Question about Canon EOS Rebel G 35mm SLR Camera
Film loading when I put in a new roll of film, and shut the door, instead of automatically forwarding the film to the number one exposure, it rewinds it as if its the end of the roll and the film ends up being useless.
  • lstcox Dec 25, 2008
    This morning (Christmas) my camera done the same thing. Replaced the battery then put another roll in & it made the sound of forwarding but never showed the numbers & then clicked. Check inside the body & the roll of film was back in case as when it is finished. Please help!! First problem that I have had and I have been using it regularly since 2002.
  • sbfd Mar 02, 2009
    My film is not advancing.
    Scholar:
  • 85 Answers
Rewinding button or option may be in action
Posted on Apr 02, 2008
Iana mini rewind crank not spinning when advancing film
If the film is advancing you do not have a problem. It may be that the rewind button does not actually spin when you advance the film, because if it did and you have something caught on it when you are trying to do so you could really mess things up. Really, the rewind crank may only visibly spin in one direction.
Apr 17, 2014 | Lomography Diana Mini Camera & Flash...
Is there a manual rewind on nikon n65?
If by manual you mean turning a crank to rewind the film, no. If you mean to do it at a point other than the end of the roll, yes.
To rewind film mid-roll, press the two film rewind buttons simultaneously for approximately one second. The film will then rewind and the frame counter will count backward. The film is completely rewound when the E appears in place of the frame number.
The two film rewind buttons are marked with a red film canister symbol with left-pointing arrows. One is the exposure compensation button next to the control panel, the other is the self-timer button next to the mode dial.
If you need a manual, you can download one from
http://butkus.org/chinon/nikon/nikon_n65/nikon_n65.htm
Jan 21, 2011 | Nikon N65 35mm SLR Camera
This is kind of embarassing... i received an old nikon f65, and i don't know how to remove the film properly without burning it...
The film should rewind automatically at the end of the roll. If it doesn't, press the two film-rewind buttons simultaneously for about one second. The film rewind buttons are maked with a red film icon; one is also the exposure compensation button to the right of the LCD control panel, the other is the auto exposure bracketing button to the left of the viewfinder.
Once the film is rewound, turn the power off. Slide the release lever on the left end of the body, and the back should pop open a little.
You can download the manual from
Aug 23, 2010 | Nikon F65 35mm SLR Camera
My Pentax SPII shoots blank images
You can check the shutter without film in the camera. Remove the lens and open the film door. You will see the cloth curtains of the shutter in the center. Advance the film lever to **** the shutter and set the speed dial to a slower speed like 1/15. Hold the camera so it is aimed a a light source, (a window will do) and fire the shutter. You should see the light through the shutter for the time duration is is set to. (1/15). If you see the light source, repeat the process going up one speed setting until you reach 1/1000. If you see the shutter open and close as described, then try another roll. After you load the film and close the back door, make note of what the rewind knob is doing as you advance the film. It should spin counter-clockwise each time. That is a easy test to know that the film is traveling in the camera properly. Vary your exposures with the new roll at different speeds and f-stops. You should get exposures, but if not let us know.
Jan 31, 2010 | Olympus Stylus 850SW Digital Camera
Why is the film automatically rewinding around 15 shots instead of the end of the 24 shot roll? The batteries are fresh.
the roll sensor is not reading the silver code on the film roll.
Open the camera when you have no film in it.
Clean the film roll slot where the "fingers" are.
These fingers touch the case of the film roll to determine the film type, which includes the number of exposures. You nmay have to "adjust" the fingers so that they make good contact with the film roll case.
Look at different rolls of film, notice the silver blocks are different. If the roll has a "dent" on it, it can't be sensed correctly.
Hope this helps!
Sep 15, 2009 | Canon Sure Shot Classic 120 35mm Point and...
New roll of film rewinds instead of advancing
Your camera has a faulty winding mechanism. It suppose to rewind in the end of the film when there are tension present but somehow the detecting system in your winding mechanism is detecting when the back door is closed. Remedy is replacing the clutch system within winding mechanism. Average repair runs about $90. -James. For further assistance by email, go to www.camerarepairjapan.com
Mar 21, 2009 | Nikon N55 35mm SLR Camera
Film rolls back automaticaly
The camera shouldn't be doing this, assuming you're using 36 exposure (or 24 exposure) film. You may want to set a custom function to prevent automatic rewind -- you would have to rewind the film yourself by pressing the rewind button.
To do this:
1. Under the palm grip, press the 'CF' (custom function) button.
2. Use the main dial to select 'F1' in the LCD. It should show a '0' below the 'F1'.
3. Press the 'CF' button to change the '0' to a '1'.
4. Press the shutter button half way to save the change and exit the custom function setting mode.
If you want to stop the rewind with the film leader still exposed (film doesn't rewind entirely into the cannister), use the same steps but set custom function 'F2' to a value of '1'.
Mar 17, 2009 | Canon EOS-1N RS 35mm SLR Camera
Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Apr 27, 2008 | Nikon FE 35mm SLR Camera
Camera not working-please help
No promises but if you take a roll of film that is already light fogged etc. and load it into the camera. Let it wind as normal. Now we need to work quickly: Press the rewind button. While it is winding OPEN THE BACK. It won't rewind very long because very little film is out of the cartridge so be ready. This will fogged a bit of the film but it does seem to clear the error. You can still shoot the roll if you just skip the first few shots.
Dec 06, 2017 | Fuji Zoom Date 60 35mm Point and Shoot...
Premature Film Rewinding
the only thing that I could think of when I read your situation is, that you might not be using a DX coated films. see, the camera reads the bar code on the film and maybe it is not the same program. check the camear manual and make sure you are using the same kind of the suggested film in the manual. good luck
Apr 11, 2007 | Nikon N65 35mm SLR Camera
Canon EOS Rebel G 35mm SLR Camera Logo
203 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Jerry Greenberg
Jerry Greenberg
Are you a Canon Photography Expert? Answer questions, earn points and help others
