Question about Samsung RS2534 Side by Side Refrigerator
Display/control panel not working
Got a 1 blinking
Temp.Control Panel indicator is Red, what can i do?
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place. 192 168 1 1 192 168 1 1 admin password log in
http://www.routermobile.com/ 192 168 192 168 1 1 Login Admin Password http://www.19216811254.com/
Aug 18, 2015 | Fisher and Paykel Active Smart E522B...
My problem is i have a jandi lite 2 and the control panel is just blinking just wondering if there is a reset button i had the heater working good then shut it down now i cant get it to work it just...
check to see if water temp sensor shorted remove to black wires from control board if it quits bad temp sensor if it doesnt bad display board need new display board
May 23, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Sent a document to print but its not printing and the printer light keeps on blinking even though I've unplugged the printer twice and even rebooted my system?
1. Turn the printer on.
2. When the memory starts counting on the control panel, press and hold the green SELECT button. Continue to hold green SELECT button until all three Control Panel LED's are illuminated and on solid.
3. Release the green SELECT button.
4. The control panel will display SELECT LANGUAGE.
5. Press the DOWN ARROW button until control panel displays COLD RESET.
6. Press green SELECT button. The printer will perform a cold reset and then continue its power-on sequence.
Hopefully, this will fix the problem for you!
Nov 23, 2010 | HP DeskJet 3550 InkJet Printer
My hp deskjet 3550 is not printing. the green light at the power button keeps on blinking. What is the problem? both ink cartridges are full. there is no paper jam.
May 28, 2010 | HP Color Laserjet 3550 Printer
No picture and the led ligth is blinking panasonic veita 52
If you have the flashing red light of death you can use the chart below, and call Panasonic to have it replaced. At the bottom is the list terms.
BLINKS PROBLEM MALFUNCTIONING PART
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Panel = Plasma Display Panel (Plasma Glass)
D Board = Format Converter / Plasma AL / Sub-Field Processor
DG Board = AC-DC Converter / Digital Signal Processor / Full HD
Microcumputer HDMI Interface / Peaks Lite 2
H Board = Speaker Out / Sound Processor
AV Terminal / AV Switch
P Board = Power Supply
PB Board = Fan Control
SC Board = Scan Drive
SD Board = Scan Out (Lower)
SS Board = Sustain Drive
SU Board = Scan Out (Upper)
Jun 11, 2009 | Panasonic (TH-50PZ700U) Television
Control panel not working Samsung refrigerator model rs2533sw. Not cooling.
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Apr 02, 2009 | Samsung Refrigerators
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? my new lcd monitor blinks on for 1 second then off but my...
Refresh rate may be set too high for LCD
hook up crt monitor
1. Open control panel-display
Click on settings tab and set to a lower screen res such as 800x600
Try lcd
2. Open control panel-display
click advanced button
click on monitor tab
set screen refresh rate to 60 hz
Try lcd
May 20, 2008 | Computers & Internet
Samsung RS2534 Side by Side Refrigerator Logo
13 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
