Question about Urbanears Medis Headphones-Cream
Urbanears wire loose problem - Urbanears Medis Headphones-Cream
2004 pontiac montana..had loose grd screw on batt..loosed support bar for fuse box and moved aside while tightening .now no inst working. radio is locked out..runs well..
Either pulled wire loose or blew fuse. At least you know area to look for loose wire. Find wiring diagram and the find color of wire for instruments that will narrow your search.
Oct 14, 2017 | Pontiac Cars & Trucks
While running a cleaning program it turned off and won't power up
You may have a loose power wire down in the electrical box on the dishwasher. Sometimes the wire nuts come loose if they are not securely fully. A loose wire may give it enough power to light the control panel and when the water valve turns ON the amperage increases, then the wires will push apart. This is because the two loose wires become magnetically similar poles and push apart. I have fixed many dishwashers by turning OFF the power to the dishwasher. Removing the lower kick panel opening up the electrical box, then removing the wire nuts, then reattach the wires together with the wire nuts again. Turn ON the power and see if the washer now works. If it does, then reassemble the dishwasher.
If this does not work, then you may have a loose wire connection in the control panel.
Sep 09, 2015 | Dishwashers
My compresssor keeps tripping the breaker>
Loose wire in panel box or loose wire around compressor. any loose wire causes a high amp draw which blows the breaker. I've found wires that look good but are loose. Go right to the compressor outside and check there first. pull disconnect first and make sure there is no power. you either have a shorted compressor or loose wire. if you ohm out compressor with power off and disconnect the three wires you will get something like this....one wire to other wire 2 ohms... same wire to other wire 3 ohms... other two wires you should get 5 ohms...2+3=5 good compressor.they will add up to each other.
Sep 28, 2014 | Heating & Cooling
How to fix an engine misfiring
this could be a lot of things. look under the hood for a loose plug wire. Look under the hood at night with the engine running to see if the spark plug wires are emitting sparks or are glowing. If so, do not touch the wires or you'll get a severe shock. Replace all the wires if they are bad. If the plug wires are okay, check for a loose wire or loose vacuum hose.
Nov 07, 2013 | 2002 Dodge Caravan
My benq dlp mp515 swithes on and goes off after few seconds, wht to do?
test the power cord for loose wires or break use the multimeter 2) test the fuse loose or c.breaker loose wires 3) main switch for faulty or loose wires resolder. 4) if the bulb is o.k or the filamente is break or faulty.
God bless you
Oct 29, 2013 | Hitachi CP-X260 LCD Projector
How to open earpiece of UrbanEars Medis earbud
I have a pair of marshall minor headphones. They are essentially the same headphones, very similar design if not identical. I had a short occur just where the cable enters into the ear piece, i was devastated when this happened. they are a good pair of headphones and i didn't want to have to shell out on another pair.
To open the earpiece, i first removed the silicone ear-click thingy. if you look in the recessed space where this fits, you will notice a clear join between the two pieces of plastic. I inserted a razor blade into this join and after very little effort i managed to separate the two halves. In doing so i actually poked the back plate off as well, i did actually try to get this off but didn't trust myself enough with the razor blade to continue.
there is another layer of plastic covering the circuit board in the ear piece, which again i would attempt to remove via the recess where the silicone ear-click piece goes. i only had a short in the cable so i didn't go as far as getting to the circuit board.
the whole earpiece consists of at least four main pieces of plastic which are held together by a series of plastic pins. with a little Araldite/ strong superglue you would never know i had opened the earpiece.
i can't believe there is nothing online about fixing these headphones. it's a shame, they are good headphones which have now been saved from the bin.
Nov 14, 2012 | Urbanears Medis Earphones
Lights not turning on
Check wiring, check wire nuts, check bulbs. it will be something simple.
Loose neutral wire.
Loose bulb, 3-way switch wired wrong.
Loose wire on breaker.
http://waterheatertimer.org/How-to-wire-switches.html
http://waterheatertimer.org/How-to-wire-GFCI.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Aug 25, 2012 | Electrical Supplies
Honda crv 2000, no instrument panel light, no park , front fog or tail lights. checked fuse(ok) but replaced anyway
check for loose negative wire on battery terminal, tighten if loose,
check your ignition switch, the accesories wire (positive) if loose/ re-connect it.
check for loose accesories harness wire- repair if nescessary.
Sep 17, 2011 | Honda CR-V Cars & Trucks
JBL 410 headphones broken
The same happened to me. JBL says that repair services are not available for this product according to their website. Their suggestion is to buy a new pair!!!!!. What a shame. JBL products are quite good but the post service is ****.
Apr 24, 2008 | JBL Reference 410 Headphones (Black)
Urbanears Medis Headphones-Cream Logo
Top Urbanears Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Urbanears Audio Player and Recorder Expert? Answer questions, earn points and help others
