Kenmore he2t 3H shows on the screen. the door will not open
jsrock516
  • 5911 Answers
SOURCE: KENMORE HE2T WASHING MACHINE
"F25" is a tachometer error. If the control unit is unable to detect the proper motor speed, the machine will shut down. You can attempt to unplug the washer for at least 30 minutes to reset the computer. Sometimes this is all that is required to correct momentary glitches. If the error reappears, the manufacturer recommends the following:
1. Check the wiring harness between the Central Control Unit, Motor Control Unit and Drive Motor to ensure they are all connected properly and not broken or loose. This would be connections L2 and N1 at the MCU and connector MS2 pins 1 and 2 at the CCU. (There is a wiring diagram inside the washer behind the lower kick panel).
2. Verify the Drive Motor is turning and the motor windings are good. Resistance checks at the drive motor connector acros Pins 1 to 2, 2 to 3, and 1 to 3 should all read about 6 ohms.
I hope this helps you.
PS I believe the tachometer is a physically attached to the drive motor.
Posted on Nov 12, 2008
Krazytech
  • 725 Answers
SOURCE: kenmore he2t error code 21
F21 is a long drain...it is taking too long to drain..you have a something slowing down the drain.. you can remove the bottom panel and clean out coin trap... if there is nothing then you may have another problem... but this is the most common problem..
Posted on Sep 23, 2009
  • 92 Answers
SOURCE: Kenmore HE2T Front Loading Washer Leaks From Door
there is a dispenser hose that goes in the tub.alot of times a sock or something gets inside that hose.that would cause your trouble.take the boot off the front and look up and left to see that hose.it comes out of the tub pretty easy.
Posted on Feb 04, 2010
  • 57 Answers
SOURCE: how do i replace the pump in a kenmore he2t front ...
The outlet pump can be easily identified by reverse tracing the outlet pipe most of the unit will have at the back of the unit so remove the back side cover you can see the pump two clips will be present one from the drum and another is connected to the outlet pipe just remove the clips then two screws will be presented kindly remove those to unfix the pump from the machine then you can easily replace the pump
Posted on May 19, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore HE2t Error Code F 01 flashes
sF01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Kenmore Washer HE2t model number 110 4756 11604 the door lock , light keep coming on and won't drain out
Usually that's an indication that the door lock assembly is bad and will have to be replaced
Nov 16, 2016 | Kenmore Washing Machines
I have a kenmore he2t washer that will not start. Door locks, buzzes for a minute then shuts off. No error codes. What could the problem be?
the door interlock is basicaly a heated switch
it locks then hold it locked
but there is a sensor to check its closed in the first place
i think the interlock sensor isnt right
replace the door interlock is the first step
http://www.ebay.co.uk/itm/WHIRLPOOL-SPORT-MAYTAG-EPICZ-KENMORE-HE2-Door-Lock-W10253483-46197023640-8540772-/141476775106?pt=LH_DefaultDomain_0&hash=item20f0ac44c2
here is one i found on ebay
its not cheep so shop around a bit now you know a few equivelant types .,.. and models
Dec 07, 2014 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
I have a Kenmore HE2t i keep getting error f21 i cleaned the trap and it still does it
You may have to unplug it for about 15 minutes and try again. I had a similar problem and this helped.
Mar 19, 2014 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
My he2t kenmore front load washing machine won't power on and there's a clicking noise
Vicki, i think that clicking sound is ok when you press start. TRY THIS.
1. close door securely 2. press power after putting detergent.3 After making your selction for different levels eg hot,warm cold, press START.
usually these buttons are pretty reliable, GL
Jan 12, 2014 | Kenmore Front Load Washer
My Kenmore HE2t washer locked it will not open after unplugging and pressing button to cancel after error message how do I get door opened
Try turning the machine on and manual advancing through a complete cycle. Then wait five minutes. Do this several times. If the problem persists, it would be best to get a qualified Technician to check the machine out.
Poppa
http://www.cdbaby.com/cd/poppamadison
Oct 04, 2013 | Kenmore HE2 Plus Front Load Washer
I have a he2t wash comes out smelling like mildew really tired of it please do not tell me to leave the door opened I do still smells
The trick is to clean the interior using regular detergent, baking soda, and hot water; run a complete cycle without any laundry in it. Wash the rubber boot where the door seals with same mixture at which point the interior should smell fresh and clean. Now is the time to leave the door open after use so that the remaining moisture can evaporate out to prevent mold growth. Hope this helps!
Sep 23, 2010 | Kenmore 44072 Front Load Washer
Our Kenmore HE2t reads F26 and stops running half way through cycle
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
Mar 09, 2010 | Kenmore HE2 Plus Front Load Washer
Feb 03, 2010 | Washing Machines
Every time I start my Kenmore HE2t washer there is
If it has a clean cycle that says, "Bleach Only," run it with 1/2 cup bleach right in the machine. If not, run it on the longest, hottest cycle you have. In the future, leave the door open slightly between loads.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
Fault code F20 on kenmore he2t clothes washer
I have a brand new front loader that never fill with water but shows F20. How can I get this machine to wash clothes?
Dec 29, 2007 | Washing Machines
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
