Question about ASUS Transformer Pad Infinity TF700T 10.1" Android Ice Cream Sandwich
Wont boot ,logo and circle
Key driver not found
Laptop doesnt boot past logo
While the computer is powering on, tap the F8 key until you get a menu. Select Safe Mode w/networking and see if that allows you to log in. If yes then you will need to determine whether or not you updated a driver recently and roll it back. This is where I would start. If it doesn't boot into safe mode then you may be looking reinstalling Windows.
Jul 12, 2015 | Gateway Computers & Internet
Won't finish booting
Sounds like a corrupt operating system you can try the master reset steps below WARNING ALL PERSONAL DATA WILL BE LOST UNLESS STORE ON THE SD CARD
Other wise contact your provider via website or phone for the closest repair center
http://locator.t-mobile.com/Locator.aspx
  1. Back up all necessary data.
  2. Turn off the phone.
  3. Press and hold the Volume Down and Power keys.
  4. Wait 3 seconds and press the Back and Menu keys.
  5. Note: If you see the LG logo before pressing the Back and Menu keys, the reset hasnt been completed and you will need to restart.
  6. Release the Power/Lock key after you see the LG logo.
  7. Release the remaining keys after the LG logo flashes (blinks once).
  8. The Android Unpacking screen appears.
  9. The phone will restart and complete the factory reset.
May 28, 2012 | T-Mobile My Touch Cell Phone
Wont start but xp logo appears then no more
Can you boot into safe mode? It sounds like your issue is a bad video driver- Try booting into Safe Mode by tapping the F8 key and selecting safe mode. Reinstall your video driver and try rebooting. There is a specific issue where if the video card has gone out, you will get symptoms similar to what you are experiencing. If reinstalling the driver does not work- try replacing the video card if possible
Oct 03, 2010 | Computers & Internet
I just get the red circle on the front display. I
The red lights is overheating you will need to fix this and to do it you can either send it in or you can use a good guide to fix it from home.
Jun 29, 2010 | Microsoft Xbox 360 Console
Apple logo stays on screen then for 10 minutes then boots up all over again what do i do and it wont show up on itunes what do i do?
Try a hard reset.
  1. Press the home button (the big circle below the screen) and the sleep wake button (the button on top of the iPhone) simultaneously.
  2. Hold both buttons simultaneously for a few seconds, Ignore the "Slide to power off" and keep holding
  3. The iPhone should now shutdown automatically - (fade to black)
  4. Turn the iPhone back on by hitting the sleep/wake button.
  5. You should now see the Apple logo, your iPhone is restarting and thus booting up.
  6. You have completed a hard reset successfully.
Oct 19, 2009 | Apple iPhone Smartphone
Hi, im kind of lost with this issue. I got a new pc with a mother board intel DG31PR, it works fine at least as far as i have tested. The problem is that i dont find how to remove the intel logo on the...
All this info can be found on the computer once she's up and running. Just go to System info under "Help" section.They know you didn't need to see that sticker for the info.
Aug 25, 2009 | Intel DG31PR Motherboard
Mac book displays a circle with a diagonal line through it when booting up, but fails to boot up
Restart your mac:
Safe Boot: Hold down the shift key after the chime until the Apple logo appears and the gear is moving.
It will take awhile but you will be asked to login.
Go to your Applications folder> Utilities and launch Disk Utility.
In the left side column, highlight your drive and repair permissions.( button down below)
Empty the trash.
Restart your mac
Apr 19, 2009 | Apple MacBook Pro Laptop Computer with...
Macbook Startup Never ending Apple Logo and Circle
try holding down the alt(option) key when starting up it should give you a list of startup options, it sounds like you dont have a astartup disk (an operating system) installed.
Dec 12, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
ASUS Transformer Pad Infinity TF700T 10.1" Android Ice Cream Sandwich Logo
18 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
