Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
PO102 MASS AIR FLOW CIRCUIT SIGNAL LOW 1997 CHEVY 5.7
leetamara
  • 702 Answers
SOURCE: having problems with my 96 chevy tahoe mass air flow
The MAF (Mass Air Flow) sensor is a very common problem with these along with the pickups. This isn't what you would call an inexpensive part. Definitely do some shopping before you buy one.
Posted on Nov 10, 2008
  • 5 Answers
SOURCE: looking to findthe mass air flow sensor on a 89 chevy corsica
location is under the hood where the aircleaner is there is an electrical connection that plugs into the mass air flow sensor
Posted on Oct 09, 2009
mlapres
  • 757 Answers
SOURCE: mass air flow sensor
The mass airflow sensor is very important...it uses tiny diodes mounted in the flow path of the incoming air to the throttle body in units called CFM. It sends that information to the engine computer and the program calculates the proper amount of fuel needed to mix with the volume of air coming in. It is vital to your car that this sensor is properly maintained. If it's diodes are allowed to get dirty such as by having a dirty air filter, then the readings it takes will be inaccurate and the cars' performance will suffer. If the diodes break, you will not be able to drive the car and a new sensor is expensive.
DO NOT buy into snake-oil products like MAF cleaner...it is an expensive gimmick plus spraying anything under pressure into the sensor can break the diode filaments, some of them are barely .010" thick. Just remove the sensor with the proper bit and carefully poor a stream of isopropyl alcohol (isohol, rubbing alcohol) over the diodes until they shine. Then rinse with water and let air dry.
Posted on Dec 15, 2009
  • 262 Answers
SOURCE: where is mass air flow sensor located on 2002
The mass air flow (MAF) sensor is an integral part of the throttle body assembly and cannot be serviced separately. For replacement of the MAF sensor refer to Throttle Body Assembly Replacement.
Posted on Feb 25, 2010
Molson02536
  • 3854 Answers
SOURCE: 98 chevy suburban, code reads mass air flow sensor
Check the wire leads and clean them before reconnecting the wire leads. It wouldn't hurt also to clean the MAF sensor with MAF cleaner, the code your getting is most common to the high performance oil base filters like K&N.
Good luck and this should help you resolve your MAF issues. Thank you for using Fixya
Posted on Mar 12, 2010
Chevy 3500HD PO102, PO108, PO113,P2563 Came on in cruise at 75 with car hauler load 6500lb max. Reduced power, had to get off interstate. 2007 w/ 147K miles.
P0102-mass or volume air flow circuit low input
p0108-manifold absolute pressure/barometric pressure circuit high input
P0113-intake air temperature circuit high input
p2563-turbocharger boost control position sensor'a' circuit range/performance
Feb 14, 2017 | Chevrolet 3500 Cars & Trucks
1997 gmc sierra fix the code po102
code po102 refers to mass air flow(MAF) sensor/volume air flow (VAF) sensor---low input======causes --wiring short to ground---MAF/VAF sensor ---ECM
Feb 22, 2015 | GMC Sierra Cars & Trucks
What do all these codes mean PO135-PO300-PO404-PO102-PO440
po135 is o2 sencer on drivers side. will be the first one. po300 is random/multiple misfire.po404 is a egr code. po102 mass air flow circuit low input. po440 evap emission control system malfunction
Dec 23, 2012 | Cars & Trucks
I am getting p0030 , p0036. po102 and p0443 on my 2007 chevy uplander ,
I think the first thing I would do is clear the codes and see how many come back after you drive it.
Code 30 and 36 are for the heater circuit in the O2 sensors on bank one. I doubt it would be both sensors, so it may be a wiring problem.
Code 102 is for a low signal from the mass air flow meter which could also be a wiring problem or the sensor or a dirty air filter.
Code 443 is for a problem with the evap purge solenoid circuit which again could be a wiring problem or the solenoid.
Sep 02, 2012 | Chevrolet Uplander Cars & Trucks
Diagnostic trouble codes dtc po420 po102
CODE PO102 IS MAF SENSOR CIRCUIT LOW FREQUENCY CONDITIONS / CODE PO420 IS CATALYST SYSTEM LOW EFFICIENCY BANK 1 CONDITIONS. BAD MASS AIR FLOW SENSOR WILL AFFECT CONTAMINATE DAMAGE CATALYTIC CONVERTER DUE TO RICH EXHAUST EMISSIONS.
Jan 26, 2011 | 1997 GMC Jimmy
102 check engine on
po102 mass air flow sensor circuit low input
Feb 20, 2010 | 1997 Chevrolet Tahoe
What is the code PO102 on a 2002 Chevrolet Impala
code PO102 is mass air flow sensor circuit low frequency condition.what it is saying.MAF sensor element hot wire contaminated or sensor failed.MAF sensor signal shorted to ground or grounded circuit problem.MAF sensor wiring routed close to ignition wires generator solenoids or electric motors.PCM has failed.
Jul 14, 2009 | 2002 Chevrolet Impala
Generic code reader returns PO102 code on 1998 volvo v70. what does this mean?
Mass or volume air flow circuit low voltage. mass air flow sensor could be going bad, or the wires are bad, damaged, disconnected. it could also mean your air filter is cloged
Jun 24, 2009 | 2004 Volvo S60
Po102 mass or volume air flow circuit low input
did it have the same code before you change the 02 sensor .cause it should of been po135 for an 02 sensor 1 bank .the mass is the one in the air breather
Feb 16, 2009 | 1996 Volkswagen Jetta
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
16 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
