Question about Boating
I have a shake spear wonder troll 909 solid state oat sereal 02669 what size motor do I have
2 Suggested Answers
  • 10 Answers
SOURCE: Replacement of motorguide trolling motor prop
Motor Guide hubs come in two different sizes - 3" and 3.5". The 3" size is more for older and lower thrust models. Newer units use the 3.5. The size differences are between manufacturers too. MinnKota's are a little bigger. If you order a new prop, the only issue may be the depth of the prop. I had to use a longer prop nut wrench to tighten the Hydrilla Hacker I purchased.
Triton72
Posted on Mar 26, 2009
I have a motorguide fw71 fb bow-mounted trolling motor which I believe is receiving a short somewhere. I have the batteries hooked up right with a 30amp breaker going to each and often when I troll on...
Using an ammeter check for current draw and compare that with specs to determine if your draw is excessive. If motor has ever overheated and some of the windings have had the insulation burn off you will have a motor with less resistance and it will draw more current since less back emf is being generated.. Under those circumstances it can overheat and also blow existing fuses. Should that be the case you are looking at shopping for a new motor.
Apr 18, 2017 | MotorGuide FW71 FB Freshwater Series...
Burning out fuses on trolling motor at battery
not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
Oct 29, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
MY TRUCK SHAKES UNDER ENGINE LOAD. THE MOTOR MOUNTS ARE GOOD. I WAS WONDERING IF I NEEDED A CARRRIER BEARING. ITS A 1980 FORD F100 WITH THE 351 WINDSOR AND 3 SPEED AUTO. AND WHAT SIZE DO I NEED THE 35MM OR...
Check the driveshaft u-joints also. They will cause a solid vibration when under acceleration load and go away when coasting. As for that carrier beariing, its best to lefdt a shop that balances driveshafts handle that so thatthey can rebalnce the shaft after the repairs are done.
Jul 20, 2009 | Ford F-100 Cars & Trucks
New MotorGuide VariMAX trolling motor does not run
The motor should work without the circuit breaker for a test. The breaker is a safety device to protect the motor and wires if something malfunctions.
May 23, 2009 | MotorGuide Electrical Supplies
Triton72
Mar 26, 2009 | Boating
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
