Question about NetGear DG834G Router
Connecting wifi radio - NetGear DG834G Router
In hotel and trying to connect to ATT WiFi. Firewall or other mechanism blocking connection.
Some hotels offer their customers free wifi. Many have it, but charge for it. Almost all have password protection to avoid the risks of being an open hot spot. If you contact the hotel desk, they should provide the wifi password if it is indeed free or explain what you need to do to gain access to the network otherwise.
Feb 19, 2016 | Logitech Squeezebox Radio
Can't connect to WIFI -- keep getting an authentication problem
It depends on the tablet that you have. Usually non branded tablets tends to have lots of problem. It also could be that the radio could be corrupted. Radio is what it take care or manage the wifi, data, etc... anything with connectivity.
I do suggest that your try to flash the radio again if possible. If not, try these next steps:
1. Go tot he wifi connection and tap on forget, this is to make sure that you don't have any wifi saved.
2. Reboot your tablet.
3. Now search for the wifi again, set it up with all the requirement, like password, channels, etc.
4. Wait until it display saved even if it doesn't connect.
5. Reboot your tablet.
6. Try to connect again to the saved wifi. If it still doesn't connect, your only option is to flash the radio band.
Dec 29, 2015 | Tablets & eReaders
Can't connect wifi
Some things to check
  1. Make sure WiFi is powered on
    1. Go to Windows CE desktop
    2. Click on wi-fi power icon
    3. Click 'Turn on'
  2. On Windows CE Task bar
    1. Double-click on WiFi (First from left)
    2. Click on 'Wireless Information' tab.
    3. Select your network from network list
    4. Double-click on i
    5. Enter your network credentials
    6. Press OK
    7. Right-click on your network name
    8. Press connect.
Dec 18, 2014 | Motorola Mc2180 Data Collection Terminal...
Grace Digital Mondo Wifi radio - plugged in, found my wifi connection, but when I enter my WEP Key, it just cirlces back to :Enter WEP Key. No errors received, just doesn't recognize my WEP K
Hi
You say that the radio keeps demanding the WEP key for your WiFi connection. WEP is just one of several security types to be used for WiFi. The fact that the radio is asking for a WEP key indicates to me that your WiFi is more than likely set to one of the other security standards such as WPA, WPA2-PSK etc etc etc. If this is the case your laptop and kindle etc will be using the same security standard as your WiFi router. To find out which security standard is being used in Windows 7, on your laptop, click on the active connection in the system tray to bring up the list of available connections and then click on "Open Network and Sharing Centre". When the Network Centre page comes up double click on the "Wireless Connection".
A status box will come up and about half way down is a utton "Wireless Properties". Click on this, and in the box that comes up click on the security tab and it will tell you the security type, the encryption type and the wireless key (click on "Show characters").
If the encryption type is not WEP then the radio will not connect to your WiFi, and the radio settings for Security and encryption need to be set to the same as on the laptop for it to connect.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 17, 2014 | Computers & Internet
Pico Wifi Internet Radio. Radio no longer connects to my WiFI...
First try making sure you are holding the reset button down long enough to reset the unit to factory settings. This can be up to 20 seconds. You will have to completely reconfigure the unit after that.
I hope this helps,
--Robert
Oct 28, 2014 | Revo Pico IR Portable Wi-Fi Internet Radio...
Aluratek AIREC01F will not connect to wifi
first need more info is this a secure router connection...does it require a password to login to. if no then i'd refer to this link make sure you meet tehe requirments.
http://aluratek.com/wifi-wireless-internet-radio-tuner-home-theater
if yes i would make sure you entered in the correct password on your new device and if you did try a reboot to clear any possible communication error sit may have gotten.
Aug 20, 2012 | Aluratek AIREC01F WiFi Internet Radio -...
Not able to connect wifi in my lapopo
In connecting through a wifi, there are two factors to consider. (1) Wireless Router broadcast and (2) Wireless Receiver.
Make sure that your network router is broadcasting wireless internet or wifi. Also, you have to know if you need a pass key or password in order to connect to the wireless network.
Now, given that there is a wifi spot, your laptop should automatically recognize the wifi broadcast and negotiate connection without your intervention. This will only happen IF AND ONLY IF your laptop has a wifi radio receiver and that it is TURNED ON. When it is turned ON, it will connect you immediately if the network has no pass key set. If there is, then you have to enter that key when you try to manually connect it. (Right click on wireless network icon on system tray. Then it should say: Wireless Network Available. Then Click CONNECT)
To turn your wifi radio receiver ON, slide a switch button to ON position depending on your laptop model. If you dont have that kind of switch, look for the wifi icon printed in the keyboard keys. In some laptop, it is in F2. Now Press FN+F2 to turn wifi radio receiever ON and OFF.
Feb 04, 2010 | Toshiba Satellite A100-S8111TD Notebook
How do I turn the radio on the wireless card
When your computer is switched on, the WiFi radio is almost always transmitting or receiving signals. In certain situations, as in an airplane, signals from the radio may cause interference. Use the following methods if you need to disable the radio and use your notebook without emitting radio signals.
Use the Optional Computer Radio On or Off Switch
If your computer has an external switch installed, use it to switch the WiFi radio on or off. See the computer manufacturer for more information about this switch. If you have Intel® PROSet/Wireless installed, the current state of the radio displays in the Intel PROSet/Wireless main window and on the Taskbar.
Use Intel PROSet/Wireless to Switch the WiFi Radio On or Off
From Intel PROSet/Wireless, the WiFi radio can be switched on or off. The status icon on Intel PROSet/Wireless displays the current state of the radio.
To start Intel® PROSet/Wireless, use one of the following methods:
  • Click Start > Programs > Intel PROSet Wireless > WiFi Connection Utility.
  • Right-click the Taskbar icon prosettaskbaricon1.jpg located in the lower right corner of your Windows* Desktop to open the Taskbar menu. Click Configure WiFi.
  • Double-click the Taskbar icon to open Intel PROSet/Wireless.
Switch the WiFi Radio On or Off from the Taskbar Icon
To switch the WiFi radio on or off, click the Taskbar icon image1_ipswtaskbaricon.jpg and select WiFi On or WiFi Off.
How to use the Device Manager to Disable the WiFi Radio
The WiFi radio can be disabled (made non-functional) from the Windows* Device Manager.
Note: If you disabled the WiFi radio from Windows*, then you must use Windows to turn the radio on. You cannot use a hardware switch or Intel PROSet/Wireless to enable the radio again.
Windows* XP
  1. From your desktop, right-click My Computer.
  2. Click Properties.
  3. Click Hardware.
  4. Click Device Manager.
  5. Double-click Network adapters and expand the selection by clicking the Plus symbol.
  6. Right-click the installed WiFi adapter.
  7. Choose Disable from the menu.
  8. Click OK.
Windows Vista*
  1. Use Control Panel > Mobile PC > Adjust commonly used mobility settings (if you use Classic View, select Control Panel > Power Options.
  2. Click Turn Wireless Off .
Hope this helps !
Jul 03, 2009 | Acer Aspire 3000 Notebook
I am unable to connect my acer aspire to a my existing wireless connection
I have two Acer Aspire One Netbooks: x1 10.1" and x1 8.9". The switch located on the very front right edge of these Netbooks is quite tricky to get it to actually switch the WiFi radio ON / OFF. Double check that switch position and since it is spring-loaded, you will have to try to see the tiny green light flickering if WiFi radio is active. The green ON (active radio) lamp is TINY and dim at best even when Brand new.
Also, if I have had the radio OFF and / or the Wireless connection 'disabled" on purpose, both of my Netbooks require a full hard boot before they will again connect to WiFi.
Hope this helps!
Good Luck
MFied
Lakeway, TX
Apr 19, 2009 | Acer Aspire One Netbook 8.9" Notebook
Wireless adapter radio
Windows* XP
  3. Click Hardware.
  8. Click OK.
Windows Vista*
Nov 05, 2008 | Acer Aspire 3000 Notebook
NetGear DG834G Router Logo
16 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
