Question about Life Fitness 91Ti Treadmill
Treadmill wax motor - Life Fitness 91Ti Treadmill
Tip
How To Re-Wax a Wood Deck for a Trotter Treadmill
Following are instructions on how to re-wax a wood deck for a Trotter treadmill and a list of materials needed for this procedure
Materials Needed for Re-Wax
  • 1 lb. of Trotter deck wax
  • Clothes iron (never to be used on clothing again)
  • Belt sander with 120 grit sanding belt
  • Vibrating sander with 250 and 400 grit paper
Pre-Existing condition: If your wood Trotter treadmill deck is worn down through the first ply, it cannot be re-waxed.
  1. Using a belt sander and 120-grit belt, gently sand in the same direction as the grain the glazed layer off the top of the deck until you have reached porous wood. If, while sanding, the first layer of ply has been sanded off, the deck can no longer be re-waxed
  2. Using a vibrating sander with 250-grit paper, sand the entire top surface of the deck until it is smooth and soft.
  3. After sanding with the 250-grit paper, continue sanding with 400-grit paper until completely smooth.
  4. Heat the clothes iron to its maximum temperature. Put a handful of Trotter deck wax on the center surface of the deck and place the preheated iron on top of it until the wax melts.
  5. Work the wax into the deck surface by pushing the melted wax across the deck with the iron. Add more wax as needed until the entire top surface of the deck is impregnated with wax.
  6. Apply just enough wax until the wood is saturated with wax.
Do NOT leave wax pooling on the surface of the deck.
How To Re Wax Wood Trotter Treadmill Deck
on Mar 11, 2015 | Exercise & Fitness
Display screen says waxer disconnected how do I fix
Remove the motor cover and look for the Wax lift board , it's right by the motor controller and check all wiring going to it.
Mar 01, 2015 | Life Fitness "Remanufactured 95Te...
Cybex 520t error 6
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Error 6 is a motor over voltage error. Motor voltage exceeded 200 VDC for 200 milliseconds. This can be caused by a worn deck and belt due to a lack of routine maintenance. AKA adding wax between your deck an belt. You might be able to wax your machine and make the error go away. More than likely a new deck and belt will be needed. Using the link below and your model and serial number, you can find the needed items. In worse case scenario, you may also need a new motor control board.
Repair Parts for Trotter Cybex Treadmill 400T 410T 500 Series SPORTSMITH...
Apr 07, 2014 | RTO Cybex 520T Remanufactured Treadmill
Lubricating walking belt
Video about How to Wax a Treadmill Using Powder Wax
How to Wax Treadmill Using Powder Wax Video
Video of How to Lubricate a Treadmill using Liquid Lube
How to Lubricate Treadmill Using Liquid Lube Video
Apr 02, 2014 | Exercise & Fitness
Lifefitness treadmill belt sticks even though wax bag is fulll
alot of times you have to remove the wax spray nozel and clean as the wax hardens over it
Apr 01, 2014 | Life Fitness 91Ti Treadmill
How do i refill the wax on my life fitness 9100 treadmill?
open cover on left at rear of treadmill, disconnect pipe, fill with wax kit and then reconnect pipe, 2 screws to remove wax cover.
Mar 30, 2013 | Life Fitness 9100 Next Generation...
I am getting a noise that increases with speed. I replaced the front roller so it should not be bearings. It is a growling noise could the motor be the problem? I have a Vision T9500 Ortho and I use wax to...
have you removed and cleaned the wax buildup off the rear roller? typically with the wax lubricant it will cause chunks to get caught in the rear roller and the grumbling sound is normally the irregular belt position as the wax buildup lifts and stretches the belt in places that it shouldnt.
Jun 16, 2010 | Dmm Vision Fitness T9500 Treadmill
My treadmill says waxing needs refill maintainance required
1) Flip the treadmill on its side to expose the bottom 2) remove the two screws holding the rectangular metal wax cover 3) remove the wax cover 4) you should see a bag of wax, replace it with new 5) type in 5-1-2-5-Enter to reset the wax statistics
Jun 24, 2010 | Life Fitness 9000 Next Generation...
Every motorized treadmill must need some regular type of servicing. What is the procedure? What do I need to do to keep my treadmill in good working order?
The main thing to do is keep the walk belt area clean of all shoe rubber and lint,vacuum the tread melt and edges regularly.Most treadmills have a wax lubricant in the walk belt,youcan purchase this lubricant at store that sell treadmills or you can do an on line search for treadmill lubricant.If you lift the belt and feel under the platform you should feel a slight waxy film, if not you should add wax as needed,some wax kits come with instructions, but if you just apply it to the platform area underneath the walk belt where you feet normally land when to step forward that should be fine,walk on the treadmill for a few minutes to spread the wax evenly on the underside of the belt, other than that there is no other maintenance needed.
Jul 10, 2009 | Exercise & Fitness
Life Fitness 91Ti Treadmill  Logo
13 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Craig Butler
Craig Butler
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
