Question about LG WM3470HWA Front Load Washer WM3470HWA
Water leaking from filter cap
Washer starts up takes water in then does its test cycle then dispenses water back out drain, water is leaking around the filter cap in the lower left corner. Checked the cap and gasket both were fine, no debris in or on threads. replaced drain pump motor still leaks water around cap,
SOURCE: Leak problem
Ours did same thing after nearly same amount of time.
Run a couple of sanitary cycles without any cloths.
Only use HE detergent.
Problem stopped after this
Posted on Oct 25, 2007
SOURCE: Water leaking from the door and door will not unlock after washing
i just placed my order @ home depot for the LG TROMM front loader washer. i purchessed the 5 yr warrenty and i belive after reading some of the comments in here that this was a good move. I used a maytag neptune @ work and it was a peice of JUNK! it has the mildue smell everyone is talking about. i was told of a remidy for this smelly issue. pour a good amount of casscade dishwasher POWDER not liquid into the washer drum and then pour bleach into the wash slot on the fron loader and then put the washer on the longest setting and let the machine run the cycle. i hope this works for you. i will try it once a month om my front laoder when its delivered. GOOD LUCK!!!!
Posted on Feb 21, 2008
MNTECH
  • 1543 Answers
SOURCE: LG WM-2277HB washer does not drain and make rattling noise.
I would guess that the impeller has come off the pump motor shaft. You can disassemble and push it back on, but it will come off again. I don't know if some type of adhesive would work, but I just replace the pump motor.
Drain water from small drain hose (or by removing filter) Remove the screw in the plastic recess by the filter, then use a putty knife on the left or right side to pop out the recess. Remove two more screws holding pump body to front frame of washer. Pull washer about 18 inches away from wall and tilt it back to lean against wall to allow access to the pump through the large rectangular hole in the base of the washer. There is a plastic locking tab holding the pump body to the plastic washer base, but don't worry if you break that, as the screws (removed earlier) will hold the pump back on just fine. Pump motor is held onto pump body with three more screws. Replace pump motor with a new one and reassemble. On a difficulty scale of 1 -10, this one might rate a 4.5 or a 5. Not too bad.
Leaking is rarely, if ever, caused by the drain pump. Small leaks can come from using too much soap, which backs up in the dispenser area and leaks down inside the machine, or larger leaks from a cut in the door gasket.
Posted on Apr 04, 2009
  • 15 Answers
SOURCE: LG WM2487 Leak Front Left
Not sure if this machine is similar to the WM2277, but here is the procedure for that - my leak was in the "baffels" hose that connects the drum to the drain pump:
1. Drain the machine - pry the panel at the front left lower corner to get access to a stoppered tube. drain as much water from here as possible.
2. Remove screw visible inside this area and remove the white molded plastic - also remove the screw behind that plastic.
3. Open the washer door and remove the spring loaded wire around the door gasket. Carefully pull the door gasket away from the panel push inside and then reclose the door.
4. Remove the detergent drawer and the two screws visible behind it.
5. Pull the top of the electronics panel away from the machine and lift up - place on top of machine or hook it out of the way
6 Remove the 4 screws that are visible holding the front panel to the machine. Left the entire front panel up about 2 inches and swing to the right (there is a wire connecting the door to the machine on the right)
Posted on Apr 27, 2009
  • 66 Answers
SOURCE: I have an LG WM2277HW front load washer that is
check ur inlet hoses on the outside of machine, also check the connections inside the panel in back
Posted on May 08, 2010
Hi, My Bosch Logixx 8 is showing error F18 which I think means the filter is blocked. we have lost the manual so how do you get the filter out. Do we need to drain the machine first? Is there an online...
F18 is either the pump discharge is clogged or the machine is oversudsing. If it is oversudsing, make sure that you are using an HE detergent and use less detergent. (Make sure to note the minimum detergent line
To clean out the pump discharge, have a bucket ready for when you release the hose. First, set the cycle selector to Off and unplug the washer. Open the service door and remove it. Next loosen the screws and remove the protective foil. Remove the emptying hose from the holder and take off the cap. Drain the water from the hose. Replace the cap. Then carefully remove the pump cap and drain the rest of the water from the pump. Clean out any foreign objects from the area (housing, threads of the pump cap, etc). Make sure that the impeller can turn. Then replace the pump cap and tighten the screws (the handle should be vertical). Replace the emptying hose and the foil protector. Replace the service door and plug back in. Then fill the dispenser II with 1 liter of water and then start the Drain cycle. Let this water flow through to the pump.
The manual is available from Bosch. Go to http://www.bosch-home.com/us/WAS24460UC.html?source=search and click on Additional Documents . Then click on User Manual. This will redirect you to the correct page. Select your specific model and the language and click on the manual with the IU designation. The pictures to go with the clogged pump are on page 9 of the PDF.
The filters that can get blocked are in the water inlets. To clear those, turn off the water to the washer. Select a cycle and press Start/Pause. Wait 40 seconds then set the selector to Off. Unplug the washer. Then remove the inlet hoses. Clean and replace the filters at both sides of the hose. You will need pliers to remove the filters from the washing machine side. Then reconnect the hoses and check for leaks.
I hope this helps.
Jul 09, 2011 | Bosch Logixx WAS2446 Front Load Washer
Kenmore Elite HE3 - Washer stopped - door locked - did not drain and spin - Getting error message F02
  1. Unplug the washer.
  2. Remove the 3 Torx head screws (located left, center, and right) from the front bottom kick panel of the washer.
  3. The drain/filter/pump is right in front.
  4. You can see a diagram of the pump at http://www.repairclinic.com/PartDetail/Drain-Pump/1200164.
  5. First remove as much water from the washer as you can. Place a large towel under the pump - a lot of water will come out when you remove the filter cover cap.
  6. Remove the drain filter cover cap by turning the filter cover cap counterclockwise.
  7. Remove the filter and check the housing and pump impeller vanes for debris (see if you can move the pumps impeller by hand).
  8. Clean the cover cap gasket and the gaskets mating surface.
  9. Replace the filter and close the cover cap firmly.
  10. Run a short wash cycle and check for any leaks at the filter cover cap. If the error comes back, you may need to replace your drain pump.
  11. Replace the kick panel if none are found.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 27, 2011 | Kenmore Washing Machines
I have an error code of 5UD or SUD and the water is not draining
If you are getting an F2 error message or a SUD error message, and are observing some water in the tub that is not draining at end of cycle, and your washi cycle is taking a lot longer that normal to complete,then here is what to do.
This solution is easy, and will take no more that 15 minutes, from start to finish, and most of that time is in the --prep-- (getting tools, towels, etc.). This WILL save you a expensive service call.
There are 3 small 9/32 hex head screws that hold the front panel on. The front panel I'm speaking of is --below-- the washer window.
These screws can be found::
a. if you have the optional washer storage drawer unit,, they can be found by opening the drawer, and observing the 3 screws (left, middle, and right side, that hold the front panel on.
or
b. if you DONT have the optional drawer assembly, then they are found on the front, bottom, of the washer, again holding the front panel on the washer.
1. unscrew the 3 hex head screws (9/32 socket or nut driver size)
2. lower/remove the front panel, and set it asisde on some towels, so as not to scratch the front panel.
3. get something now to soak up at least a gallon of water that WILL empty onto the floor.
4. observe large WHITE drain cap, at front center of washer.
5. unscew white drain cap --WARNING-- lots of water WILL drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
6. clean out the front and bottom of the filter trap. I'm sure lint, and gosh knows what else have cloged some of the holes
7. wipe out the inside of the housing for the filter trap (observe lots of -gunk- there too).
8 put back in filter trap, tighten white cap, and put front panel on washer with same 9/32 screws you took off earlier.
Now I ran a test --express wash-- cycle, just to be sure all was OK,, and it was.
Jun 07, 2009 | Kenmore Elite 45986 Front Load Washer
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer won't rinse and spin
clean the drain hose, but make sure you have a container to catch the water and lot of debris will come out. Then unplug the washer and put water on spin cycle to drain water, after draining water remove the pump filter located next to the drain hose turn left to open and clean more debris. I found my husband wedding band I thought he lost it on purpose. You will be surprise how much funk is in that filter. Turn pump filter to right to close and put cap back on hose. Don't call the repair guy. Hope this helped.
Darlene, New Orleans
504-296-4391
Jul 24, 2008 | LG WM-1832C Front Load Washer
Leak
It sounds like you have a leak somewhere around the door bellow. This is the rubber boot that seals the wash tub to the door frame. Pull the folds back and inspect around the entire perimeter of the rubber. You could have a small rip or tear somewhere. There are a series of small holes in the bottom of the bellow that are supposed to be there. This is the allow any standing water to drain back into the wash tub. If you cannot find any obvious signs of leaks, remove the lower panel under the door. This is accomplished by removing the screws under the bottom edge of the panel. With the screws removed, the panel will drop down, then off. Start the washer on a normal wash and watch for any leaks. If the door bellow leaks, the front counterweight (usually a concrete block) will begin to get wet and drip. This could also be an indication of the bellow clamp around the wash tub being loose. If the leak starts to pool under the washer and run out the front, this is usually an indication of a drain pump leak or drain line leak. Please inspect the washer with the panel removed and the washer on a load and post back and let me know. Go to my profile and use the "Ask Me" feature for a quicker response. I hope this helps you.
PS One other item. On the left hand side of the door bellow is the a dispenser tube that penetrates through the bellow and allows water to enter the wash tub. Sometimes the dispenser tube is not seated all the way into the rubber (should be seated past the flange) and it will dispense water behind the rubber instead of into the wash tub. Just something else to consider...
Jun 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
DISPENSER WILL NOT DRAIN
Waag, pull that dispenser drawer out of there, push down on the tab-left side in the back. Now take your index finger and see if you have something blocking the water feed hole to the tub. It will be on the inside front. Sometimes I find bottle cap disks blocking the inlet. Start a cycle with the drawer out of there and observe the water flow, if it's backing up, you have something blocking that inlet. You can always pause/cancel. Catriver.
Jan 01, 2008 | Kenmore 46462 Front Load Washer
Whirlpool Duet Sport Front loading washer and dryer with error code
An easy Fix. Take off the kick panel, 3 screws 1/4 inch. Make sure you have a shop vac ready or a lot of towels as there will be some water. Always disconnect power to washer and dryer, and turn off water to washer. Your filter most likely is clogged with change, screws, lint, and other household stuff that we leave in our pockets! Unscrew the cap on the filter, easy to find, since you have the kick panel off! Take everything out of the filter. Take your shop vac and **** out remaining stuff in hose. Also, **** up any water that has leaked in and around the washer. Screw the cap back on hand tight, put the kick panel back on, turn your water back on, plug it in and there you go! Maybe takes an hour and saves you a repair bill. If you are not comfortable with this procedure then call a maintenance person that is qualified. 775f844.jpg
Dec 26, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Zanussi FX 1265 W washing machine
You can seal the cap by some tape, but it is better to get a good replacement, for the filter needs periodic maintenance. Your machine will not drain well if the filter is clogged.
Nov 09, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Machine stops in Rinse & Spin Cycle & leaks water
Hotpoint WF430 Front Load Washer This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 24, 2007 | Hotpoint WF430 Front Load Washer
LG WM3470HWA Front Load Washer WM3470HWA Logo
21 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
