Question about Foxconn K7S741MG-6L Motherboard
9 pin port connection of k7s741mg model - Foxconn K7S741MG-6L Motherboard
2 Suggested Answers
myob247
  • 1342 Answers
SOURCE: Pin Outs
Get your manual and drivers HERE
Posted on May 20, 2008
Acer 4720Z not charging, port is not damaged neither pin
Check if the led indicator is on, when you connect your adapter to power outlet. It may simply be loose connection between the adapter and connecting cord.
If possible, borrow adapter of same make and model from someone (maybe a friend who owns the same laptop) to ensure, that the port is not damaged.
If the port is all good, I suggest you get your adapter replaced, as repairing it is not worth the hassle.
-Meet.
Oct 06, 2013 | Acer Computers & Internet
Where is the diagnostic port located on a 2000 fiat marea
on a 99 2.0 model you will have 2 diagnostic ports. both of them will be the fiat 3 pin type.
to connect the 3 pin fiat connector to a 16 pin obd2 connector you need 4 lengths of wire. use 3 lengths of wire to connect the 3 pin connector to the obd connector. also use 1 length of wire for power to the obd connector.
on the 16 pin obd2 connector use the following pins
4- chassis ground (connect to ground on 3 pin connector, or any good chassis earth)
5- signal ground (connect to black wire pin on 3 pin connector)
7- k line (connect to white wire pin on 3 pin connector)
16- 12vDC (connect to battery positive terminal)
Apr 08, 2013 | Cars & Trucks
WHERE DO I CONNECT THE PWER SWITCH PIN ON WINFAST MOTHERBOARD
hai, i am using winfast motherboard pc and i was remove my cpu all wire so please tell me about how to connect the power switch wire and restart wire
Oct 28, 2012 | Foxconn WinFast K7S741MG Motherboard for...
Where do i plug in the connector for the power button?
You can find it on the bottom right part of the motherboard below the memory ports. It will be called FP1. It will be the upper 3rd and 4th pin. It may say PSWITCH above it. If you want a diagram, you can find it in the manual at the link listed below:
http://www.foxconnsupport.com/download.aspx?models=en-us0000129&category=C000000001&brand=en-us0000002&Series=en-us0000006&chipset=en-us0000058&keywords=&sort=
You will see it under File Downloads. It will be on page 4 of the manual. Hope this helps!
Mar 31, 2012 | Foxconn WinFast K7S741MG Motherboard for...
Plz tell me the front usb port connection of my gigabyte motherboard intel 875/865/848p
In the motherboard of any models, there are only two ro four onboard fix ports. Another ports is not the part of Motherboard, there are only free ports pin on motherboards. your cabinet ports connect with there open pin ports.,
Mar 28, 2010 | MSI 848P Neo-V Motherboard
Does this have a firewire port, if so what does it look like?
Depending on the model, yes it does have a firewire port. The firewire port is also known as a IEEE-1394 connection. There are 2 possible layouts for this port, 6 pin and 4 pin. Below is a link to an image that shows what the 2 different ports look like. The larger 1 is a 6 pin and the small is 4 pin.
http://en.wikipedia.org/wiki/File:FireWire-46_Diagram.svg
Hope this helps.
Apr 20, 2009 | Computers & Internet
Connections
see if ur both devices ur laptop and ur camera has firewire 1394 port it is like mini usb port but check out the pins is it 4 pins normally it is 4 pins it is called firewire cable then u can connect directly ur camera to laptop and capture thru firewire port if u dont hv firewire port in laptop or camera let me know we can work on other ways after connection contact me for further instructions of cap video on pc
pls rate me FIXYA if i fixed ur problem
pls reply with camera model and laptop model u have
Mar 07, 2009 | Panasonic NV-DA1 Mini DV Digital Camcorder
Utilities Disk for WinFast K7S741MG motherboard
Click on this link and it will take you to the support page for foxconn motherboards. There will be 2 options: Search by product model and search by download type. Type in K7S741MG-6L in the keyword space. Then where it says select type, select under Motherboard, I-drivers and click search.
To the bottom will display the drivers for this particular motherboard.
Hope this solves your driver problems.
Lolita
Jun 18, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Pin Outs
May 20, 2008 | Foxconn K7S741MG-6L Motherboard
Foxconn K7S741MG-6L Motherboard Logo
15 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
