Question about KitchenAid KSB655 Blender
Replace drive coupler on ksb655 - KitchenAid KSB655 Blender
  • KitchenAid Master
  • 1,267 Answers
Unscrew it (left hand thread) and screw on a new one. Motor coupling.
Posted on Jul 26, 2014
Can you replace drive coupler on cooks XB9218WA
There would be no spare parts for that. Best plan would be to fix it with epoxy putty. Seal the lot together, if it fails again, you need a new one.
Jun 08, 2017 | Blenders
Replacing drive side coupler on a Waring HPB300 blender. Threads don't match???
There are not normally any tricks, sometimes they are left hand thread though. More likely if the thread size is really too small then wrong part has been supplied.
Jul 10, 2015 | Waring Megamix Commercial Blender Hpb300
On a KSB5WH4 how to remove & replace clutch?
it's reverse threaded. strike clutch firmly in clockwise direction with a screwdriver/hammer. it should spin right off.
Aug 03, 2011 | KitchenAid KSB655 Blender
How can I change the blade for my 2 speed hand mixer? The model type is NC-12 if you need to know
you are using your KitchenAid blender and it stops blending, you may think there is a problem with the motor in your machine. However, a common reason for the blades not rotating in the blender is a dirty or faulty coupler. The coupler is what connects your blender dispenser to the motor, and you can easily replace the coupler at any time by only using a screwdriver.
Things You'll Need
  • Flat-blade screwdriver
    • 1 Turn the blender dispenser clockwise and lift up to remove it. Set the blender dispenser aside.
    • 2 Insert a flat-blade screwdriver between the black drive coupler and the frame of the blender on the top center portion of the blender.
    • 3 Lift the screwdriver upward, and the coupler will start to bend out of place. Slightly turn the coupler and then lift up on the screwdriver again.
    • 4 Continue to move the coupler slightly and lift the screwdriver until the coupler is completely removed.
    • 5 Insert the new coupler over the blender's motor blade and then twist the coupler counter-clockwise until it is tightly fastened.
Jun 07, 2011 | Blenders
How to remove the cutters on model ksb560mco pctag@verizon.net
The cutters are part of the collar itself and not available as a separate part. If there is anything wrong with them you need to replace the whole collar. The collars are available on Amazon UK, K A Parts as well as other places.
Dec 31, 2010 | KitchenAid KSB560 5 Speed Blender
Rubber coupler on blender sheared off
Yes, it is very easy to fix. You will need a new coupler, which is part number 9704230. There is a set of instructions with video here: http://www.kaparts.co.uk/Howtoremoveablendercoupler/tabid/219/Default.aspx
Feb 13, 2010 | KitchenAid KSB3 Classic Work Top Blender
Teeth sheared off the coupler drive on KitchenAid Blender
You should be able to remove this assembly from the other parts - then you will have enough room to work on it.
Remember to clean the seal area if disturbed or it may leak.
Aug 20, 2009 | KitchenAid KSB560 5 Speed Blender
Square drive pin for Osterizer blenders?
I simply slid a small screwdriver in through one of the holes under the base to prevent the fan from spinning and unscrewed the pin counterclockwise using some small channel lock pliers. No disassembly necessary.
Jan 26, 2009 | Oster 4134 / 4126 Classic Beehive Work Top...
Rubber drive wheel disintegrated. How do we replace?
The rubber wheel is known as the "coupler." To clarify: the coupler is a black, cylindrical rubber piece that juts out of the top of the motor base and you set the pitcher on top of it.
This part can be replaced through a Kitchenaid certified service center, where they can provide the part for you. It is a low-cost repair.
A listing of certified Kitchenaid locations may be found here:
http://caservice.kitchenaid.com/
Also, if you are interested in self repair, you may order the part and view do-it-yourself instructions here:
http://www.mendingshed.com/kacoupling.html
Apr 06, 2008 | KitchenAid KSB5 Professional Stainless...
KitchenAid KSB655 Blender Logo
80 people viewed this question
Top KitchenAid Blenders Experts
Appliance engineer
eyecam
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
