Question about MSI X340-021US Notebook
Deactivate sleep mode
When starting up my x340 only the moon icon is luminated? but before that i having problem with booting
Hp slimline s3000 goes immediately into sleep mode
Try booting into Safe Mode then go into the Control Panel and change the Power Options.
Turn off the computer, then hit the power button to turn itback on and immediately start hitting the F8 key repeatedly until you see SAFEMODE. Take the Safe Mode option and let it boot up. Safe Mode will lookdifferent to you, the screen will be darker and the icons bigger, this isnormal.Once safe mode is up click Start/Control Panel and look for Power Options.
Apr 08, 2012 | Computers & Internet
Hi i have an msi u130 and i got a problem when i turn on the minilap shows a black screen and the led of the little moon its ON but doesnt work what can i do? please help me
The moon icon usually indicates that your machine is in SLEEP mode. Try closing and opening the screen lid. If not, there might be a problem with your laptop waking up from sleep mode. Try holding the power button. This will turn it off. Turn it on again by pressing the power button once more. Hope this helps! Have a nice day.
Apr 11, 2011 | MSI Wind UmNotebook
Moon
If the shape of the symbol is the cresent moon....then that is the "Sleep" shortcut key. It will send the hard drive into standby mode. In a lot of systems, this sleep mode can really corrupt and damage system files. I always recommend disableing sleep mode in the power options section of the control panel.
May 24, 2010 | Compaq Keyboard
I have a Compaq keyboard that has a half moon on the top left of it and I hit it and my monitor went blank. How do I get it back
Reboot the computer in Safe Mode by pressing F8 at boot up and selecting Safe Mode. Then go to Start->Control Panel->Keyboard. Here you will find settings of this keyboard. Disable the sleep mode. And your monitor will come alive. Whenever you have any problem you must first use the control panel and try your hands at DIY. But do remember what you did in what sequence to undo it later if need be.
Nov 17, 2009 | Compaq Keyboard
Have msi lap top vr601x model when try turn on by power button a half moon icon on keypad flashes on with the power button then after 3 sec turns off what does this mean
the half moon indicate an sleep mode when you open your laptop the sleep mode is already activated thats why it goes to shutdown reason is your sleep mode key is grounded try to consult it to your your dealer
Sep 17, 2009 | MSI VR601 Notebook
What does the half moon lit up mean, No screen.
The half moon usually means the computer is in SLEEP MODE. Normally, pressing the spacebar will wake the computer up but I have noticed that sometimes, the computer can get "stuck" in sleep mode. If that is the case, you can hold the power button down (until the power turns off and the moon disappears). Wait a few seconds then hit the power button again to turn the laptop back on.
Jul 12, 2009 | IBM ThinkPad T30 2366 Notebook
What is 1/4 moon symbol on top left of my compaq keyboard ? when i press it seems to put my computer into sleep mode . how do I get my computer started again ?
You are correct. The moon is sleep mode. Closing and opening the lid will often take it out of sleep mode. You might have to "unlock" the keyboard as well by entering a password (just hit return if you haven't entered a password.)
Under power options, you can select what the computer does in sleep mode.
Jun 20, 2009 | Compaq Keyboard
How is a flashlight both luminous and nonluminous at the same time?
At first light it DOES sound a bit confusing.
First, the definition of the term 'NON-LUMINOUS'; 'Not capable of PRODUCING light but can be capable of REFLECTING light from another source'.
For instance, our MOON is NON-LUMINOUS as it REFLECTS light from the Sun. The SUN is LUMINOUS as it produces light that is REFLECTED off the surface of the moon. And so, LUMINOUS means capable of PRODUCING light.
Now closely examine your flashlight.
The BATTERIES produce electrical energy which is transferred to the BULB which emits light, thus LUMINOUS. The tiny little BULB emits quite a lot of light for its small size. However, the bulb is contained within a concave silvered cone which REFLECTS,(NON-LUMINOUS) gathers and channels the emitted light from the BULB (LUMINOUS) into a BEAM which ILLUMINATES whatever you are pointing the flashlight at.
Our cameras would be just paperweights if there were no NON-LUMINOUS surfaces for the light to REFLECT off of, back into the camera lens, onto the 'plate' thus etching the image. For example, take a photograph in the dark without the flash and what do you get. No LUMINOUS, no NON-LUMINOUS.
And so there we have LUMINOUS and NON-LUMINOUS, ILLUMINATING our lives. Enjoy! :)
Jul 21, 2008 | Vector Power On Board High Intensity...
Sleep Mode
u have press power on button again the ur pc will be on again
thnx to using fix ya
Mar 30, 2008 | Computers & Internet
MSI X340-021US Notebook Logo
23 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
