Question about Brother CS-6000
Right hand wheel on side of sewing maching is hard to turn
Right hand wheel is hard to turn
2 Suggested Answers
SOURCE: brother overlock sewing machine the hand wheel hard to turn how can we fix this
most of the time when the hand wheel is hard to turn, it needs to be serviced, to see if it needs cleaning or if there is some damaged part inside
Posted on Mar 20, 2012
Brother sewing maching
On the hand wheel there is the lock that is used to stop and start the needle from being used. This is necessary for refilling the bobbin with thread. If the hand wheel doesn't make the needle work then you will need to do some minor adjustment.
1. On the hand wheel find a small screw and loosen it until it is just about ready to remove.
2. Now tighten the hand wheel.
3. Tighten the small screw again.
It should be ready to use now.
Aug 31, 2016 | Brother Sewing Machines
How do I wind the bobbin?
There are several ways. On most machines you put the empty bobbin on the spine over the bulk of the machine on the right hand side. Twist some threads around the bobbin to get started, then put the thread through the thread loop above the shuttle area on your left side. That keeps the tread tension right. There is a gear the clicks into the bobbin. You push that closed. You will have to release the clutch by turning the large wheel on your right hand side. Not hard to find and it usually is hand size. It is the one that goes around and around when you are sewing. Grasp it firmly and turn the top toward you. This will prevent the needle from going up and down when the thread is pulled onto the bobbin. Don't forget to tighten the large "wheel" when you are done.
Feb 24, 2015 | Sewing Machines
I have a husqvarna H Class E10 sewing machine. The hand wheel has tighten up on me. I can not loosen it.
I suspect the main bearings and other rotating parts need to be cleaned of old lubricant and regreased. This obviously requires dsassembly of the maching. Unless you're a mechanic, leave it to the repair person.
Feb 21, 2013 | Husqvarna Sewing Machines
Brother overlock sewing machine the hand wheel hard to turn how can we fix this
Mar 20, 2012 | Brother Sewing Machines
I have a Pixie sewing machine that will not sew. It appears that top thread is not connecting with bobbin thread. When I just slowly turn the hand wheel I am hearing a little snap and I feel a little...
If you are sure that you are using the correct needles and they are
correctly inserted, have the timing of the bobbin case checked on your
machine.
Feb 23, 2011 | Singer Sewing Machines
Hand wheel is hard to turn
If you take out the bobbin case and slide off the needle pate, you can inspect the bottom area for a thread jam. The black post that the bobbin case slides onto is called the thread hook. It should have a loose feel to it when you gently move it around, it should not have a "solid feel".
Another area that sometimes wraps the thread is the take up lever area.
(the lever that moves really fast up and down as the machine is sewing)
If the lever has been pushed to the left, it's possible the thread has wrapped up in that area.
If those two areas are o.k. you'll need to take it in for service.
Oct 16, 2009 | Husqvarna Viking 1
Balance wheel on sewing maching does not turn
hi have you recently refill bobbin seems like you need to reengage clutch tighten inner wheel on hand wheel or slide switch depending on machine refer to your manual good luck
mary h
Dec 27, 2008 | Sewing Machines
Brother CS-6000 Logo
22 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
