 Answers
SOURCE: My Dyson vacuum cleaner overheated and won't restart
usually there is a onshot TC fitted to the motor once it pops its popped and you have to replace the motor assembly.
Posted on Jul 23, 2009
  • 1015 Answers
SOURCE: over heats and shuts off, wont start again untill
The electric motor has a thermal switch and is self-resetting so there is no re-set switch. Make sure the air filter for the exhaust is clean. Also make sure that the height adjustment is not too low causing strain on the motor. Always bring the height down to where the brushes just make contact with the carpet. It is possible that the thermal safety switch is tripping due to a bad switch. In that case I would contact Drit Devil if it is still under warranty.
Posted on Nov 10, 2009
  • 115 Answers
SOURCE: DEll GX 260 Bios Currupt due to abnormat shutdown
Please download BIOS and install from following site
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&catid=1&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=PLX_PNT_P4_GX260&hidos=WW1&hidlang=en&TabIndex=
Regards
Ashley
Posted on Feb 02, 2010
SOURCE: The Brush Motor on my Bissell Healthyhome Vacuum wont start
I had this same problem. There is a screw that holds the top handle and the lower handle "together". If this screw is not TOTALLY tightly screwed in, this will cause the contacts in the switch to BREAK contact, and therefore one or BOTH motors may not start, or cut in and out. This was the fix for me.
Posted on May 12, 2010
I cannot get my Veggie Bullet 's motor to come on. Red light comes on, but when I push the button again the light turns green, but the motor will not engage.
The motor may have gone into thermal shutdown due to overheating but also the motor could simply be defective.
Mar 28, 2018 | Televison & Video
Where is the reset switch on the Nutone CV-350
The reset button to the vacuum unit is located on the upper left or right hand side towards the back. There is a small black circle about the size of a dime that has a white tab that pops out. If the tab is sticking out, you can reset the system and trying vacuuming. Typically, the reset button pops for a reason because of an overheating or defective motor. If the reset button is not popped, try turning on the unit from a vacuum inlet and see if you hear a clicking sound at the vacuum unit. If so, this means a new motor is needed. If a clicking sound is not heard, this can mean a bad relay in the unit.
Please visit our website if you need a replacement part or if you have more questions.
https://qualityhomesystems.com/central-vacuum-system/
Don't forget to like and visit our Facebook page.
https://www.facebook.com/QualityHomeSystems/?ref=hl
Mar 15, 2016 | Broan-NuTone CV350 Central Vacuum
Why wont the reset button depress on riccar 8955 or turn on after trying
The reset button does not have a significant amount of movement in response to pressing to with a paper clip or ball point pen. If the vacuum does not start upon pressing the button, then either the thermal protection circuit is not why the vacuum stopped in the first place or the reason the thermal protection circuit tripped has not been cleared. Quoting from the manual
"Your Riccar vacuum cleaner comes equipped with a Manual Reset Thermal Fuse Protector. This thermal protector is designed to protect your vacuum cleaner from overheating due to a restriction in airflow (i.e. clogged hose, operating the vacuum without a bag). Should this situation occur, the thermal fuse protector will safely shut off the vacuum cleaner to avoid any potential damage. NOTE: To determine it was the thermal fuse protector that turned off your vacuum
cleaner, please refer to the vacuum cleaner's headlight. If the headlight is on while the motor is off, then the thermal fuse protector did safely shut down the motor. If both the headlight and motor are off, then there is some reason other than the thermal protector (i.e. pulled plug) your vacuum is off.
To reset the thermal fuse:
. Unplug the vacuum cleaner
  1. Check for problem - over-filled bag, clog in hose, clogged filters, etc.
  2. Correct problem
  3. Locate "tripped" fuse - the small white button located on the bottom of the back side of the main body (roughly one inch to the right of the left wheel)
  4. Using a pencil, paper clip or other pointed object, push the reset button in
  5. Plug vacuum cleaner in and resume use"
Mar 08, 2015 | Riccar 8955 Upright Vacuum
The vacuum does not start
Did you push the reset button on the rear of the vacuum. If it has. Overheated the reset will trip.
Mar 21, 2014 | Riccar 8900 Simplicity 7822, 7300, 7350,...
I need to know if it has a reset button. we had a power outage and it has stopped working since than. cant find a button to reset it.
Vacuum cleaners do not have reset buttons instead it would have a thermal protection breaker integrated within the motor if the motor overloads it will shut off but will start again as it cools down.Check to make sure the outlet has power in it first. Vacuum cleaners are usually reliable since they are not subjected to prolonged use unless it is used in commercial environment, but a common problem with it is a bad internal connection usually around the motor area due to vibration.
May 24, 2011 | Vacuums
My tank foamed up into the motor and now the rainbow won't come on. Is there a reset button for the motor somewhere? Will it dry out and reset on its own?
Reset switches are generally for use after a motor has shut off due to overheating. They don't do any good for resetting a motor that has gotten moisture into it. Moisture in a motor will quickly ruin it. Allowing it to dry out on it's own will just result in rusting and further damage to the motor. You can take it to a repair shop to see if they can undo the damage, but I think you'll probably have to replace it.
Mar 29, 2011 | Rainbow E series Canister Wet/Dry Vacuum
Where EXACTLY is the reset button on DC07? I am not an idiot, but I cannot find this button anywhere!
This model doesn't have a reset switch. When it shuts off due to overheating, the vacuum needs to be switched off and allowed to cool down for at least 30 minutes before using again.
Overheating is generally caused by blockages in the airflow system, and should be checked while it's shut down. A downloadable owner's manual can be found on the following site.
http://ubermanuals.com/product/dyson-dc07-1870
Jan 02, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson dc 16 hand held vacume stops & starts while in use, each time you pull the trigger it will start again but then stops after a short while untill i pull the trigger again.
Cutting out can be due to a few things , motor overheating due to dirty filter, Faulty mains cable or plug..sealed type also..Faulty Switch/trigger.May need to seek pro help to fix.
Apr 01, 2010 | Vacuums
Over heats and shuts off, wont start again untill it cools off. can maybe vacuum one room before overheating. cyclone tubes are all clean, all hoses & lines are clear. this vacuum is fairly new, not...
Nov 10, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
Husky comp on 1st start builds up 75 lbs and wont restart
Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
Dec 30, 2008 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
12 people viewed this question
k24674
jasbo
jasbo
