Question about Frigidaire Kenmore Washer Tub to Pump Hose 134455900
Kenmore microwave model 721.8975590 went dead
Will not work no clock or power
MicrowaveSvc
  • 9085 Answers
SOURCE: Kenmore 665.61629100 Microwave Problem
The 665 prefix on your model number is Whirlpool, but I haven't found the code "d" listed yet.
Can you set the cooking time?
If so, what happens when you press Start?
I'll post back if I find the codes or if you have other info and I can help further.
Posted on Oct 22, 2007
MicrowaveSvc
  • 9085 Answers
SOURCE: Kenmore 66561629100
F2 in this case means you have a bad or contaminated keypad (a.k.a. membrane switch).
Is it possible that some spray cleaner accidentally got into the controls?
I always recommend that users spray the cleaner on a soft cloth (not on the keypad itself) then wipe the control panel off.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
In many case, the damaged keypad must be replaced.
This is not too hard a job for a DIYer.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full Kenmore model number here: http://www3.sears.com
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 30, 2007
brainyass
  • 242 Answers
SOURCE: Kenmore 565.6050.9990 microwave dead
Start taking all screws out until you can access fuse.
Posted on Sep 17, 2008
SOURCE: Kenmore microwave - unresponsive keypad
Repaired the unresponsive keypad on my older Kenmore (model 721.68100): Unplug. Remove integral cover for top and sides which is held in place by 5 metal screws. The cover then slides toward the rear. Unplug two connectors to back of keypad and clean them (I used contact spray cleaner). Some of the components retain a charge even when unplugged.
Posted on Jul 11, 2010
  • 33 Answers
SOURCE: Kenmore microwave oven model # 721 63684300 built
I checked the owners manual and it does not list the fault codes. Manufactures leave this information out of the manual most of the time so you have to call them for service.
Call 1-800-4-my-home (sears) and tell them the problem. You will also need to provide the m# so have that ready when you call.
Good Luck
Posted on Dec 20, 2010
Why Kenmore microwave oven (model 80089700) start/enter button not working while all other buttons works fine?
Safety system locking out the start switch. Door not closed, mode and timer not set etc.
Apr 10, 2017 | Kenmore Microwave Ovens
Multi purpose oven won't work after power cut have reset clock, light won't work. Is making all the right sounds just won work
power supply from clock damaged not by power cut but voltage spike when power resumed the oven thinks its in auto mode permanentley thats why it wont come on ,new clock or power board needed.
Feb 03, 2017 | Neff Ovens
Lost power to my house, came back on outlet has power clock on radio works radio has no power. wall clock on same outlet works fine
There is a battery backuo in the radio. This is probably powering the clock. It looks like the radio power supply is either fried or the hardwired fuse is blown.
Take a look at the manual. If you take out the battery back up does the clock still work? GPX MP3 Player KC232S user manual
Apr 12, 2015 | Audio Players & Recorders
Bottom oven stopped working. Clock display is totally blank but we have power to the oven as grill & top fan still coming on.
No make or model all pretty much the same oven power fed from clock/control either and open fuse feeding power to clock or bad clock have seen burnt wires going to clock
Apr 03, 2015 | Ovens
I just got a Bradford Exchange Purr-fect Moments Kitten Cuckoo Clock and the battery powered clock movement doesn't work. I need to get a new clock movement with the wire that connects it to the bird
Bradford is a high end retailer. You can contact them because if the item is not over a year old then it is warrantied. The other thing is you can email them to see about the clock works inside the unit. See this page and look for "contact us" at the bottom.
Jan 05, 2015 | Watches
Why would my kenmore micro wave model 721.66463500 just go dead, no power
There may be a weakened connection around the main power supply 'Transformer'. Sometimes the connections can overheat but if they are removed and replaced it may again make contact. I've had a similar problem and found parts from similar brands to replace the connecting/wiring parts. I soon realized that I could have removed the extra pieces around the wires without causing any electrical problems. That is the minor repair. The major repair would be to replace one of the main features (large or small) which assist the transformer in power functions. Take your time examining the tiniest parts and pieces.
Jun 23, 2014 | Kenmore 62622 Microwave Oven
Clock does not work but load does
really need more info. but assuming that ur turn it by hand to turn it on and off, it sounds as tho u have no power on the clock or the clock is bad. is it new? is it old and the clock quit, or new and the clock doesn't work? in this case may not have power to clock.
Mar 15, 2014 | Intermatic T104 24h 208-277v Mechanical...
Clock wont turn on
USA car, not all cars are wired the same. (my answers are USA)
ok you lost power to the clock (factory clock?)
so check ALL fuses.
the clock as about 3 pins.
1: ground.
2: Park lamp , 12v or less if dash dimmed in park mode.
3: power to clock.
if ground reads 12v, the ground is open
if #3 is not 12v, that feed wire, is dead.
the feed wires are called Honda, power distribution
the schematic is free for honda's (use a voltmeter to trace the voltage drop) (cut wires, for alarm or other hacks)
free
http://hondatech.info/downloads/Auto/Manuals/Accord/
its there, see the clock pages.
Nov 09, 2013 | 1993 Honda Accord
Kenmore solid state microwave
Every machine can be repaire but with some costs..
Now ..becaus ethe light was off..now you have problems with the board..or display..
Thanks God is exchangeable
Check the internet by part no. and you'll find it
Good luck
Jul 02, 2013 | Dishwashers
Frigidaire Kenmore Washer Tub to Pump Hose 134455900 Logo
47 people viewed this question
Top Kenmore Vehicle Parts & Accessories Experts
Tom Chichester
Jim Rus
Jim Rus
Matt
Are you a Kenmore Vehicle Part and Accessory Expert? Answer questions, earn points and help others
