Question about HP Pavilion Computers & Internet
Alarm beeps and orange light flashes when power is switched on.
Computer will not boot. As soon as the power is switched on the front; on switch turns oranges and flashes with a high pitch beep sound, alarm. No booting happens. No bios or windows 7 booting. Checked, all fans are working. Power, CPU , graphics, case.
    Problem Solver:
  • 7 Answers
If you unplug the power cord from the wall and the PSU, then flick the little red voltage switch on the back up and then back down again, plug it back in and it should work again
Posted on Feb 15, 2014
SOURCE: gx260 pc wont start
Either the motherboard or power supply are bad. I've had both be the cause of the problem. Check the motherboard for bulging and discolored capacitors. The same can be true of the power supply.
To the guy above who said his were out of warranty. If the motherboard is the cause of the problem, Dell will replace it until near the end of January. Just call them up and try to convince them. We are an educational customer, but everyone should be able to get it. It's a known defect.
Posted on Dec 18, 2007
  • 998 Answers
SOURCE: No display and wont boot
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Power supply is easier and cheaper to replace.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 12, 2008
OneRide
  • 379 Answers
SOURCE: unable to upgrade onboard graphics on dell gx520
Try disabling your onboard graphics in the BIOS. Some BIOS allow this. If you have a sound card, disable the onboard sound too. Count your beeps. they contain a code. Go online and "Google" bios codes. This should give you a starting point to diagnose the problem.
Posted on Oct 10, 2009
SOURCE: Dell Optiplex GX280 -ABC LIGHTS LIT UP IN BACK USB-HIGH FAN SPEED
system halted my pc help
Posted on Feb 25, 2010
drifterK
  • 4924 Answers
SOURCE: dell gx 520 long beeps and unable boot display?What's your problem?
Usually the beeps ore associated with ram memory failure ..or video card not being well plugged or being faulty ..To stat check the ram memory ..Just remove them all ..(if you have more modules) ..and after that insert one by one and try to boot ..If it still makes the same noise (beep ) and each one ..it means the ram is ok ..and the fault from other way ..If it starts with only one one ..it means the other is faulty ..Anyway ..usually the ram memory does not damage itself ..but most likely does not make contact well ..so plug them well back in the slot and try again ..
If it always make that beep ..try to see if you have a pci or agp or video card ..and if you do ..remove the card and post it back ..Usually if you remove it and you have a on board card ..you can already boot up if the card is faulty ..and use the card on board until you get another card ..
(the idea is that for the ram fault the beep is short and in some kinda loop ..but if it starts the fan and keep beeping it is the video card to blame .It is either out of slot and does not making contact well or is damaged and need to be replaced.
Posted on Dec 26, 2011
HP Pavilion not turning on, orange light and alarm sound.
Try a Hard reset!
1. Remove all connections from the computer including the power cable
2. Press and hold the power button for 20-30 seconds and then release
3. Only hook up the mouse, keyboard, monitor and power cable
4. Turn the computer
let me know what happens!
Oct 15, 2014 | HP Pavilion Computers & Internet
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
Precision T7400 power supply sounding an alarm
Did you open the case on your computer? It may have an open case alarm which is a small switch typically located near the edge of the cover you removed. Make sure the case cover is completely installed, then see if the alarm goes off.
Feb 28, 2013 | Dell POWER SUPPLY Power Supply
No power only orange power light
Hi, It most likely is a faulty power supply or a motherboard issue. Remove the power cord then press and hold the power button for at least 30 seconds. Then plug it back in and hit the power button. This will release any static buildup that might be in the computer and sometimes that causes it not to boot. If nothing is happening it is more likely your power supply than the motherboard.
Mar 19, 2012 | Dell Inspiron 530s Desktop Computer...
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
My Dell 100L will not switch on and battery will not charge.
since the LED is orange it might be a ram issue. try to locate the memory modules in your computer then try to reseat them. or if you have 2 ram modules try to remove 1 first then try to turn on the laptop check if it will do the same thing. then try removing 2 ram modules check if it will beep. if no beeps ask for mobo replacement. if it has beeps take note of the beep codes.
Oct 03, 2009 | Dell Latitude 100L Notebook
Both lights are blinking and will not print
they call that flash codes or error codes. please count
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Computers & Internet Logo
195 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
