Question about Crosley CR49-TW Tweed Traveler Turntable CD Player
Crosley CR49 turntable does not play sound loud enough to hear
2 Suggested Answers
  • 6 Answers
SOURCE: Crosley CR49 Turntable Speed Problem
Do you know how to make a measurement? open your equipment, use your voltmeter to see how much voltage run the motor and then compare with the voltage who is written in the motor. If the voltage which your have read is in the range of motor voltage +- 10% is ok, of no, that voltage must be more than that correct that problem.
If the voltage is the range of motor voltage the replace the motor.
Thank you.
Tell me if this helped you
Posted on Mar 04, 2008
My turntable a Crosley CR49 is about 14 years old. It plays just fine, but have to manually reset, clicking the tone arm after every record I play, either 45s or 33 1/3. How Can I fix this?
You will need to get to the underside of the turntable. There you should find that the arm when it gets to the centre of the record it will push on a switch. This switch might be out of position or just get stuck by grease or dirt. Correcting it should solve the problem.
Dec 08, 2015 | Crosley Audio Players & Recorders
My crosley keepsake turntable has been having a lot of static and the sound is very low, I can only hear it if I turn the volume all the way up. I'm not sure if the needle is the problem or there is s
I would check the wires to the cartridge. It might that one or more is off or loose.
If you turn down the volume completely and listen with a record playing you should be able to hear (with your ear) the stylus in the grooves of the record playing the track. Pick a loud (rock) record for this. If it does that OK the stylus is good.
Dec 26, 2014 | Crosley Keepsake USB Turntable
My Crosley CR49-TA won't revolve. It turns on, and
Most turntables are belt driven. Suggest you take a look inside but remember to unplug the deck first. Usually it's a simple case of slipping the belt back on.
Apr 26, 2013 | Audio Players & Recorders
Crosley turntable CR49
Check if it is still covered under the manufactures warranty, you might be able to send it in and have it fixed. Although, I am not sure if they would ship it back to Dubai. Contact customer support and ask them what are your options.
Tech Support: http://www.crosleyradio.com/supportreq.aspx
Warrenty registration: http://www.crosleyradio.com/wreg.aspx
Nov 25, 2012 | Audio Players & Recorders
Crosley Turntable Repeating little bits?
Is this on all records? if yes! you need to adjust the weight slightly, if the problem is with one record, clean the record in luke warm water and dry carefully, may solve the problem.
Apr 16, 2012 | Crosley CR49 Traveler Portable Turntable...
Belt came off on my crosley cr49 record player
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Aug 29, 2009 | Crosley CR49-TW Tweed Traveler Turntable...
Thank you.
Mar 03, 2008 | Crosley CR49-TW Tweed Traveler Turntable...
AC adaptor cord
Try a Radio Shack universal replacement power supply like 273-1773 or 273-1776 or 273-1667 with the proper "Adaptaplug" that goes with it. It should do nicely and be sure to observer the proper polarity of the plug so that it will match your unit. Good luck.
Feb 03, 2007 | Crosley CR49 Shelf System
Crosley CR49-TW Tweed Traveler Turntable CD Player Logo
43 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
