Question about Acer C7 Chromebook
Battery won't charg
Light on power button and charge light flash battery won't charge over 1%
longgee
  • 322 Answers
SOURCE: BATTERY NOT CHARGING
Try replacing the battery, i think the battery is defective.
Posted on May 09, 2009
Geekman
  • 32281 Answers
SOURCE: Acer 5315 Battery cHarging Problems
All rechargeable batteries have a limited life, and as they age their charge capacity reduces over time and you get shorter and shorter time between charges.
Recharage batteries have a finite number of charge and discharge cycles and batteries over 2 years old are considered nearly worn out. Worn out batteries won't charge up at all.
Posted on Jun 30, 2009
tbirdfan1
  • 3051 Answers
SOURCE: My Acer Aspire 5720 laptop won't charge while it's running
Hello there:
try removing the battery from the computer and turning on the computer to see if the power cord works correctly if it does inspect the battery and clean the terminals on the battery and computer and put the battery back in while it is still on now you should see the battery show up on the taskbar if not right click anywhere on the desktop and go to properties and than go to than go to screensaver than look towards the bottom and you will see power click on it and you should see the options for the battery ok sorry this was so long but i needed to explain it in full
please dont forget to rate this
best regards mike
(usn retired)
Posted on Aug 04, 2009
SOURCE: Acer 5100 charge light is blinking while plugged in
well either you have a bad battery, or a bad charger, or your ACPI settings are not correct in BIOS, you must check each one, First you must check the Power Adapter, usually with a multimeter set to Volts DC and see if it the same as what is written on power supply, Next check the batteries voltage with a meter and see if that is OK, really the only real way is to substitute the battery, and expensive guess? Also as said check your ACPI settings are OK in BIOS and Windows power settings too. Use your manual for reference.
Posted on Feb 20, 2010
rajdeepdutta
  • 2517 Answers
SOURCE: Battery Wont Charge
Hi there as per your information there is a chance of battery damaged. So i suggest you use your battery in others laotop for confirmation. If your found the same problem then buy a new battery . Thanks & waiting for your feedback.
Posted on Mar 17, 2010
My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
Apr 04, 2013 | Electrolux Zb4106wd Rapido Wet And Dry...
Tip
Laptop Battery Won?t Charge?
If your dell laptop computer runs normally on the AC adapter, but the battery won’t charge, please try the following troubleshooting steps:
Check the dell laptop battery and Connections:
1, Remove the battery from the system.
2, Look at the connectors in the bay and on the battery for signs of physical damage.
3, Check the battery charge by pressing the status button or image on the battery near the LED’s.
Note: The lights indicate the current amount of charge on the battery. If all the LED’s come on when you press the button, the battery is fully charged. If fewer lights are lit, then the battery is partially charged. If any lights flash, or blink, there could be a problem with the battery.
4, Reinsert the battery; push until it locks into place and the latch snaps back to the locked position.
Swap Bays or Try A Second Computer:
1, Some systems can run with the battery in either bay. Try swapping bays if you have one of these systems.
The following systems permit a battery to be used in either bay:
Inspiron systems 3700 3800 7500 4000 4100 4150 8000 8100 8200 Latitude systems CPx H CPt V CPx / CPt C600 C610 C640 C800 C810 C840 Note: It may be necessary to slide the face plate left or right on some batteries when switching bays. 2, If you have access to a second computer like your own, try to charge your battery in that system.
Flash the BIOS:
Flashing the BIOS can correct many hardware issues.
NOTE:Dell recommends that you update the BIOS on your system, only if you are having problems
1, Go to “The Dell support site”
2, Be sure your system is the one listed in the Your System section on the left.
3, Click the Downloads tab
4, Choose your operating system from the drop down menu
5, Select FlashBIOS Updates as the download category.
6, Click Go.
Select the link to download the most current version of the BIOS:
1, Save the program to your desktop.
2, Go to the desktop and double click the icon.
3, You will be given the option to either create a BIOS disk or flash the disk from the hard drive.
Run the Recalibration Utility if Your System has One:
This utility runs the battery all the way down and then recharges it completely. The process takes several hours so it is best to run it overnight. Use only the recalibration program specified for your system. Using any other program could void your warranty!
Latitude LM, Inspiron 3000 and Inspiron 3200 systems use this recalibration program: BATRECAL.EXE
Inspiron 5000, Inspiron 7000, and Inspiron 7500 systems use this program: I75BRCA0.EXE
Latitude LS, Latitude L400, Latitude X200, and Inspiron 2100 enable a recalibration option on the Power page of the BIOS Setup Program:
How to Enable Battery Recalibration
Try to charge a second battery like your own if possible.
If the second battery won’t charge, the problem may be caused by the charging system in your computer.
If the battery still won’t charge after you have done this troubleshooting,it mean you should replace your old battery,you can go to www.sales-battery.com to choice a new dell laptop battery replacement
post via:dell.com
Battery purchase information:
US shop
http://www.sales-battery.com/laptop-batteries/dell.htm
UK shop
http://www.global-battery.co.uk/laptop-batteries.htm
need Universal External laptop battery
http://www.global-battery.co.uk/universal-external-laptop-battery.html
http://sales-battery.com/External_laptop_battery.html
on Jun 15, 2010 | Computers & Internet
Lap top Battery problem
POWER SUPPLY & BATTERY PROBLEM
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Aug 02, 2012 | MSI Computers & Internet
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
Jan 12, 2012 | Lands Phones
Battery light flashs orange continusly on a dell latitude d620 if i disconnect the power cord the computer shuts down
Two possible causes for flashing Amber battery light.
1) Your battery won't charge and needs to be replaced.
2) Your charging circuit for the battery is defective and then your motherboard of laptop will need to be replaced.
Oct 20, 2011 | Dell Latitude D620 Notebook
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Medion E1210 notebook. Battery has suddenly stopped charging. Didn't get a fall. Laptop works fine when power supply connected, but if plugged out laptop shuts down immediately. When power plugged in...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Computers & Internet
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Won't turn on. Battery is plugged in and lit. n
Try removing your battery pack. Then connect the power adaptor (even without the battery) and connect is directly to the power outlet. If it powers up, then the battery pack might be defective or totally drained.
If the battery is just totally drained, simply place the battery to the laptop. Do not turn the laptop on. Plug the power adaptor to the laptop and plug it to the power source. If you see that the charging LED is blinking in your laptop, then just leave it charging up to 5 to 8 hours.
Never use a laptop on battery mode while it is plugged in to a power source. This is the number 1 reason why laptop batteries don't last longer.
Jun 06, 2010 | Sony VAIO Notebook
I have a Dell Inspiron 1525 that won't start. The battery light would flash orange 4 times then blue once, and then start over with the same sequence. Pulled the power board and fixed the solder joints on...
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
Dec 27, 2009 | Dell Inspiron 1525 Notebook
Acer C7 Chromebook Logo
20 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
