Question about Kodak EasyShare Z650 Digital Camera
Can you buy a new kodak easy share camera 2014
Agent Allan
  • 480 Answers
SOURCE: Kodak memory card error
Hey hardygurl198,
What is most likely going on is you need to format the card so it will work in your camera. Every time you get a new memory card for a digital camera or if you put a memory card formatted to a different camera in a new digital camera you will need to format the memory card before you can use it. Directions on how to format your memory card are on page 27 of your camera manual, and I have provided a link to a PDF download of your manual in case you need it. I hope this helps!
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00431/C310_CD40_GLB_en.pdf
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jul 08, 2008
SOURCE: camera error message #E45
I have fixed the problem! For any out there with a the same problem, all you have to do is smack the extended lense against your palm firmly then turn the camera back on. It just worked for me and no more error, camera is now working fine. Good luck!!
Posted on Jul 31, 2008
SOURCE: my kodak easy share v1233
hi i was having the same problem with my polaroid camera my solution was that the bottom lid to the battery compartment was taped shut. and when it came loose i could only keep the camera on by holding the tape in place to keep it shut. now it works fine hope this helped some.
Posted on Jan 02, 2009
SOURCE: Kodak Easy share C182 Digital Camera
Please check that you have putted kodak alkaline batteries.
Posted on Apr 12, 2010
  • 141 Answers
SOURCE: Is the kodak easy share c180 digital camera webcam?
I won't say the camera is usable as a webcam because you will definitely severly shorten the life of the camera by using it as such. Firstly the camera is designed to take photos and short videos, NOT being left on continuously for use as a webcam. The heat generated by doing so could damage the delicate CCD (the part which collects light from the lens and converts it into electrical signals) Secondly most cameras are deigned to switch themselves off after a certain period of non use. Not handy for webcams.
Next there's the power issue. Unless you are using an external power supply for the camera you will be forever replacing batteries and for what an external power supply costs you could buy a proper made for the job USB powered WebCam complete with focus and sometimes zoom.
Next there's the mounting issue. Where will you mount the camera to give a well lit and steady picture of your face. Definitely not on top of the monitor due to extra heat generated by the monitor itself. Mix that with camera's heat and hello, and too soon, goodbye camera.
Webcams cost $20 if ou shop around maybe cheaper. OK your cmera will give a better picture but at the distance you're talking it won't matter. Plus you will need software to generate the webcam picture. MSN is a good webcam program. Plus depending on the output of the camera, usually only video. You may need a video capture card for your computer. The camera will give you a full screen image of what it's pointed at but you need a box to put a smaller picture in on the screen otherwise all you will see is one big face, yours.
So do you really want to wear your camera out prematurely simply because you can't afford a $20 webcam. The made for the job unit is cheap, will stay on all day and the power comes from the USB port. Everything you need and cheap. I think you know which way to go.
Good luck
Posted on Apr 22, 2010
Can not email picture from easyshare camera
It is not possible to email directly from the camera.
If you're experiencing emailing difficulties directly from the Easy Share Software:
Please do a Clean Install on the software:
Please follow the instructions:
  1. Uninstall Easy Share software:
  2. Select Start > Settings > Control Panel > Add / Remove Programs.
    For Windows XP operating systems, select Start > Control Panel > Add / Remove Programs.
  3. Select Kodak Easy Share software.
  4. Select Remove (or select Change, and then select Remove).
  5. Run the Clear utility:
  6. Visit the CLEAR Utility for Kodak Easy Share software Web page at www.kodak.com/go/clear
  7. Click the Download button, and then follow the on-screen prompts.
  8. After restarting your computer, visit the Kodak Easy Share software Web page at www.kodak.com/go/easysharesw and install the latest version of Easy Share software.
Jan 19, 2010 | Kodak EasyShare One Digital Camera
All of a sudden my Kodak Easyshare 530 will not transfer pictures to my computer, I have reinstalled software, still does not transfer. Can you help me?
Possible solutions:
Remember you need to turn the camera on when transferring.
Try a different USB outlet
Try a different cable
Try a different computer.
If all fails please contact KODAK in order to arrange a repair or order a new cable. Remember your USB cable is covered under the same warranty as your camera, so remember your serial number when calling:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
If you suspect it could be directly related to your software.
You need to follow the instructions:
Jan 10, 2010 | Kodak EasyShare C315 Digital Camera
Easy Share P850 lost eyecup
According to Kodak, the rubber eyepiece is not available for purchase, you have to send it to them to get it fixed...I would try to take it to a local camera repair shop and let them do it.
Oct 28, 2009 | Kodak EasyShare P850 Digital Camera
I just want to know what battery to buy for a Kodak M763 Easy share digital camera
This is the battery that you need to buy its a Kodak KLIC-7001 Lithium-Ion
Apr 24, 2009 | Cameras
My kodak easyshare C813 WONT TURN ON!!
After searching and getting the run around, the only solution I've found is to BUY a new camera that IS NOT Kodak!!! I had never had a problem with Kodak until now...I WILL NOT buy this brand ever again!
Apr 03, 2009 | Kodak Easyshare C813 Digital Camera
Kodak Easy Share CD1013 pictures won't download on Vista
Hello and welcome to FixYa
Please go to a electronics store and buy a USB card reader. I bought one last week and it cost $0.5 so its cheap as dirt. Then simply remove the card from your camera , pop it into the reader and the pictures will appear on a drive like a flashdrive in your my computer folder.
This is a much better option than using the camera's cable as it is faster , safer , saves on your camera battery and you don't need to install any software or drivers.
The card reader will most likely also still be compatible with any new camera you buy in future.
Kind Regards
Andrea
Mar 24, 2009 | Kodak EasyShare One Digital Camera
Kodak EasyShare Z650 Digital Camera Logo
23 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
