Question about Harman Kardon Audio Players & Recorders
Buzzing sound when receiver on - Harman Kardon Audio Players & Recorders
Realistic STA-2150 Receiver - Making buzzing noise through speakers
The problem may go away when the turntable ground wire is disconnected from the receiver.
Jun 26, 2017 | The Audio Players & Recorders
BUZZING WITH NO SOUND
The audio outputs in the receiver are bad, and will need to be replaced.
Apr 08, 2012 | Marantz SR6005
Loud Buzzing Sound
This may be a power supply failure, and or a short in the output stage, and in the drivers for the output stage.
This is not a repair you can do at home unless you have a lot of experience in troubshooting and analysing problems in power amplifier equipment.
Jerry G.
May 04, 2008 | Onkyo TX-SR875 Receiver
Technics sax-710 receiver Nht sb-1 speaker developed a buzzing sound when playing, Kids may have over drove speakers(not sure) Replaced with nht supezeros now both speakers sound very staticy like off...
The speakers have buzzing sound because of damaged cones.
Over driving speakers, especially with heavy low frequencies, can tear the voice coil away from the cone.
Once damaged, only replacement will help
Apr 24, 2008 | Audio Players & Recorders
Hk3480 buzzing
Is the buzzing coming over the speakers or just from the receiver itself?
If over the speakers:
Try swapping ports on the receiver from the DVD. Go from DVD into an auxiliary video or VCR 2 if available.
Try swapping out the cables with known good ones.
But do this in steps to be able to nail down the problem and not just leave a mystery.
If the sound is solely coming from the receiver it could be a dusty fan. Blow it out with compressed air ,With the Power Off.
Or, my favorite, might just have to crank it up so you can't hear the buzzing.
good luck
COEch
Mar 11, 2008 | Harman Kardon HK 3480 Receiver
Buzzing Sound when calling or receiving a call
could be that your earpiece is faulty so yu should take it to a mobile service center and have them check it for you.
Feb 16, 2008 | Samsung SGH-E370 Cellular Phone
YAMAHA R-V701 MAKES BUZZING SOUND & WONT TURN ON
This could be the indication of an open resistor, or bad Capacitor in power supply. May not be visible to eye, but if you look in PS. there should be atleast one big sized cap and every PS has a bridge rectifier, this is usually 4 diodes in series, check them and see if any open, shorted
Sep 05, 2007 | Yamaha R-V701 Receiver
Speakers started buzzing.
It sound like your getting AC noise, chances are you have some dried out capacitors
Dec 13, 2005 | Aiwa AV-DV70 5.1 Channels Receiver
13 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
