Question about Hitachi Gst Hitachi CP-X3511 XGA 3LCD Projector, 3500 ANSI Lumens, 1024 x 768 Resolution, 2000:1 Contrast Ratio, IR Wireless with Remote Mouse Function
How to connect with macbook pro - Hitachi Gst Hitachi CP-X3511 XGA 3LCD Projector, 3500 ANSI Lumens, 1024 x 768 Resolution, 2000:1 Contrast Ratio, IR Wireless with Remote Mouse Function
Tip
MacBook Pro Display housing coming off
If you don't want to spend a lot fixing your old macbook, this is an easy way to do it!
I hope it can help you.
keywords
MacBook Pro Display housing coming off fix
MacBook Pro display housing partly unattached fix
Macbook pro screen separating from the case fix
MacBook Pro unibody housing fix
Macbook Pro screen separation problem fix
MacBook Pro screen glass coming off fix
Broken MacBook Pro hinge fix
on Jan 29, 2016 | Apple Macbook Pro 13 - Brushed Titanium -...
What do I use to connect Macbook pro to an Epson EMP projector?
you need a cable:
type depends on your macbook pro model and epson:
use-connect-macbook-pro-epson-emp-rd53xsmc3ry4fozipcd12amw-5-2.jpg use-connect-macbook-pro-epson-emp-rd53xsmc3ry4fozipcd12amw-5-5.jpg use-connect-macbook-pro-epson-emp-rd53xsmc3ry4fozipcd12amw-5-9.jpg
Nov 29, 2012 | Epson EMP-S1H Projector
Ms9535 won't connect to macbook pro
Apple don't allow anything to link to Macbook's via bluetooth. I can't even connect my iPhone 4 to my Macbook Pro unless I connect it with a USB cable.
Nov 11, 2012 | Metrologic MS9535 Voyager BT Accessories...
I have macbook pro version 10.6.6 and i have reliance netconnect usb connection. but i am having problem after few mins using internet my laptop shows a message that i need to shut down the compter and...
I too have macbook pro version 10.6.6 and i have reliance netconnect usb connection. but i am having problem after few mins using internet my laptop shows a message that i need to shut down the compter and restart again. its happening all the time.
please advise what i need to fix this problem. i think some drivers compatible with macbook pro
Apr 17, 2011 | Computers & Internet
Connecting LE26R8 to MacBook Pro
Hi.
LE26R8 its a Samsung LCD TV.
You can Connect a LCD TV to MacBook Pro.
You need a mini dvi to dvi or mini dvi to vga depending on your monitor. You also need a cable to get the sound to the tv from the macbook (from headphone output specifically)
Also Watch this video its a Tutorial to How Connect a LCD TV to MacBook Pro.
The Video:
(do not delete)
Good Luck.
Nov 03, 2009 | Samsung Audio Players & Recorders
I want to connect my Macbook Pro (Mac OS 10.5) with my Onkyo Receiver via Toslink optical cable. How could I do?
There is an optical cable that you can buy. It needs to have a MINIPLUG on the one end and a standard Toslink on the other. This will give you the digital audio out of the MacBook Pro.
A company called Proel make the cable you need in varying lenghts.
www.proelgroup.com
Hope this helps
Verb
May 26, 2009 | Apple MacBook Pro Notebook
Conia plasma 42inch connecting to macbook pro - ??
Hi, i also have a conia plasma (and sony 510 amp). Which video connection are you using? DVI-VGA? DVI-component? Note that the tv probably defaults to using YPBR rather than VGA so you may need to play with settings in the menu ...
Aug 12, 2008 | Sony STR-DG510 Receiver
Macbook pro + IBM m4000
Depends on the connections you have on both. Most MacBook Pros have a DVI connector on the side. If the IBM projector takes that sort of input, then all you need is that cable.
If the IBM projector has a VGA input, then you'll need an adaptor from DVI to VGA.
(VGA input is standard monitor looking connector.)
Jul 26, 2008 | Apple MacBook Pro Notebook
Hitachi Gst Hitachi CP-X3511 XGA 3LCD Projector, 3500 ANSI Lumens, 1024 x 768 Resolution, 2000:1 Contrast Ratio, IR Wireless with Remote Mouse Function Logo
Top Hitachi Gst Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Gst Office Equipment and Supply Expert? Answer questions, earn points and help others
