Radio takes up to 30 minutes to turn on
Radio also frequently starts at the preview channel rather than the last channel listened to.
3 Suggested Answers
sTatiC00000L
  • 8 Answers
SOURCE: xm will not work
i understand that you're only getting preview channels..and had the radio for almost 3 years....yes, they might be correct that your radio was broken already...but, have you ever asked them to refresh the signal into your radio? If you want you can do it online at www.refresh.xmradio.com all you to do is to key in your 8-digit radio i.d(can be found on ch. 0) then click submit...it'll give u the activation instructions...that u need to follow faithfully..if this won't work..i'll get back to you next week..Godbless!
Posted on Sep 08, 2008
TOLhamRadio
  • 509 Answers
SOURCE: it has started to go to channel the 1 preview
Is your power button stuck?
Posted on Jul 26, 2010
Pro-95 will not scan, when first turned on, unit goes to manual mode with last selected channel. Upon selecting SCAN, unit will switch to SCAN mode, but will not move off the bank of last selected...
If you did the hold down '2' '9' reset, there isn't much more you can do. I have tried pulling out the battery pack and putting in a jumper wire between both battery contacts inside the radio (with no battery) and turn it on and let it sit for 1/2 hour. That's about the last thing to try. Only other goofy thing could be you got 'sticky pop' on the 'manual' button, so the radio thinks you pushed the manual button as soon as you turn it on. Make sure that the rubber isn't stuck around the manual button. You could try a QTip with 70% alcohol around the edge of the MANUAL button, but you also might wipe off some lettering at the same time, so use caution. Good luck and let me know how it goes.
Apr 26, 2017 | Radio Shack Pro-95 Handheld Scanner
How do I link up my akira 2way radio to different 2way radio like bell
They may not be compatible. Quite frequently, they use different numbers for the same channels, you may just have to experiment.
Aug 21, 2013 | Uniden BC60XLT-1 (30 Channels) 2-Way Radio
The radio on my 2010 Subaru WRX has A Sat button on the radio. How do I get an XM Tuner to activate this button?
Many/most of the original factory radios with the 'XM' button already have the tuner in them. While outside (not inside a garage or under trees) Press the "XM" button then see if you can get channel 1, or channel 247, or channel 0. Channel 1 is free previews, channel 247 is free weather, and Channel 0 is the serial number of the radio. IF you have these 3 channels then all you have to do is call 1-800-XM-RADIO with the serial number from channel zero. Leave the radio on channel 1 for 30 minutes after calling, and you should then be activated. Let me know if you have more questions.
Jul 17, 2010 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
All of a sudden the display says invalid channel and 0% updating channels sirius says the radio must be broken
I would try a different antenna first, then exchange radio if that doesn't work. You will have to 'update' the radio for about 30 minutes after you first activate it, but after 30 minutes it should be fine. Try the activation channel (channel 1) - call Sirius for a 'refresh'. After 30 minutes, your undate should be done. Turn the radio off with the pushbutton on the radio. Turn it back on - should be no more updating. If so, then there is a problem.
Dec 29, 2009 | Sirius Starmate ST2 Satellite Radio...
Lost manual and cannot program scanner bc145xl
Try these instructions from Wiki.answers
Turn on unit.
Press MANUAL button.
Press MANUAL button again to select the channel you want to program. Note the channel in the display. If there is a hyphenated symbol in the upper left corner the channel has been locked out. Press the LOCKOUT button once to remove the symbol or press the LOCKOUT button to lock a channel out. To find out if there is a frequency programed into that channel, press the PREVIEW button. Each digit of the frequency that is stored in memory will be displayed in the LED display. To program a new frequency into that channel, simply press the digits of the frequency you want, including the decimal point. Press the "E" keypad key to enter it into memory. If you get a "E" displayed in the LED display, the frequency was entered wrong, is not a valid frequency or is out of range for the scanner. Last but least, the scanner is not working properly. If the channel is active, (communications going over it) set SQUELCH to higher number, until you hear the communications or just noise. To set the SQUELCH, select a channel that has only noise and turn it down to the point the noise disappears. You make have to readjust it to your liking. Once you have the channels programed you can select the SCAN button to listen to all the channels or select the MANUAL button to listen to just one channel. If there are channels that you don't want to hear during the scan mode, go to MANUAL and select the channel you don't want to hear and press LOCKOUT button. Then press SCAN again it will only scan channels you want to hear.
Hope this helps.
Sep 07, 2009 | Radio Communications
My RoadyXT forgets what channel it was set to when I turn it off for more than a few minutes. It remembers if I'm only moving it from one vehicle to another, but when I turn it off overnight, it comes on...
No battery. Always turn it off with the POWER switch, not just pulling the plug on the radio or taking it ouf out it's base. Using the POWER switch, then it will remember for a little while.
Aug 13, 2009 | Delphi Roady XT XM Radio Receiver
Can't get refresh signal to work for xm radio
to reset the radio - it must be removed from the dash and unplugged.
Be sure to write down any anti-theft codes if your radio requires them.
However - since your radio is getting the 2 channels - it is working properly. The problem lies in XM turning on your account.
Be sure to get the correct # off the radio... sometimes there is a transposition error with paperwork.
The number can be gotten by setting your radio to channel 0. This is your radio ID# required to activate the radio.
Your Radio is working fine - call XM and stay on the line until they activate your account.
I have a suspicion the number was written down improperly.
Be sure when you call that the car is on, and that it is tuned to station #1... also - it can take 15-20 minutes to activate - and must be left on for the duration to catch the activation signal that is sent out.
Here are the steps from XM to activate manually-
Get Your XM Radio Activated Online
Step1 Turn on your XM radio and tune it to channel 0. The display will read your XM radio's identification number. This number will include both letters and numbers. Write this number down and head to your computer.
Step2 Log onto the Internet and go to the XM radio website. A high speed connection to the Internet will make this go faster, but you can activate your XM radio online with dial up.
Step3 Click on the tab that says to activate a new XM radio. This will take you to a screen where you will enter your XM radio's identification number. Type this in.
Step4 Choose a screen name and password to make an account on the XM web site. The screen name should be something that you will easily remember. The password needs to be at least 7 characters long and include 1 capital letter, 1 lowercase letter, and 1 number.
Step5 Enter your personal information for the activation of your XM radio. This information will include your name, address, and email address. You will also need to choose which service plan you will want to purchase for your XM radio. Enter your credit card payment to finish purchasing your activation of your XM radio online.
Step6 Turn on your XM radio and tune it to channel 1. XM will send a signal out to your XM radio to activate it. You will need to leave the radio tuned to channel 1 for 15 to 20 minutes to activate it.
If you have additional questions or concerns - please ask me first before moving on to another expert.
Thanks for using FixYa!!
Apr 01, 2009 | XM Radio Audio Players & Recorders
Xm will not work
Sep 08, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
32 people viewed this question
 Grubhead
Grubhead
