Question about Dyson DC44 Animal Cordless Vacuum
Dyson dc44 animal just quit and will not work even when plugged in
My dyson dc44 animal stopped working and even when plugged into charger will not run. I have checked for any blockage or other abnormalities and cannot see any problems.
SOURCE: dyson animal, have to hold ON switch for it to work
Pull the wand out of the Vac. Need to use a small Torx bit to take out 2 screws hidden behind the wand storage. Once screws are out, there are 4 push-clips which need to be un-latched. Pry the power panel off and you will expose the two switches (one for power, one for the brushes). Push the power switch down and it should "release" and go back to clicking when pushed. Re-assemble. Took about 5 minutes to fix.
Posted on Nov 15, 2008
  • 55 Answers
SOURCE: Dyson Animal hose collapses when using attachment hose
You have a clog in either your hose or your wand. You need to take off the wand and hose and inspect them.
Posted on Dec 02, 2008
  • 7 Answers
SOURCE: My Dyson Animal 14 beater brush will not turn.
It MAY be a clutch issue. I had a similar problem with my DC07 Animal recently a posted a solution elsewhere on this site, but here's the summary. To reset the clutch on my model, recline the vacuum, turn it on it's side and slowly change the carpet/bare floor knob from one setting to the other about 6 times. This apparently reset the clutch and now it works fine. You may also wish to call DYSON. They're very helpful and walk you through troubleshooting before recommending servicing. Their number is 1-866-693-9766. They'll need your model and serial number (located on bottom of uinit).
Posted on Apr 18, 2009
rustysheriff
  • 344 Answers
SOURCE: Dyson cleaner keeps cutting out, no blockage found, filter clean.
1. Check the on/off button these can also be troublesome and if you've stood on the cable once or twice you could have a break in the wire and it's shorting, check by turning on and wiggle cable around where it enters machine.
2. Faulty thermocouple, it is held in a white plastic housing screwed with one T15 torx screw to the motor housing. You could replace it but I just shorted mine with some wire and it hasn't failed since and more importantly not caught fire yet!
Posted on May 28, 2009
Dysonteam
  • 167 Answers
SOURCE: No suction on wand of Dyson DC14 Animal
Hi its Darran at Dyson.
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Posted on Apr 22, 2010
Can I leave the battery charger plugged in to my Dyson DC44 animal after the battery is fully charged
i take mine off the charger just for safety seasons dont like leaving things plugged in after its charged.
Dec 07, 2016 | Dyson Vacuums
Is charger not working?
If you have a DC voltmeter and can see the contacts in the charger, you may be able to see it the charger has a output. But with the newer electronics for battery charging, the battery may need to be in the charger to get a reading. My guess is you do have a bad charger.
Jul 26, 2015 | Dyson DC44 Animal Digital Slim Cordless...
Is the charger dead?
Hi Malgorzata, it's Jack at Dyson.
I'm sorry to hear your machine isn't charging. In order to confirm whether the fault lies with the charger, battery or main body, our experts would need to talk you through some simple diagnostic checks when you have your DC44 easily to hand.
When convenient, please give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Jul 21, 2015 | Dyson DC44 Animal Cordless Vacuum
Why can't I make my dyson dc44 work
Hi there, it's Jack at Dyson.
I'm sorry to hear about the difficulty you've experienced with your DC44 Animal. In order to diagnose the cause of the issue and determine the correct resolution, we'd need to take you through some quick troubleshooting checks when you have your machine to hand.
When you have a moment, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). If a replacement part is needed, we can also confirm if this is covered under our 2-year parts and labour guarantee.
Aug 27, 2014 | Dyson DC44 Animal Cordless Vacuum
Dyson manuals
http://www.dyson.com/support/dc44/dc44-animal
The Dyson Helpline is available during the following times (CST):
1-866-MY-DYSON
(1-866-693-9766)
Monday - Friday: 8am - 8pm
Saturday: 9am - 6pm
Aug 26, 2014 | Dyson DC44 Animal Cordless Vacuum
Pulsing then stops
Dyson Digital Slim cordless vacuums such as DC44 Animal are engineered to make a pulsing noise to warn you if the machine has a blockage. This can occur if an item too large for the machine has been vacuumed up accidentally. It's easily resolved by checking the floor tool, wand and bin inlet: http://www.dyson.co.uk/support/dc44/dc44-animal/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual-dc44/no-resolved-redirect-to-check-the-wand/check-wand
I'm confident following these steps will resolve the issue, but for any further guidance from our experts you can reach us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 06, 2014 | Dyson DC44 Animal Handheld Vacuum Cleaner
Do you keep the Dyson DC44 plugged into charger all the time?
I don't keep mine plugged in, but that's because I haven't mounted the charger on the wall. I think rechargeable batteries are smart enough nowadays to allow for an appliance to be constantly plugged in.
Jul 10, 2014 | Dyson DC44 Animal Cordless Vacuum
Not starting at all
The issues with your DC44 Animal sound unusual, and we'd like to take some further details. If a replacement part is needed, we can also confirm if your machine is within our 2-year warranty period.
When your machine is fully charged and easily to hand, please call us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). Our experts will be happy to run you through some quick diagnostic checks to help determine the best course of action.
Dec 01, 2013 | Dyson DC44 Animal Cordless Vacuum
Won't turn on and charger is flashing
Hi Becky, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC44 Animal. To confirm why the charger is flashing we'll need to take you through some quick diagnostic checks when you have your machine to hand.
Please give our Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US) so our experts can provide further assistance. We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Aug 07, 2013 | Dyson DC44 Animal Cordless Vacuum Handheld...
Dyson DC44 Animal Cordless Vacuum Logo
50 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
